FA11902_TINA3-W
FA11902_TINA3-W
    LEDIL(芬兰)
FA11902_TINA3-W 数据手册
PRODUCT DATASHEET FA11902_TINA3-W TINA3-W ~40° wide beam optimized for CREE XP-E. Assembly with holder, installation tape and location pins. TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant Ø 16.1 mm 7.3 mm tape, pin yes MATERIAL SPECIFICATIONS: Component Type Material Colour TINA3-W Single lens PMMA clear TINA3-HLD-PIN-TAPE-XP Holder PC white TINA-TAPE3 Tape Acrylic foam black Finish ORDERING INFORMATION: Component FA11902_TINA3-W » Box size: 470 x 240 x 105 mm Single lens Qty in box MOQ MPQ 2016 288 288 Box weight (kg) 3.5 Last update: 15/05/2018 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/8 PRODUCT DATASHEET FA11902_TINA3-W See also our general installation guide: www.ledil.com/installation_guide Last update: 15/05/2018 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET FA11902_TINA3-W PHOTOMETRIC DATA (MEASURED): LED XM-L FWHM / FWTM 43.0° / 82.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L2 FWHM / FWTM 38.0° / 70.0° Efficiency 91 % LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 32.0° / 58.0° Efficiency 89 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM 34.0° / 68.0° Efficiency 89 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET FA11902_TINA3-W PHOTOMETRIC DATA (MEASURED): LED XP-L HI FWHM / FWTM 31.0° / 57.0° Efficiency 91 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 30.0° / 57.0° Efficiency 92 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NS9x383 FWHM / FWTM 48.0° / 85.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSU333A FWHM / FWTM 30.0° / 60.0° Efficiency 94 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET FA11902_TINA3-W PHOTOMETRIC DATA (SIMULATED): LED XD16 FWHM / FWTM 52.0° / 86.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 4 Light colour White Required components: LED XHP35 HD FWHM / FWTM 38.0° / 89.0° Efficiency 90 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35.2 HD FWHM / FWTM 46.0° / 89.0° Efficiency 86 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L HVW FWHM / FWTM 50.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET FA11902_TINA3-W PHOTOMETRIC DATA (SIMULATED): LED XP-E2 FWHM / FWTM 22.0° / 50.0° Efficiency 96 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 33.0° / 77.0° Efficiency 90 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW3x9A FWHM / FWTM 40.0° / 70.0° Efficiency 91 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Signal FWHM / FWTM 24.0° / 52.0° Efficiency 90 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour Blue Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET FA11902_TINA3-W PHOTOMETRIC DATA (SIMULATED): LED OSLON SSL 80 FWHM / FWTM 30.0° / 57.0° Efficiency 94 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 80 FWHM / FWTM 31.0° / 56.0° Efficiency 90 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour Far Red Required components: Last update: 15/05/2018 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET FA11902_TINA3-W GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 15/05/2018 Subject to change without prior notice Published: 16/11/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
FA11902_TINA3-W 价格&库存
很抱歉,暂时无法提供与“FA11902_TINA3-W”相匹配的价格&库存,您可以联系我们找货
FA11902_TINA3-W
  • 1+16.46975
  • 288+13.13987
  • 864+12.45712
  • 1440+11.57075
FA11902_TINA3-W
  • 1+35.981041+4.65093
FA11902_TINA3-W
  • 1+16.784701+2.16960
  • 288+13.37531288+1.72890
  • 864+12.67595864+1.63850
  • 1440+11.801741440+1.52550
