CA11766_LAURA-WW
CA11766_LAURA-WW
    LEDIL(芬兰)
    LENS ASSY 1POS 21.6MM SQ 13.1MM
CA11766_LAURA-WW 数据手册
PRODUCT DATASHEET Laura series last update 26/11/2013 DETAILS Product Number CA11766_LAURA-WW Family Laura Type Assembly Color black Diameter 21.6 x 21.6 mm Height 13.1 mm Style square Optic Material PMMA Holder Material PC Fastening tape Status ready ROHS Comliant Yes Date Updated 16/10/2014 OPTICAL PROPERTIES Viewing Light Effi- LED Angle Beam ciency cd/lm Connector XT-E 57 deg Very Wide 87 % 0.960 - Z5 62 deg Very Wide - - - XP-G2 64 deg Very Wide 84 % 0.800 - XP-E 66 deg Very Wide 86 % 0.700 - XP-G 68 deg Very Wide 86 % 0.610 - H35C1 (LEMWA33) 68 deg Very Wide 83 % 0.800 - April 28th 2015 15:01 Copyright Ledil Oy - Subject to change without prior notice - Page 1/1 Ledil Oy Salorankatu 10 24240 SALO, Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. GENERAL INFORMATION - Product series especially designed & optimized for series of LEDs. - Special care taken to make light distribution as uniform as possible. - Fastening to heat sink with a PU foam adhesive tape of automotive grade. Please find fastening details by clicking link: http://www.ledil.com/datasheets/DataSheet_TAPE.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the tape. NOTE 2: Assembly to the surface must be made straight, so the tape bonds constant and balanced with fastening surface. Slanted assembly might cause unbalanced bond to the surface. All surfaces where tape is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer - this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling.
CA11766_LAURA-WW 价格&库存
很抱歉,暂时无法提供与“CA11766_LAURA-WW”相匹配的价格&库存,您可以联系我们找货
CA11766_LAURA-WW
  • 180+13.80840180+1.73160
  • 360+13.54286360+1.69830
