CA12838_FLARE-MINI-A-PIN
    LEDIL(芬兰)
CA12838_FLARE-MINI-A-PIN 数据手册
PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN FLARE-MINI-A-PIN ~100° x 20° oval beam. Assembly with location pins and installation tape. TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant Ø 16.0 mm 9.1 mm tape, pin yes MATERIAL SPECIFICATIONS: Component Type Material Colour FLARE-MINI-A-PIN Single lens PMMA clear TINA-TAPE3 Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA12838_FLARE-MINI-A-PIN » Box size: 460 x 250 x 300 mm Single lens Qty in box MOQ MPQ 4600 230 230 Box weight (kg) 7.4 Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN See also our general installation guide: www.ledil.com/installation_guide Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN PHOTOMETRIC DATA (MEASURED): LED XB-D FWHM / FWTM 130.0 + 21.0° / 119.0 + 172.0° Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 113.0 + 20.0° / 122.0 + 171.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 93.0 + 14.0° / 150.0 + 24.0° Efficiency 94 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 114.0 + 22.0° / 120.0 + 158.0° Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN PHOTOMETRIC DATA (MEASURED): LED XP-G2 FWHM / FWTM 94.0 + 19.0° / 152.0 + 31.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM 109.0 + 26.0° / 152.0 + 43.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L2 FWHM / FWTM 100.0 + 28.0° / 153.0 + 49.0° Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 124.0 + 22.0° / 119.0 + 173.0° Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN PHOTOMETRIC DATA (MEASURED): LED LUXEON CZ FWHM / FWTM 105.0 + 9.0° / 145.0 + 16.0° Efficiency 94 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 95.0 + 19.0° / 30.0 + 148.0° Efficiency 93 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 93.0 + 19.0° / 145.0 + 31.0° Efficiency 94 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19A FWHM / FWTM 112.0 + 20.0° / 104.0 + 167.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN PHOTOMETRIC DATA (MEASURED): LED NCSxx19B FWHM / FWTM 95.0 + 15.0° / 151.0 + 27.0° Efficiency 94 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 99.0 + 21.0° / 149.0 + 35.0° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 101.0 + 20.0° / 145.0 + 32.0° Efficiency 94 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square PC FWHM / FWTM 116.0 + 22.0° / 114.0 + 172.0° Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN PHOTOMETRIC DATA (MEASURED): LED OSLON SSL 150 FWHM / FWTM 106.0 + 11.0° / 22.0 + 152.0° Efficiency 93 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 80 FWHM / FWTM 84.0 + 12.0° / 23.0 + 144.0° Efficiency 93 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351Z FWHM / FWTM 95.0 + 19.0° / 133.0 + 31.0° Efficiency 94 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M3 FWHM / FWTM 102.0 + 20.0° / 149.0 + 37.0° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN PHOTOMETRIC DATA (MEASURED): LED Z8Y22P FWHM / FWTM 115.0 + 21.0° / 154.0 + 34.0° Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN PHOTOMETRIC DATA (SIMULATED): LED XP-G3 FWHM / FWTM 93.0 + 20.0° / 150.0 + 37.0° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HD FWHM / FWTM 78.0 + 11.0° / 131.0 + 21.0° Efficiency 95 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON C FWHM / FWTM 11.0 + 84.0° / 21.0 + 168.0° Efficiency 92 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON CZ FWHM / FWTM 75.0 + 10.0° / 139.0 + 19.0° Efficiency 95 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour Red Required components: Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN PHOTOMETRIC DATA (SIMULATED): LED LUXEON H50-2 FWHM / FWTM 18.0 + 86.0° / 31.0 + 137.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rubix FWHM / FWTM 79.0 + 10.0° / 142.0 + 18.0° Efficiency 96 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour Green Required components: LED LUXEON Rubix FWHM / FWTM 76.0 + 10.0° / 140.0 + 18.0° Efficiency 96 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour Red Required components: LED LUXEON Rubix FWHM / FWTM 79.0 + 10.0° / 143.0 + 18.0° Efficiency 96 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN PHOTOMETRIC DATA (SIMULATED): LED LUXEON Rubix FWHM / FWTM 80.0 + 10.0° / 142.0 + 18.0° Efficiency 96 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour Blue Required components: LED LUXEON Z ES FWHM / FWTM 84.0 + 13.0° / 141.0 + 22.0° Efficiency 95 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxE17A FWHM / FWTM 79.0 + 12.0° / 140.0 + 22.0° Efficiency 95 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 91.0 + 16.0° / 143.0 + 27.0° Efficiency 94 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN PHOTOMETRIC DATA (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 89.0 + 18.0° / 145.0 + 31.0° Efficiency 94 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M1/Z5M2 FWHM / FWTM 91.0 + 20.0° / 141.0 + 30.0° Efficiency 95 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/13 PRODUCT DATASHEET CA12838_FLARE-MINI-A-PIN GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 05/10/2022 Subject to change without prior notice Published: 13/09/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/13
物料型号:CA12838_FLARE-MINI-A-PIN 器件简介:这是一个椭圆形光束角度约为100° x 20°的LED光学器件,装配有定位销和安装胶带。
引脚分配:装配方式包括胶带和销钉。
参数特性:尺寸为16.0毫米x 9.1毫米,符合ROHS标准。
功能详解:提供不同LED型号的光度数据,如CREE、LUMILEDS、NICHIA和OSRAM等,包括光束角度、效率、峰值强度等。
应用信息:适用于需要特定光束角度和光效的应用场合。
封装信息:单个透镜组件,材料为PMMA,颜色为透明,胶带为丙烯酸泡沫黑色。
以上信息摘自LEDiL公司提供的PDF数据手册。
CA12838_FLARE-MINI-A-PIN 价格&库存
很抱歉,暂时无法提供与“CA12838_FLARE-MINI-A-PIN”相匹配的价格&库存,您可以联系我们找货
  • 230+19.57394230+2.53014
  • 230+8.07317
  • 460+7.27065
库存:4600
    • 2+21.96279
    • 50+21.08282
    • 230+20.19243
    库存:237
