C13237_HB-2X2-WW-BLIND
    LEDIL(芬兰)
    LENS ARRAY SQUARE 4 POS 50X50MM
C13237_HB-2X2-WW-BLIND 数据手册
PRODUCT DATASHEET C13237_HB-2X2-WW-BLIND HB-2X2-WW-BLIND ~65° wide beam without centre screw hole for easier potting TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant 50.0 x 50.0 mm 8.5 mm glue, pin yes MATERIAL SPECIFICATIONS: Component Type Material Colour HB-2X2-WW-BLIND Multi-lens PMMA clear Finish ORDERING INFORMATION: Component C13237_HB-2X2-WW-BLIND » Box size: 480 x 280 x 300 mm Qty in box 800 MOQ MPQ 160 160 Box weight (kg) 9.4 Last update: 14/12/2019 Subject to change without prior notice Published: 11/06/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/8 PRODUCT DATASHEET C13237_HB-2X2-WW-BLIND See also our general installation guide: www.ledil.com/installation_guide Last update: 14/12/2019 Subject to change without prior notice Published: 11/06/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET C13237_HB-2X2-WW-BLIND PHOTOMETRIC DATA (MEASURED): LED XP-G FWHM / FWTM 69.0° / 92.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM 69.0° / 92.0° Efficiency 91 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 65.0° / 89.0° Efficiency 91 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Q FWHM / FWTM 67.0° / 92.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/12/2019 Subject to change without prior notice Published: 11/06/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET C13237_HB-2X2-WW-BLIND PHOTOMETRIC DATA (MEASURED): LED LUXEON Z ES FWHM / FWTM 59.0° / 87.0° Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 67.0° / 92.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square PC FWHM / FWTM 65.0° / 89.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351Z FWHM / FWTM 63.0° / 89.0° Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/12/2019 Subject to change without prior notice Published: 11/06/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET C13237_HB-2X2-WW-BLIND PHOTOMETRIC DATA (MEASURED): LED Z5M1/Z5M2 FWHM / FWTM 65.0° / 90.0° Efficiency 90 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED TL1L4 FWHM / FWTM 60.0° / 87.0° Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE G1 49x121mm 2000lm xxx EXC OTD FWHM / FWTM 67.0° / 93.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE G1 49x133mm 2000lm xxx EXC OTD FWHM / FWTM 67.0° / 93.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/12/2019 Subject to change without prior notice Published: 11/06/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET C13237_HB-2X2-WW-BLIND PHOTOMETRIC DATA (MEASURED): LED RLE G1 49x223mm 4000lm xxx EXC OTD FWHM / FWTM 67.0° / 93.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE G1 49x245mm 4000lm xxx EXC OTD FWHM / FWTM 67.0° / 93.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/12/2019 Subject to change without prior notice Published: 11/06/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET C13237_HB-2X2-WW-BLIND PHOTOMETRIC DATA (SIMULATED): LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 69.0° / 85.0° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 14/12/2019 Subject to change without prior notice Published: 11/06/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET C13237_HB-2X2-WW-BLIND GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 14/12/2019 Subject to change without prior notice Published: 11/06/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
C13237_HB-2X2-WW-BLIND 价格&库存
很抱歉,暂时无法提供与“C13237_HB-2X2-WW-BLIND”相匹配的价格&库存,您可以联系我们找货
