PRODUCT
DATASHEET
C13233_HB-2X2-M
HB-2X2-M
~25° medium beam
TECHNICAL SPECIFICATIONS:
Dimensions
Height
Fastening
ROHS compliant
50.0 x 50.0 mm
8.5 mm
glue, pin, screw
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
HB-2X2-M
Multi-lens
PMMA
clear
Finish
ORDERING INFORMATION:
Component
C13233_HB-2X2-M
» Box size: 480 x 280 x 300 mm
Qty in box
800
MOQ
MPQ
160
160
Box weight (kg)
9.2
Last update: 04/08/2022
Subject to change without prior notice
Published: 11/06/2020
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
See also our general installation guide: www.ledil.com/installation_guide
2/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
PHOTOMETRIC DATA (MEASURED):
LED
QUICK FLUX XTP 2x4 xxx LS G5
FWHM / FWTM
28.0° / 52.0°
Efficiency
94 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
QUICK FLUX XTP 2x6 xxx LS G5
FWHM / FWTM
29.0° / 52.0°
Efficiency
94 %
Peak intensity
3 cd/lm
LEDs/each optic
1
Light colour
White
LED
XB-D
FWHM / FWTM
26.0° / 47.0°
Efficiency
94 %
Peak intensity
3.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G
FWHM / FWTM
31.0° / 54.0°
Efficiency
91 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
3/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
LED
XP-G2
FWHM / FWTM
33.0° / 54.0°
Efficiency
93 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
XT-E
FWHM / FWTM
25.0° / 46.0°
Efficiency
92 %
Peak intensity
3.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Q
FWHM / FWTM
26.0° / 49.0°
Efficiency
94 %
Peak intensity
3.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Z ES
FWHM / FWTM
21.0° / 42.0°
Efficiency
91 %
Peak intensity
5.6 cd/lm
LEDs/each optic
1
Light colour
White
4/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
LED
NVSxE21A
FWHM / FWTM
20.0° / 40.0°
Efficiency
94 %
Peak intensity
5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19B/NVSxx19C
FWHM / FWTM
29.0° / 53.0°
Efficiency
90 %
Peak intensity
3 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19B/NVSxx19C
FWHM / FWTM
29.0° / 52.0°
Efficiency
91 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
PrevaLED Brick HP 2x8
FWHM / FWTM
30.0° / 51.0°
Efficiency
93 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
5/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
LED
OSLON Square CSSRM2/CSSRM3
FWHM / FWTM
30.0° / 51.0°
Efficiency
93 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square PC
FWHM / FWTM
30.0° / 54.0°
Efficiency
91 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351B
FWHM / FWTM
31.0° / 53.0°
Efficiency
94 %
Peak intensity
2.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351Z
FWHM / FWTM
32.0° / 52.0°
Efficiency
93 %
Peak intensity
2.9 cd/lm
LEDs/each optic
1
Light colour
White
6/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
LED
Z8Y15
FWHM / FWTM
20.0° / 41.0°
Efficiency
89 %
Peak intensity
4.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z8Y19
FWHM / FWTM
22.0° / 46.0°
Efficiency
89 %
Peak intensity
3.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z8Y22
FWHM / FWTM
24.0° / 53.0°
Efficiency
94 %
Peak intensity
3 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z8Y22P
FWHM / FWTM
28.0° / 56.0°
Efficiency
94 %
Peak intensity
2.9 cd/lm
LEDs/each optic
1
Light colour
White
7/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
LED
TL1L4
FWHM / FWTM
25.0° / 46.0°
Efficiency
85 %
Peak intensity
3.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
RLE 2x4 2000lm HP EXC2 OTD
FWHM / FWTM
29.0° / 50.0°
Efficiency
93 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
RLE G1 49x121mm 2000lm xxx EXC OTD
FWHM / FWTM
29.0° / 53.0°
Efficiency
94 %
Peak intensity
3 cd/lm
LEDs/each optic
1
Light colour
White
LED
RLE G1 49x133mm 2000lm xxx EXC OTD
FWHM / FWTM
29.0° / 53.0°
Efficiency
94 %
Peak intensity
3 cd/lm
LEDs/each optic
1
Light colour
White
8/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
LED
RLE G1 49x223mm 4000lm xxx EXC OTD
FWHM / FWTM
29.0° / 53.0°
Efficiency
94 %
Peak intensity
3 cd/lm
LEDs/each optic
1
Light colour
White
LED
RLE G1 49x245mm 4000lm xxx EXC OTD
FWHM / FWTM
29.0° / 53.0°
Efficiency
94 %
Peak intensity
3 cd/lm
LEDs/each optic
1
Light colour
White
9/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
PHOTOMETRIC DATA (SIMULATED):
LED
XD16
FWHM / FWTM
28.0° / 48.0°
Efficiency
95 %
Peak intensity
3.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G2
FWHM / FWTM
32.0° / 52.0°
Efficiency
93 %
Peak intensity
3 cd/lm
LEDs/each optic
1
Light colour
White
Protective plate, glass
LED
XQ-E HI
FWHM / FWTM
22.0° / 42.0°
Efficiency
93 %
Peak intensity
5.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON 3030 2D (Round LES)
FWHM / FWTM
28.0° / 49.0°
Efficiency
94 %
Peak intensity
3.6 cd/lm
LEDs/each optic
1
Light colour
White
10/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
LED
LUXEON C
FWHM / FWTM
25.0° / 45.0°
Efficiency
94 %
Peak intensity
4.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSCONIQ C 2424
FWHM / FWTM
26.0° / 43.0°
Efficiency
96 %
Peak intensity
4.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
FWHM / FWTM
36.0° / 56.0°
Efficiency
87 %
Peak intensity
2.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 80
FWHM / FWTM
29.6° / 48.1°
Efficiency
94 %
Peak intensity
3.5 cd/lm
LEDs/each optic
1
Light colour
White
11/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
LED
LH231B
FWHM / FWTM
28.0° / 50.0°
Efficiency
94 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z8Y22T
FWHM / FWTM
28.0° / 51.0°
Efficiency
94 %
Peak intensity
3.4 cd/lm
LEDs/each optic
1
Light colour
White
12/13
PRODUCT
DATASHEET
C13233_HB-2X2-M
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
13/13
很抱歉,暂时无法提供与“C13233_HB-2X2-M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+20.35062
- 10+18.29041
- 28+16.24217
- 56+14.18195
- 国内价格 香港价格
- 160+22.56902160+2.93291
- 国内价格 香港价格
- 1+21.825661+2.83630
- 10+19.6517910+2.55380
- 28+17.4779228+2.27130
- 56+15.2171056+1.97750
