C13235_SATU-W
C13235_SATU-W
    LEDIL(芬兰)
    Ceramic
C13235_SATU-W 数据手册
PRODUCT DATASHEET C13235_SATU-W SATU-W ~35° wide beam optimized for CREE XT-E TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant Ø 21.8 mm 8.9 mm glue, pin yes MATERIAL SPECIFICATIONS: Component Type Material Colour SATU-W Multi-lens PMMA clear Finish ORDERING INFORMATION: Component C13235_SATU-W » Box size: 480 x 280 x 300 mm Qty in box MOQ MPQ 2880 120 120 Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 7.7 1/8 PRODUCT DATASHEET C13235_SATU-W See also our general installation guide: www.ledil.com/installation_guide Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET C13235_SATU-W PHOTOMETRIC DATA (MEASURED): LED XB-D FWHM / FWTM 31.0° / 60.0° Efficiency 77 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 33.0° / 59.0° Efficiency 84 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 27.0° / 54.0° Efficiency 86 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 34.0° / 63.0° Efficiency 82 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET C13235_SATU-W PHOTOMETRIC DATA (MEASURED): LED XP-G2 FWHM / FWTM 35.0° / 64.0° Efficiency 87 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 37.0° / 66.0° Efficiency 87 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 38.0° / 67.0° Efficiency 86 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED NF2x757A FWHM / FWTM 32.0° / 63.0° Efficiency 80 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET C13235_SATU-W PHOTOMETRIC DATA (MEASURED): LED OSLON Square EC FWHM / FWTM 37.0° / 66.0° Efficiency 85 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 80 FWHM / FWTM 30.0° / 58.0° Efficiency 80 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351Z FWHM / FWTM 36.0° / 64.0° Efficiency 87 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M1/Z5M2 FWHM / FWTM 38.0° / 66.0° Efficiency 92 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET C13235_SATU-W PHOTOMETRIC DATA (SIMULATED): LED J Series 3030 FWHM / FWTM 33.0° / 60.0° Efficiency 96 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 34.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED LUXEON H50-2 FWHM / FWTM 40.0° / 64.0° Efficiency % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 39.0° / 64.0° Efficiency 87 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET C13235_SATU-W PHOTOMETRIC DATA (SIMULATED): LED OSLON Black FWHM / FWTM 27.0° / 51.0° Efficiency 85 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Synios P2720 1/2 mm FWHM / FWTM 30.0° / 58.0° Efficiency 94 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351B FWHM / FWTM 42.0° / 66.0° Efficiency 94 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22P FWHM / FWTM 41.0° / 68.0° Efficiency 87 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET C13235_SATU-W GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 02/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
C13235_SATU-W
物料型号:C13235_SATU-W
器件简介:SATU-W是一款为CREE XT-E优化的宽光束角度(约35°)的多透镜LED光学器件。
引脚分配:文档中未提供引脚分配信息。
参数特性: - 尺寸:直径21.8毫米,高度8.9毫米 - 固定方式:胶粘或插针 - 符合RoHS标准
功能详解:文档提供了不同LED型号的光度数据,包括CREE、LUMILEDS、NICHIA、OSRAM、SAMSUNG和MESOTO等品牌的LED,涉及的参数包括半高全宽角(FWHM/FWTM)、效率、峰值强度等。
应用信息:文档中未明确提供应用信息,但根据光度数据,该产品适用于需要宽光束角度的照明应用。
封装信息:SATU-W的封装材料为PMMA(聚甲基丙烯酸甲酯),订购信息包括每箱数量、最小起订量(MOQ)、中等起订量(MPQ)和每箱重量。
C13235_SATU-W 价格&库存
很抱歉,暂时无法提供与“C13235_SATU-W”相匹配的价格&库存,您可以联系我们找货
