CA11819_STRADA-SQ-T-DW
    LEDIL(芬兰)
    LENS ASSY 1POS 25MM SQ 10.82MM
CA11819_STRADA-SQ-T-DW 数据手册
PRODUCT DATASHEET Strada-SQ series last update 26/8/2014 Product number C11818_STRADA-SQ-T-DW Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Lens XP-E Clear 25 + 25 mm 10.67 mm Square PMMA Screw, glue On production Product number CA11819_STRADA-SQ-T-DW Family Type LED Color Diameter Height Style Optic Material Holder Material Fastening Status Strada-SQ Assembly XP-E Clear 25 + 25 mm 10.82 mm Square PMMA Screw, tape On production FWHM Efficiency cd/lm Gerber File Asymmetric degrees 90 % (simulated) 0.000 Available FWHM Efficiency cd/lm Gerber File Asymmetric degrees 90 % (simulated) 0.000 Available NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value. April 28th 2015 13:41 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 PRODUCT DATASHEET Strada-SQ series last update 26/8/2014 GENERAL INFORMATION - Product series especially designed & optimized for XP-E series of LEDs. - Special care taken to make light distribution as uniform as possible. - Lens material optical grade PMMA with high UV and temperature resistance. Allows use of high current and temperature conditions. Please find more information about used material from below: http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf April 28th 2015 13:41 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001
CA11819_STRADA-SQ-T-DW 价格&库存
很抱歉,暂时无法提供与“CA11819_STRADA-SQ-T-DW”相匹配的价格&库存,您可以联系我们找货
