CA11960_LAURA-D-PIN
CA11960_LAURA-D-PIN
    LEDIL(芬兰)
CA11960_LAURA-D-PIN 数据手册
PRODUCT DATASHEET CA11960_LAURA-D-PIN LAURA-D-PIN ~15° diffused spot beam optimized for CREE XP-E. Assembly with white holder, installation tape and location pins. TECHNICAL SPECIFICATIONS: Dimensions 21.6 x 21.6 mm Height 13.1 mm Fastening tape, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour LAURA-D Single lens PMMA clear LAURA-PIN-XP-HLD-WHT Holder PC white ROSE-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA11960_LAURA-D-PIN » Box size: Qty in box Single lens 1440 MOQ MPQ 180 Box weight (kg) 7.5 Last update: 24/01/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/10 PRODUCT DATASHEET CA11960_LAURA-D-PIN See also our general installation guide: www.ledil.com/installation_guide Last update: 24/01/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET CA11960_LAURA-D-PIN PHOTOMETRIC DATA (MEASURED): LED XP-E FWHM / FWTM 13.0° / 31.0° Efficiency 93 % Peak intensity 9.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E-HEW FWHM / FWTM 15.0° / 33.0° Efficiency 86 % Peak intensity 6.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 15.0° / 36.0° Efficiency 88 % Peak intensity 6.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 16.0° Efficiency 94 % LEDs/each optic 1 Light colour White Required components: Last update: 24/01/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET CA11960_LAURA-D-PIN PHOTOMETRIC DATA (MEASURED): LED LUXEON Rebel FWHM / FWTM 15.0° / 37.0° Efficiency 90 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 18.0° / 40.0° Efficiency 89 % Peak intensity 4.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Z ES FWHM / FWTM 15.0° / 34.0° Efficiency 90 % Peak intensity 7.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19B FWHM / FWTM 19.0° / 41.0° Efficiency 85 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 24/01/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET CA11960_LAURA-D-PIN PHOTOMETRIC DATA (MEASURED): LED NF2x757D FWHM / FWTM 19.0° / 43.0° Efficiency 84 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 16.0° / 34.0° Efficiency 81 % Peak intensity 6.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 150 FWHM / FWTM 12.0° / 28.0° Efficiency 83 % Peak intensity 8.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 80 FWHM / FWTM 14.0° / 31.0° Efficiency 83 % Peak intensity 7.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 24/01/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET CA11960_LAURA-D-PIN PHOTOMETRIC DATA (MEASURED): LED SFH 4725S FWHM / FWTM 18.0° / 42.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED Z5 FWHM / FWTM 14.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 24/01/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET CA11960_LAURA-D-PIN PHOTOMETRIC DATA (SIMULATED): LED XD16 FWHM / FWTM 12.0° / 23.0° Efficiency 90 % Peak intensity 16.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 12.0° / 22.0° Efficiency 94 % Peak intensity 18 cd/lm LEDs/each optic 1 Light colour Amber Required components: LED XP-G3 FWHM / FWTM 17.0° / 32.0° Efficiency 93 % Peak intensity 8.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON H50-2 FWHM / FWTM 13.0° / 28.0° Efficiency 90 % Peak intensity 9.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 24/01/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET CA11960_LAURA-D-PIN PHOTOMETRIC DATA (SIMULATED): LED LUXEON IR Domed 150 FWHM / FWTM 9.0° / 18.0° Efficiency 0% LEDs/each optic 1 Light colour White Required components: LED LUXEON IR Domed 60 FWHM / FWTM 12.0° / 25.0° Efficiency 94 % LEDs/each optic 1 Light colour White Required components: LED LUXEON IR Domed 90 FWHM / FWTM 12.0° / 24.0° Efficiency 94 % LEDs/each optic 1 Light colour White Required components: LED NV4WB35AM FWHM / FWTM 16.0° / 32.0° Efficiency 96 % Peak intensity 8.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 24/01/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET CA11960_LAURA-D-PIN PHOTOMETRIC DATA (SIMULATED): LED KW CULPM1.TG FWHM / FWTM 10.0° / 20.0° Efficiency 96 % Peak intensity 21.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Signal FWHM / FWTM 10.0° / 20.0° Efficiency 96 % Peak intensity 23.8 cd/lm LEDs/each optic 1 Light colour Red Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 12.0° / 24.0° Efficiency 96 % Peak intensity 15.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4715S FWHM / FWTM 13.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 24/01/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET CA11960_LAURA-D-PIN GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 24/01/2022 Subject to change without prior notice Published: 11/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
CA11960_LAURA-D-PIN 价格&库存
很抱歉,暂时无法提供与“CA11960_LAURA-D-PIN”相匹配的价格&库存,您可以联系我们找货
