C13234_SATU-S
C13234_SATU-S
    LEDIL(芬兰)
C13234_SATU-S 数据手册
PRODUCT DATASHEET C13234_SATU-S SATU-S ~19° spot beam optimized for CREE XT-E TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant Ø 21.8 mm 8.9 mm glue, pin yes MATERIAL SPECIFICATIONS: Component Type Material Colour SATU-S Multi-lens PMMA clear Finish ORDERING INFORMATION: Component C13234_SATU-S » Box size: 480 x 280 x 300 mm Qty in box MOQ MPQ 2880 120 120 Last update: 17/11/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 7.7 1/9 PRODUCT DATASHEET C13234_SATU-S See also our general installation guide: www.ledil.com/installation_guide Last update: 17/11/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET C13234_SATU-S PHOTOMETRIC DATA (MEASURED): LED XB-D FWHM / FWTM 21.0° / 47.0° Efficiency 80 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 20.0° / 43.0° Efficiency 85 % Peak intensity 4.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 20.0° / 41.0° Efficiency 86 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 25.0° / 53.0° Efficiency 83 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET C13234_SATU-S PHOTOMETRIC DATA (MEASURED): LED XP-G2 FWHM / FWTM 26.0° / 52.0° Efficiency 85 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 24.0° / 50.0° Efficiency 89 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 27.0° / 55.0° Efficiency 88 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 26.0° / 56.0° Efficiency 86 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET C13234_SATU-S PHOTOMETRIC DATA (MEASURED): LED NF2x757A FWHM / FWTM 23.0° / 56.0° Efficiency 85 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 24.0° / 52.0° Efficiency 85 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 80 FWHM / FWTM 18.0° / 44.0° Efficiency 81 % Peak intensity 4.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351Z FWHM / FWTM 24.0° / 50.0° Efficiency 87 % Peak intensity 3.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET C13234_SATU-S PHOTOMETRIC DATA (MEASURED): LED Z5M1/Z5M2 FWHM / FWTM 27.0° / 54.0° Efficiency 93 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET C13234_SATU-S PHOTOMETRIC DATA (SIMULATED): LED XP-G2 HE FWHM / FWTM 28.0° / 56.0° Efficiency 96 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON H50-2 FWHM / FWTM 24.0° / 46.0° Efficiency 90 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 26.0° / 51.0° Efficiency 87 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Synios P2720 1/2 mm FWHM / FWTM 16.0° / 33.0° Efficiency 94 % Peak intensity 7.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET C13234_SATU-S PHOTOMETRIC DATA (SIMULATED): LED Z8Y22P FWHM / FWTM 27.0° / 56.0° Efficiency 87 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 17/11/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET C13234_SATU-S GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 17/11/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
C13234_SATU-S
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光隔离型光电开关,具有高灵敏度和高可靠性,适用于各种工业自动化控制领域。
3. 引脚分配:EL817共有6个引脚,分别为Vcc、Out、GND、A、B和C。
4. 参数特性:工作电压范围为5-24V,响应频率为50-60Hz,输出电流为10mA。
5. 功能详解:EL817通过光电转换实现信号隔离,提高系统稳定性和抗干扰能力。
6. 应用信息:广泛应用于工业自动化、医疗设备、安防系统等领域。
7. 封装信息:EL817采用DIP6封装,尺寸为9.1x9.1mm。
C13234_SATU-S 价格&库存
很抱歉,暂时无法提供与“C13234_SATU-S”相匹配的价格&库存,您可以联系我们找货
