FA11027_TINA-WW
FA11027_TINA-WW
    LEDIL(芬兰)
FA11027_TINA-WW 数据手册
PRODUCT DATASHEET FA11027_TINA-WW TINA-WW ~60° wide beam. Assembly with installation tape and location pins. holder, TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant Ø 16.1 mm 9.5 mm pin, tape yes MATERIAL SPECIFICATIONS: Component Type Material Colour TINA-WW-XP Single lens PMMA clear TINA-HLD-PIN-BLK Holder PC black TINA-TAPE3 Tape Acrylic foam black Finish ORDERING INFORMATION: Component FA11027_TINA-WW » Box size: Single lens Qty in box MOQ MPQ 2016 288 144 Box weight (kg) 4.0 Last update: 08/06/2022 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/7 PRODUCT DATASHEET FA11027_TINA-WW See also our general installation guide: www.ledil.com/installation_guide Last update: 08/06/2022 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/7 PRODUCT DATASHEET FA11027_TINA-WW PHOTOMETRIC DATA (MEASURED): LED LUXEON C FWHM / FWTM 35.0° / 81.0° Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW3x9A FWHM / FWTM 59.0° / 92.0° Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 80 FWHM / FWTM 57.0° / 90.0° Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4715S FWHM / FWTM 36.0° / 80.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 08/06/2022 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/7 PRODUCT DATASHEET FA11027_TINA-WW PHOTOMETRIC DATA (MEASURED): LED SFH 4725S FWHM / FWTM 35.0° / 82.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 08/06/2022 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/7 PRODUCT DATASHEET FA11027_TINA-WW PHOTOMETRIC DATA (SIMULATED): LED LUXEON Z ES FWHM / FWTM 48.0° / 84.0° Efficiency 95 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxE17A FWHM / FWTM 27.0° / 76.0° Efficiency 90 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 50.0° Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED SYNIOS S2222 FWHM / FWTM 46.0 + 47.0° / 84.0° Efficiency 98 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/06/2022 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/7 PRODUCT DATASHEET FA11027_TINA-WW PHOTOMETRIC DATA (SIMULATED): LED LH181B FWHM / FWTM 40.1° / 81.3° Efficiency 94 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 08/06/2022 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/7 PRODUCT DATASHEET FA11027_TINA-WW GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/06/2022 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/7
FA11027_TINA-WW
物料型号:FA11027_TINA-WW
器件简介:这是一个LEDiL品牌的光学器件,具有约60°的宽光束角度,带有安装支架、安装胶带和定位销。产品符合RoHS标准。
引脚分配:文档中没有提供具体的引脚分配信息,但提到了使用定位销进行固定。
参数特性: - 尺寸:直径16.1mm,高度9.5mm - 材料:镜头为PMMA,支架为PC,胶带为丙烯酸泡沫 - 颜色:透明,支架为黑色,胶带为黑色
功能详解:文档提供了不同LED制造商的光度数据,包括LUMILEDS、NICHIA、OSRAM和SAMSUNG的LED产品,包括它们的FWHM(全宽半高)、FWTM(全宽十分之一高)、效率、峰值强度等参数。
应用信息:文档提到了产品的一般安装指南,可以通过访问www.ledil.com/installation_guide获取更多信息。
封装信息:产品包含单个镜头、支架和胶带,每个盒子包含2016个单位,最小起订量为288个单位。
FA11027_TINA-WW 价格&库存
很抱歉,暂时无法提供与“FA11027_TINA-WW”相匹配的价格&库存,您可以联系我们找货
FA11027_TINA-WW
  • 144+19.28870144+2.49327
