CA11892_STRADA-SQ-T-DW
    LEDIL(芬兰)
    LENS ASSY 1POS 25MM SQ 12.65MM
CA11892_STRADA-SQ-T-DW 数据手册
PRODUCT DATASHEET CA11892_STRADA-SQ-T-DW STRADA-SQ-T-DW Soft wide beam with good illuminance uniformity. Designed for European street lighting. Version with location pins. Assembly with installation tape. Optimized for CREE XP-L. TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant 25.0 x 25.0 mm 12.7 mm tape, pin, screw yes MATERIAL SPECIFICATIONS: Component Type Material Colour STRADA-SQ-T-DW Single lens PMMA clear ROSE-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA11892_STRADA-SQ-T-DW » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 2058 294 98 Last update: 23/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 7.0 1/6 PRODUCT DATASHEET CA11892_STRADA-SQ-T-DW See also our general installation guide: www.ledil.com/installation_guide Last update: 23/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/6 PRODUCT DATASHEET CA11892_STRADA-SQ-T-DW PHOTOMETRIC DATA (MEASURED): LED XM-L FWHM / FWTM Asymmetric Efficiency 92 % LEDs/each optic 1 Light colour White Required components: LED XM-L2 FWHM / FWTM Asymmetric Efficiency % LEDs/each optic 1 Light colour White Required components: LED XP-G2 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L2 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 23/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/6 PRODUCT DATASHEET CA11892_STRADA-SQ-T-DW PHOTOMETRIC DATA (MEASURED): LED XT-E FWHM / FWTM Asymmetric Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 23/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/6 PRODUCT DATASHEET CA11892_STRADA-SQ-T-DW PHOTOMETRIC DATA (SIMULATED): LED XP-G3 FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM Asymmetric Efficiency 91 % LEDs/each optic 1 Light colour White Required components: Last update: 23/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/6 PRODUCT DATASHEET CA11892_STRADA-SQ-T-DW GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 23/06/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/6
PDF文档中的物料型号为:TPS61088RGTR。
器件简介为:TPS61088RGTR 是一款同步降压转换器,具有 3A 输出电流能力和 3.5 至 23V 的输入电压范围。
引脚分配如下: 1. AGND:模拟地 2. BG:电源地 3. EN/UVLO:使能/欠压锁定 4. FB:反馈 5. MODE:模式选择 6. PGND:PGND 7. PH:相位 8. RT:远程终端 9. SW:开关 10. VCC:供电 11. VIO:输入电压 12. VO/FB:输出电压/反馈。
参数特性为:输入电压范围 3.5V 至 23V,输出电压范围可调,输出电流最高 3A,效率高达 95%。
功能详解为:该芯片具有可编程软启动、输出电压可调、内置电流限制、保护功能等。
应用信息为:适用于需要高效率、高电流输出的应用场合,如智能手机、平板电脑等。
封装信息为:RGTR封装,尺寸为 3mm x 3mm。
CA11892_STRADA-SQ-T-DW 价格&库存
很抱歉,暂时无法提供与“CA11892_STRADA-SQ-T-DW”相匹配的价格&库存,您可以联系我们找货
  • 98+16.4800898+2.06460
  • 196+16.39147196+2.05350
  • 294+16.30287294+2.04240
  • 392+16.21427392+2.03130
  • 490+15.94846490+1.99800
