C11679_ANNA-50-7-M
C11679_ANNA-50-7-M
    LEDIL(芬兰)
    LENS 7POS 50MM ROUND OD 10.7MM
C11679_ANNA-50-7-M 数据手册
PRODUCT DATASHEET C11679_ANNA-50-7-M ANNA-50-7-M ~20° medium beam with 7 optics TECHNICAL SPECIFICATIONS: Dimensions Ø 50.0 mm Height 10.7 mm Fastening glue, pin ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour ANNA-50-7-M Multi-lens PMMA clear Finish ORDERING INFORMATION: Component C11679_ANNA-50-7-M » Box size: 480 x 280 x 300 mm Qty in box 512 MOQ MPQ 96 32 Last update: 27/10/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 7.1 1/7 PRODUCT DATASHEET C11679_ANNA-50-7-M See also our general installation guide: www.ledil.com/installation_guide Last update: 27/10/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/7 PRODUCT DATASHEET C11679_ANNA-50-7-M PHOTOMETRIC DATA (MEASURED): LED XB-D FWHM / FWTM 22.0° Efficiency 87 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON A FWHM / FWTM 26.0° / 55.0° Efficiency 84 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel FWHM / FWTM 18.0° / 38.0° Efficiency 87 % Peak intensity 5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel ES FWHM / FWTM 27.0° / 56.0° Efficiency 87 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 27/10/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/7 PRODUCT DATASHEET C11679_ANNA-50-7-M PHOTOMETRIC DATA (MEASURED): LED NCSxx19A FWHM / FWTM 23.0° / 50.0° Efficiency 89 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED NF2x757A FWHM / FWTM 20.0° / 43.0° Efficiency 90 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19A FWHM / FWTM 25.0° / 54.0° Efficiency 89 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON SSL 150 FWHM / FWTM 22.0° / 42.0° Efficiency 89 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 27/10/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/7 PRODUCT DATASHEET C11679_ANNA-50-7-M PHOTOMETRIC DATA (MEASURED): LED OSLON SSL 80 FWHM / FWTM 20.0° / 44.0° Efficiency 88 % Peak intensity 4.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 27/10/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/7 PRODUCT DATASHEET C11679_ANNA-50-7-M PHOTOMETRIC DATA (SIMULATED): LED NVSxx19B/NVSxx19C FWHM / FWTM 25.0° / 44.0° Efficiency 95 % Peak intensity 4.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5 FWHM / FWTM 23.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED Double Dome (GM2BB) FWHM / FWTM 24.0° Efficiency % LEDs/each optic 1 Light colour White Required components: Last update: 27/10/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/7 PRODUCT DATASHEET C11679_ANNA-50-7-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 27/10/2019 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/7
C11679_ANNA-50-7-M 价格&库存
很抱歉,暂时无法提供与“C11679_ANNA-50-7-M”相匹配的价格&库存,您可以联系我们找货
C11679_ANNA-50-7-M
  • 2+38.74468
  • 8+37.89075
  • 16+37.07326
库存:180
C11679_ANNA-50-7-M
  • 32+24.48606
  • 64+23.87477
  • 128+23.50716
库存:180
C11679_ANNA-50-7-M
  • 32+21.1551832+2.65290
  • 64+20.9781564+2.63070
  • 96+20.8011296+2.60850
  • 160+20.71261160+2.59740
  • 320+20.35854320+2.55300
