CN10953_IRIS-M
CN10953_IRIS-M
    LEDIL(芬兰)
CN10953_IRIS-M 数据手册
PRODUCT DATASHEET IRIS-M IRIS-M ~25° medium beam with sublens and holder TECHNICAL SPECIFICATIONS: Dimensions Ø 38.0 mm Height 30 mm Fastening glue, screw ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour C10781_IRIS Single lens PMMA clear C10860_IRIS-HLD Holder PC black C10333_LEDILSTAR-SUB Sublens PC Finish ORDERING INFORMATION: Quantities for one set: Single lens 1 Holder 1 Sublens 1 Last update: 26/04/2022 Subject to change without prior notice Published: 08/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/9 PRODUCT DATASHEET IRIS-M Component Qty in box MOQ MPQ Box weight (kg) C10781_IRIS » Box size: 480 x 280 x 300 mm Single lens 580 116 58 9.0 C10860_IRIS-HLD » Box size: 480 x 280 x 300 mm Holder 1044 116 29 7.2 C10333_LEDILSTAR-SUB » Box size: 300 x 250 x 250 mm Sublens 2500 90 4 4.5 Last update: 26/04/2022 Subject to change without prior notice Published: 08/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET IRIS-M See also our general installation guide: www.ledil.com/installation_guide Last update: 26/04/2022 Subject to change without prior notice Published: 08/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET IRIS-M PHOTOMETRIC DATA (MEASURED): LED MC-E FWHM / FWTM 28.0° / 48.0° Efficiency 81 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED MHD-E/G FWHM / FWTM 30.0° / 58.0° Efficiency 93 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50 FWHM / FWTM 30.0° / 60.0° Efficiency 75 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.2 FWHM / FWTM 29.0° / 53.0° Efficiency 77 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 26/04/2022 Subject to change without prior notice Published: 08/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET IRIS-M PHOTOMETRIC DATA (MEASURED): LED Duris S10 FWHM / FWTM 30.0° / 56.0° Efficiency 75 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 26/04/2022 Subject to change without prior notice Published: 08/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET IRIS-M PHOTOMETRIC DATA (SIMULATED): LED XD16 FWHM / FWTM 12.0° / 24.0° Efficiency 76 % Peak intensity 13.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HD FWHM / FWTM 14.0° / 28.0° Efficiency 84 % Peak intensity 10.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HI FWHM / FWTM 13.0° / 24.0° Efficiency 84 % Peak intensity 13.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.3 HD FWHM / FWTM 15.0 + 16.0° / 28.0° Efficiency 80 % Peak intensity 9.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 26/04/2022 Subject to change without prior notice Published: 08/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET IRIS-M PHOTOMETRIC DATA (SIMULATED): LED XP-E2 FWHM / FWTM 12.0° / 22.0° Efficiency 83 % Peak intensity 15.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 16.0° / 28.0° Efficiency 83 % Peak intensity 9.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 7070 FWHM / FWTM 20.0° / 38.0° Efficiency 80 % Peak intensity 5.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 18.0° / 32.0° Efficiency 82 % Peak intensity 7.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 26/04/2022 Subject to change without prior notice Published: 08/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET IRIS-M PHOTOMETRIC DATA (SIMULATED): LED OSLON Square Flat FWHM / FWTM 15.0° / 30.0° Efficiency 80 % Peak intensity 8.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 26/04/2022 Subject to change without prior notice Published: 08/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET IRIS-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 26/04/2022 Subject to change without prior notice Published: 08/07/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
CN10953_IRIS-M 价格&库存
很抱歉,暂时无法提供与“CN10953_IRIS-M”相匹配的价格&库存,您可以联系我们找货
