CA14219_STRADA-SQ-CY
    LEDIL(芬兰)
CA14219_STRADA-SQ-CY 数据手册
PRODUCT DATASHEET CA14219_STRADA-SQ-CY STRADA-SQ-CY Beam for canopy lighting with batwing light distribution. Suitable for symmetrical tunnel lighting. Version with location pins. Assembly with installation tape. TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant 25.0 x 25.0 mm 10.1 mm tape, pin, screw yes MATERIAL SPECIFICATIONS: Component Type Material Colour STRADA-SQ-CY Single lens PMMA clear ROSE-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component CA14219_STRADA-SQ-CY » Box size: 480 x 280 x 300 mm Qty in box Single lens 2058 MOQ MPQ 98 Last update: 28/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 7.8 1/9 PRODUCT DATASHEET CA14219_STRADA-SQ-CY See also our general installation guide: www.ledil.com/installation_guide Last update: 28/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET CA14219_STRADA-SQ-CY PHOTOMETRIC DATA (MEASURED): LED MHD-E/G FWHM / FWTM 117.0 + 115.0° / 138.0 + 133.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED MK-R FWHM / FWTM 118.0 + 115.0° / 274.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50 FWHM / FWTM 122.0 + 118.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50 FWHM / FWTM 115.0 + 113.0° / 132.0 + 131.0° Efficiency 90 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 28/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET CA14219_STRADA-SQ-CY PHOTOMETRIC DATA (MEASURED): LED XHP70 FWHM / FWTM 121.0 + 119.0° / 144.0 + 143.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L FWHM / FWTM 122.0 + 116.0° / 270.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM 118.0 + 127.0° / 136.0 + 148.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L2 FWHM / FWTM 118.0 + 115.0° / 136.0 + 133.0° Efficiency 90 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 28/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET CA14219_STRADA-SQ-CY PHOTOMETRIC DATA (MEASURED): LED LUXEON M/MX FWHM / FWTM 120.0 + 115.0° / 271.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON MZ FWHM / FWTM 127.0 + 118.0° / 144.0 + 137.0° Efficiency 94 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON XR-M Linear (L2M0-xxxx003MC3300) FWHM / FWTM 118.0 + 115.0° / 135.0 + 130.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW319B FWHM / FWTM 125.0 + 117.0° / 141.0 + 131.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 28/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET CA14219_STRADA-SQ-CY PHOTOMETRIC DATA (MEASURED): LED NVSxx19B/NVSxx19C FWHM / FWTM 124.0 + 115.0° / 141.0 + 128.0° Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S10 FWHM / FWTM 116.0 + 113.0° / 132.0 + 128.0° Efficiency 93 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM 112.0° / 126.0° Efficiency 93 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH508A FWHM / FWTM 114.0 + 113.0° / 127.0° Efficiency 79 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 28/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET CA14219_STRADA-SQ-CY PHOTOMETRIC DATA (SIMULATED): LED J Series 2835 FWHM / FWTM 113.0° / 136.0° Efficiency 98 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED MHB-A/B FWHM / FWTM 112.0° / 138.0° Efficiency 98 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.2 FWHM / FWTM 101.0 + 107.0° / 122.0 + 125.0° Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 97.0 + 106.0° / 118.0 + 123.0° Efficiency 88 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour White Required components: Protective plate, glass Last update: 28/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET CA14219_STRADA-SQ-CY PHOTOMETRIC DATA (SIMULATED): LED OSCONIQ P 7070 FWHM / FWTM 115.0° / 130.0° Efficiency 92 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 28/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET CA14219_STRADA-SQ-CY GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 28/09/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-40至85摄氏度,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装。
CA14219_STRADA-SQ-CY 价格&库存
很抱歉,暂时无法提供与“CA14219_STRADA-SQ-CY”相匹配的价格&库存,您可以联系我们找货
