CA14366_FLARE-MAXI-TAPE 数据手册
PRODUCT
DATASHEET
FLARE-MAXI-TAPE
34 x 33 mm lens with ~100° x 15° oval beam.
Assembly with installation tape.
TECHNICAL SPECIFICATIONS:
Dimensions
33.9 x 33.3 mm
Height
16.9 mm
Fastening
tape, pin
ROHS compliant
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
FLARE-MAXI
Single lens
PMMA
clear
FLARE-MAXI-TAPE
Tape
Acrylic foam
clear
Finish
ORDERING INFORMATION:
Component
» Box size:
Qty in box
Single lens
864
MOQ
MPQ
144
72
Box weight (kg)
9.7
Last update: 17/08/2022
Subject to change without prior notice
Published: 13/09/2019
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
1/13
PRODUCT
DATASHEET
See also our general installation guide: www.ledil.com/installation_guide
2/13
PRODUCT
DATASHEET
PHOTOMETRIC DATA (MEASURED):
LED
XM-L
FWHM / FWTM
96.0 + 15.0° / 175.0°
Efficiency
94 %
Peak intensity
2.1 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
XM-L2
FWHM / FWTM
105.0 + 13.0°
Efficiency
96 %
LEDs/each optic
1
Light colour
White
LED
XP-G
FWHM / FWTM
105.0 + 11.0° / 174.0°
Efficiency
94 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G2
FWHM / FWTM
96.0 + 10.0° / 162.0°
Efficiency
94 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
3/13
PRODUCT
DATASHEET
LED
XP-L HD
FWHM / FWTM
115.0 + 13.0° / 149.0 + 19.0°
Efficiency
94 %
Peak intensity
2.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-L2
FWHM / FWTM
99.0 + 13.0° / 158.0 + 21.0°
Efficiency
94 %
Peak intensity
2 cd/lm
LEDs/each optic
1
Light colour
White
LED
XT-E
FWHM / FWTM
96.0 + 10.0° / 183.0°
Efficiency
94 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Rebel ES
FWHM / FWTM
91.0 + 10.0° / 164.0°
Efficiency
94 %
Peak intensity
2.8 cd/lm
LEDs/each optic
1
Light colour
White
4/13
PRODUCT
DATASHEET
LED
LUXEON T
FWHM / FWTM
96.0 + 10.0° / 262.0°
Efficiency
92 %
Peak intensity
2.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON TX
FWHM / FWTM
96.0 + 9.0° / 141.0°
Efficiency
94 %
Peak intensity
3.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
NCSxx19B
FWHM / FWTM
98.0 + 9.0° / 170.0°
Efficiency
94 %
Peak intensity
3.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19B/NVSxx19C
FWHM / FWTM
98.0 + 11.0° / 176.0°
Efficiency
94 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
5/13
PRODUCT
DATASHEET
LED
OSLON Square PC
FWHM / FWTM
98.0 + 13.0° / 178.0°
Efficiency
94 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351Z
FWHM / FWTM
94.0 + 8.8° / 125.0 + 13.0°
Efficiency
94 %
Peak intensity
3.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
WICOP 5050
FWHM / FWTM
112.0 + 17.0° / 158.0 + 27.0°
Efficiency
93 %
Peak intensity
1.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z5M3
FWHM / FWTM
97.0 + 10.0° / 154.0 + 17.0°
Efficiency
94 %
Peak intensity
2.6 cd/lm
LEDs/each optic
1
Light colour
White
6/13
PRODUCT
DATASHEET
LED
Z8Y22P
FWHM / FWTM
104.0 + 10.0° / 160.0 + 17.0°
Efficiency
93 %
Peak intensity
2.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z8Y50P
FWHM / FWTM
105.0 + 21.0° / 155.0 + 29.0°
Efficiency
93 %
Peak intensity
1.3 cd/lm
LEDs/each optic
1
Light colour
White
7/13
PRODUCT
DATASHEET
PHOTOMETRIC DATA (SIMULATED):
LED
XD16
FWHM / FWTM
62.0 + 8.0° / 146.0 + 15.0°
Efficiency
94 %
Peak intensity
3.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
XHP35 HD
FWHM / FWTM
89.0 + 14.0° / 139.0 + 20.0°
Efficiency
91 %
Peak intensity
2.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
XHP35 HI
FWHM / FWTM
82.0 + 10.0° / 136.0 + 15.0°
Efficiency
93 %
Peak intensity
3.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-E2
FWHM / FWTM
6.0 + 41.0° / 13.0 + 109.0°
Efficiency
94 %
Peak intensity
5.6 cd/lm
LEDs/each optic
1
Light colour
White
8/13
PRODUCT
DATASHEET
LED
LUXEON CZ
FWHM / FWTM
4.0 + 34.0° / 10.0 + 107.0°
Efficiency
95 %
Peak intensity
7.1 cd/lm
LEDs/each optic
1
Light colour
Red
LED
LUXEON H50-2
FWHM / FWTM
9.5 + 64.0° / 137.0°
Efficiency
92 %
Peak intensity
3.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Rubix
FWHM / FWTM
40.0 + 4.0° / 117.0 + 10.0°
Efficiency
96 %
Peak intensity
6.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Rubix
FWHM / FWTM
39.0 + 4.0° / 114.0 + 10.0°
Efficiency
96 %
Peak intensity
7 cd/lm
LEDs/each optic
1
Light colour
Red
9/13
PRODUCT
DATASHEET
LED
LUXEON Rubix
FWHM / FWTM
41.0 + 4.0° / 118.0 + 10.0°
Efficiency
96 %
Peak intensity
6.6 cd/lm
LEDs/each optic
1
Light colour
Green
LED
LUXEON Rubix
FWHM / FWTM
Efficiency
96 %
Peak intensity
6.7 cd/lm
LEDs/each optic
1
Light colour
Blue
LED
SFT-40-WCS
FWHM / FWTM
61.0 + 8.0° / 129.0 + 14.0°
Efficiency
96 %
Peak intensity
4.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
SFT-70X-WCS
FWHM / FWTM
72.0 + 10.0° / 132.0 + 16.0°
Efficiency
96 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
10/13
PRODUCT
DATASHEET
LED
NCSxE17A
FWHM / FWTM
90.0 + 9.0° / 150.0 + 18.0°
Efficiency
94 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square EC
FWHM / FWTM
8.0 + 53.0° / 116.0 + 15.0°
Efficiency
94 %
Peak intensity
4 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 150
FWHM / FWTM
6.0 + 58.0° / 12.0 + 131.0°
Efficiency
94 %
Peak intensity
4.7 cd/lm
LEDs/each optic
1
Light colour
Red
LED
LH351B
FWHM / FWTM
67.0 + 10.0° / 126.0 + 17.0°
Efficiency
94 %
Peak intensity
3.1 cd/lm
LEDs/each optic
1
Light colour
White
11/13
PRODUCT
DATASHEET
LED
LH351C
FWHM / FWTM
71.0 + 11.0° / 126.0 + 18.0°
Efficiency
94 %
Peak intensity
3 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z5M1/Z5M2
FWHM / FWTM
67.0 + 8.0° / 127.0 + 14.0°
Efficiency
94 %
Peak intensity
3.6 cd/lm
LEDs/each optic
1
Light colour
White
12/13
PRODUCT
DATASHEET
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
13/13
CA14366_FLARE-MAXI-TAPE 价格&库存
很抱歉,暂时无法提供与“CA14366_FLARE-MAXI-TAPE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 72+42.9520672+5.57300
