FCA12104_IRIS
FCA12104_IRIS
    LEDIL(芬兰)
    Lens with Holder Clear 9° Spot Cree XM-L
FCA12104_IRIS 数据手册
PRODUCT DATASHEET FCA12104_IRIS IRIS ~5° real spot beam optimized for CREE XM-L. Assembly with holder and installation tape. TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant Ø 38.0 mm 27.7 mm tape, pin, screw yes MATERIAL SPECIFICATIONS: Component Type Material Colour IRIS Single lens PMMA clear IRIS-XM-HLD Holder PC black SPUTNIK-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component FCA12104_IRIS » Box size: 480 x 280 x 300 mm Qty in box Single lens 378 MOQ MPQ 126 42 Last update: 11/10/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 9.0 1/8 PRODUCT DATASHEET FCA12104_IRIS See also our general installation guide: www.ledil.com/installation_guide Last update: 11/10/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/8 PRODUCT DATASHEET FCA12104_IRIS PHOTOMETRIC DATA (MEASURED): LED XHP35 HD FWHM / FWTM 10.0° / 22.0° Efficiency 91 % Peak intensity 17.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HI FWHM / FWTM 7.0° / 16.0° Efficiency 93 % Peak intensity 33.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.2 FWHM / FWTM 12.0° / 30.0° Efficiency 88 % Peak intensity 9.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L FWHM / FWTM 9.0° / 19.0° Efficiency 91 % Peak intensity 19.2 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 11/10/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/8 PRODUCT DATASHEET FCA12104_IRIS PHOTOMETRIC DATA (MEASURED): LED XM-L2 FWHM / FWTM 10.0° / 23.0° Efficiency 86 % Peak intensity 18.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4x144A FWHM / FWTM 13.0° / 31.0° Efficiency 89 % Peak intensity 9.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW3x9A FWHM / FWTM 7.0° / 17.0° Efficiency 85 % Peak intensity 25.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (2W version) FWHM / FWTM 5.0° / 14.0° Efficiency 91 % Peak intensity 38.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 11/10/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/8 PRODUCT DATASHEET FCA12104_IRIS PHOTOMETRIC DATA (SIMULATED): LED XD16 FWHM / FWTM 6.0° / 14.0° Efficiency 91 % Peak intensity 47.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35.2 HD FWHM / FWTM 8.0° / 20.0° Efficiency 85 % Peak intensity 21.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.3 HD FWHM / FWTM 13.0° / 28.0° Efficiency 89 % Peak intensity 10.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.3 HI FWHM / FWTM 10.0° / 22.0° Efficiency 96 % Peak intensity 17 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 11/10/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/8 PRODUCT DATASHEET FCA12104_IRIS PHOTOMETRIC DATA (SIMULATED): LED XP-L HD FWHM / FWTM 8.8° / 19.0° Efficiency 93 % Peak intensity 24.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Round LES FWHM / FWTM 10.0° / 27.0° Efficiency 92 % Peak intensity 13.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFT-40-WCS FWHM / FWTM 6.0° / 14.0° Efficiency 94 % Peak intensity 46.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFT-70X-WCS FWHM / FWTM 8.0° / 18.0° Efficiency 94 % Peak intensity 29.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 11/10/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/8 PRODUCT DATASHEET FCA12104_IRIS PHOTOMETRIC DATA (SIMULATED): LED SST-70X-WCS FWHM / FWTM 10.0° / 24.0° Efficiency 92 % Peak intensity 15.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM 12.0° / 30.0° Efficiency 92 % Peak intensity 10.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 11/10/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/8 PRODUCT DATASHEET FCA12104_IRIS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 11/10/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/8
FCA12104_IRIS 价格&库存
很抱歉,暂时无法提供与“FCA12104_IRIS”相匹配的价格&库存,您可以联系我们找货
