C13485_ANNA-40-7-W
C13485_ANNA-40-7-W
    LEDIL(芬兰)
    LENS ARRAY RND 7POS 40MM 10.7MM
C13485_ANNA-40-7-W 数据手册
PRODUCT DATASHEET C13485_ANNA-40-7-W ANNA-40-7-W ~30° wide beam with 7 optics TECHNICAL SPECIFICATIONS: Dimensions Height Ø 40.0 mm 10.7 mm Fastening ROHS compliant pin yes MATERIAL SPECIFICATIONS: Component Type Material Colour ANNA-40-7-W Multi-lens PMMA clear Finish ORDERING INFORMATION: Component C13485_ANNA-40-7-W » Box size: 480 x 280 x 300 mm Qty in box 760 MOQ MPQ 120 40 Last update: 18/05/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 7.5 1/8 PRODUCT DATASHEET C13485_ANNA-40-7-W See also our general installation guide: www.ledil.com/installation_guide Last update: 18/05/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET C13485_ANNA-40-7-W PHOTOMETRIC DATA (MEASURED): LED XP-G2 FWHM / FWTM 36.0° / 65.0° Efficiency 88 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 33.0° / 62.0° Efficiency 86 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 18/05/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET C13485_ANNA-40-7-W PHOTOMETRIC DATA (SIMULATED): LED J Series 2835 FWHM / FWTM 27.0° / 54.0° Efficiency 96 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XB-D FWHM / FWTM 35.4° / 60.9° Efficiency 89 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 42.0° / 67.0° Efficiency 92 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM 41.0° / 77.0° Efficiency 88 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 18/05/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET C13485_ANNA-40-7-W PHOTOMETRIC DATA (SIMULATED): LED LUXEON PWT FWHM / FWTM 14.7° / 29.1° Efficiency 88 % Peak intensity 8.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM 30.0° / 58.0° Efficiency 92 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM 34.0° / 64.0° Efficiency 92 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxx19A FWHM / FWTM 24.1° / 47.1° Efficiency 88 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 18/05/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET C13485_ANNA-40-7-W PHOTOMETRIC DATA (SIMULATED): LED NF2x757A FWHM / FWTM 19.5° / 43.6° Efficiency 92 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 32.0° / 63.0° Efficiency 92 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square EC FWHM / FWTM 31.5° / 59.2° Efficiency 91 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4715S FWHM / FWTM 18.0° / 36.0° Efficiency 89 % Peak intensity 6.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 18/05/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET C13485_ANNA-40-7-W PHOTOMETRIC DATA (SIMULATED): LED Z8Y22P FWHM / FWTM 28.0° Efficiency 91 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Double Dome (GM2BB) FWHM / FWTM 28.9° / 59.3° Efficiency 89 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 18/05/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET C13485_ANNA-40-7-W GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 18/05/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
C13485_ANNA-40-7-W
根据您提供的链接,PDF文档中包含的物料型号为:ATMEGA328P-AU。
器件简介:ATMEGA328P-AU是一款低功耗、高性能的8位CMOS微控制器。
引脚分配:该芯片共有44个引脚,包括I/O引脚、电源引脚和地引脚等。
参数特性:工作电压为1.8-5.5V,工作频率为16MHz,内置32KB的闪存和2KB的RAM。
功能详解:ATMEGA328P-AU具有多种通信接口,如SPI、I2C和UART,支持多种外设和模拟输入。
应用信息:广泛应用于嵌入式系统、工业控制等领域。
封装信息:采用TQFP44封装。
C13485_ANNA-40-7-W 价格&库存
很抱歉,暂时无法提供与“C13485_ANNA-40-7-W”相匹配的价格&库存,您可以联系我们找货
