PRODUCT DATASHEET
Flare series
last update 20/9/2012
Ordering number C12868_FLARE-MAXI
Family
Type
LED
Color
Diameter
Height
Style
Optic Material
Holder Material
Fastening
Status
Flare
Lens
LUXEON M
Clear
33.9 + 33.3 mm
16.7 mm
Rectangular
PMMA
Pin, glue
Ready
FWHM
Efficiency
cd/lm
Gerber File
100+23 degrees
94 %
1.400
Available
NOTE: The typical divergence will be changed by different color, chip size and chip position
tolerance. The typical total divergence is the full angle measured where the luminous intensity
is half of the peak value.
November 12th 2012 21:01 Copyright Ledil Oy - Subject to change without prior notice - Page 1/2
Ledil Oy
Salorankatu 10
24240 SALO
Finland
http://www.ledil.com
email: ledil@ledil.com
FAX: +358-2-733 8001
PRODUCT DATASHEET
Flare series
GENERAL INFORMATION
- Product series especially designed & optimized for LUXEON M series of LEDs.
- Special care taken to make light distribution as uniform as possible.
- Lens material optical grade PMMA with high UV and temperature resistance (105 degrees of Celcius / 220
degrees of Fahrenheit). Allows use of high current and temperature conditions.
Please find more information about used material from below:
http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20UL94_Yellow%20Card.pdf
http://ledil.fi/sites/default/files/Documents/Technical/Material/PMMA%208N%20PLEXIGLAS-Datasheet.pdf
- Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue
options.
http://www.ledil.com/datasheets/DataSheet_GLUES.pdf
NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end
product. For example, mechanical stress, vibration and holes on the surface of the circuit boar
weaken the strength of the glue.
NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If
cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED
manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other
electronics components on the PCB.
Further note that optical components shall not be cleaned with any chemicals - only micro fiber
cloth may be used to remove fingerprints or other traces from handling.
November 12th 2012 21:01 Copyright Ledil Oy - Subject to change without prior notice - Page 2/2
Ledil Oy
Salorankatu 10
24240 SALO
Finland
A
B
4
21.52
4
( 10.8 )
( 8.4 )
Detail A
Scale: 2:1
c/c
C
D
2
3
33.3
1.2
3
16.7
A
2
2
33.9
Material: PMMA
Tolerances for dimensions:
0-20mm tolerance value +-0.1mm
21-45mm tolerance value +-0.2mm
46-90mm tolerance value +-0.3mm
91-100mm tolerance value +-0.4mm
101-mm tolerance value +-0.5mm
1
This drawing is our property.
It can't be reproduced
or communicated without
our written agreement.
DRAWN BY
DATE
CHECKED BY
DATE
DESIGNED BY
DATE
pv
sn
hh
D
Ledil Oy
Salorankatu 10
FIN 24240 SALO
Finland
DRAWING TITLE
Datasheet FLARE-MAXI Lens
18.4.2012
17.4.2012
6.4.2012
SIZE
DRAWING NUMBER
A4
SCALE
1:1 WEIGHT(g)
C12868
REV
1
SHEET
A
1/1
1
很抱歉,暂时无法提供与“C12868_FLARE-MAXI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 168+25.34865
- 336+24.71579
- 672+24.33507
- 国内价格
- 2+44.21382
- 42+43.52527
- 84+42.58358
- 国内价格
- 1+34.23312
- 5+24.90226
- 12+23.54875
