FP11429_LISA2-WWW-PIN
    LEDIL(芬兰)
    LENS ASSY 1POS 9.9MM RND 7MM
FP11429_LISA2-WWW-PIN 数据手册
PRODUCT DATASHEET FP11429_LISA2-WWW-PIN LISA2-WWW-PIN ~80° wide beam. 7.0 mm high variant with location pin installation. TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant Ø 9.9 mm 7 mm glue, pin yes MATERIAL SPECIFICATIONS: Component Type Material Colour LISA2-WWW Single lens PMMA clear LISA2-HLD-PIN Holder PC black Finish ORDERING INFORMATION: Component FP11429_LISA2-WWW-PIN » Box size: Qty in box Single lens 2000 MOQ MPQ 100 Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 1.4 1/9 PRODUCT DATASHEET FP11429_LISA2-WWW-PIN See also our general installation guide: www.ledil.com/installation_guide Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET FP11429_LISA2-WWW-PIN PHOTOMETRIC DATA (MEASURED): LED XB-D FWHM / FWTM 73.0° / 116.0° Efficiency 71 % LEDs/each optic 1 Light colour White Required components: LED XD16 FWHM / FWTM 66.0° / 110.0° Efficiency 66 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 84.0° Efficiency 77 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 86.0° / 126.0° Efficiency 75 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET FP11429_LISA2-WWW-PIN PHOTOMETRIC DATA (MEASURED): LED LUXEON A FWHM / FWTM 86.0° / 122.0° Efficiency 72 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel ES FWHM / FWTM 88.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED LUXEON Z FWHM / FWTM 73.0° / 106.0° Efficiency 75 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 53.0° / 98.0° Efficiency 70 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET FP11429_LISA2-WWW-PIN PHOTOMETRIC DATA (MEASURED): LED SFH 4170S FWHM / FWTM 58.0° / 114.0° Efficiency % LEDs/each optic 1 Light colour IR Required components: LED SFH 4180S FWHM / FWTM 57.0° / 112.0° Efficiency % LEDs/each optic 1 Light colour IR Required components: LED LH181B FWHM / FWTM 62.0° / 104.0° Efficiency 72 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET FP11429_LISA2-WWW-PIN PHOTOMETRIC DATA (SIMULATED): LED XQ-E HD FWHM / FWTM 70.0° / 126.0° Efficiency 81 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON IR 2720 FWHM / FWTM 58.0° / 101.0° Efficiency 76 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour IR Required components: LED LUXEON SunPlus 20 Line (150 deg) FWHM / FWTM 84.0° / 140.0° Efficiency 73 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 80.0° / 130.0° Efficiency 83 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET FP11429_LISA2-WWW-PIN PHOTOMETRIC DATA (SIMULATED): LED SST-20 FWHM / FWTM 73.0° / 122.0° Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW519A FWHM / FWTM 104.0° / 140.0° Efficiency 76 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 120 FWHM / FWTM 86.0° / 123.0° Efficiency 87 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour Amber Required components: LED SFH 4715AS FWHM / FWTM 52.0° / 102.0° Efficiency 88 % LEDs/each optic 1 Light colour IR Required components: Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET FP11429_LISA2-WWW-PIN PHOTOMETRIC DATA (SIMULATED): LED LM301B FWHM / FWTM 80.0° / 122.0° Efficiency 86 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5 FWHM / FWTM 70.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET FP11429_LISA2-WWW-PIN GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 16/08/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
FP11429_LISA2-WWW-PIN 价格&库存
很抱歉,暂时无法提供与“FP11429_LISA2-WWW-PIN”相匹配的价格&库存,您可以联系我们找货
    • 2+17.45880
    • 10+16.76628
    • 20+16.05293
    库存:282
    • 1+19.358071+2.48600
    • 100+15.39846100+1.97750
    • 300+14.60654300+1.87580
    • 500+13.55065500+1.74020
