CP12860_EVA-O
CP12860_EVA-O
    LEDIL(芬兰)
    ASSY 1POS 37.7MM RND OD 17MM
CP12860_EVA-O 数据手册
PRODUCT DATASHEET Eva series last update 31/7/2012 Ordering number CP12196_EVA-S Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Assembly XM-L Black 37.7 mm 17 mm Round PMMA PC Screw, glue Ready FWHM Efficiency cd/lm Gerber File 13 degrees 94 % Available FWHM Efficiency cd/lm Gerber File 15.5+39 degrees 86 % 3.300 Available FWHM Efficiency cd/lm Gerber File 15.5+39 degrees 86 % 3.300 Available FWHM Efficiency cd/lm Gerber File 20 degrees 91 % Available Ordering number CA12859_EVA-O Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Assembly XM-L Black 37.7 mm 17.2 mm Round PMMA PC Tape Ready Ordering number CP12860_EVA-O Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Assembly XM-L Black 37.7 mm 17 mm Round PMMA PC Screw Ready Ordering number CP12197_EVA-D Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Assembly XM-L Black 37.7 mm 17 mm Round PMMA PC Screw, glue Ready November 12th 2012 23:09 Copyright Ledil Oy - Subject to change without prior notice - Page 1/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Eva series last update 31/7/2012 Ordering number CP12198_EVA-M Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Assembly XM-L Black 37.7 mm 17 mm Round PMMA PC Screw, glue Ready FWHM Efficiency cd/lm Gerber File 24 degrees 88 % Available FWHM Efficiency cd/lm Gerber File 40 degrees 79 % Available FWHM Efficiency cd/lm Gerber File 64 degrees 77 % Available Ordering number CP12199_EVA-W Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Assembly XM-L Black 37.7 mm 17 mm Round PMMA PC Screw, glue Ready Ordering number CP12200_EVA-WW Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Eva Assembly XM-L Black 37.7 mm 17 mm Round PMMA PC Screw, glue Ready NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. November 12th 2012 23:09 Copyright Ledil Oy - Subject to change without prior notice - Page 2/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Eva series last update 31/7/2012 GENERAL INFORMATION - Product series especially designed & optimized for XM-L series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220 degrees of Fahrenheit). Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf - Optic holder molded by high quality PC material (120 dergees of Celcius / 248 degrees of Fahrenheit). - Fastening to heat sink with a PU foam adhesive tape of automotive grade. Please find fastening details by clicking link: http://www.ledil.com/datasheets/DataSheet_TAPE.pdf - Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue options. http://www.ledil.com/datasheets/DataSheet_GLUES.pdf NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the tape. NOTE 2: Assembly to the surface must be made straight, so the tape bonds constant and balanced with fastening surface. Slanted assembly might cause unbalanced bond to the surface. All surfaces where tape is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer - this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end product. For example, mechanical stress, vibration and holes on the surface of the circuit boar weaken the strength of the glue. NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other electronics components on the PCB. Further note that optical components shall not be cleaned with any chemicals - only micro fiber cloth may be used to remove fingerprints or other traces from handling. November 12th 2012 23:09 Copyright Ledil Oy - Subject to change without prior notice - Page 3/3 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001
CP12860_EVA-O 价格&库存
很抱歉,暂时无法提供与“CP12860_EVA-O”相匹配的价格&库存,您可以联系我们找货
