High Efficiency TIR Lenses for LZP Emitter Family
LLNF-3T11-H
LLFL-3T11-H
Key Features
Total Internal Reflection (TIR) optics provides a well-controlled beam
Designed specifically for LED Engin LZP emitter family
Maximum Lux on TargetTM and lumens in beam
Provides the highest quality and quantity of light in a beam
Smooth light gradient eliminates hot spots and rings and minimizes glare for superior illumination
UL-rated optical grade PMMA lens material allows use of high current and temperature conditions
Lenses are available standard with holder that mount easily onto LuxiGen LZP MCPCBs
Simple fastening of holder to MCPCB with appropriate adhesive, e.g. epoxy or polyurethane based
Typical Applications
Down lighting
Architectural lighting
Entertainment
Stage and Studio lighting
Accent lighting
Description
This lens family couples with the compact, high-flux density LZP LuxiGen emitter family providing a range of beam
options and opening up new applications in stage and studio, architectural and down lighting. The TIR lens
collimates the LED light into efficient, well-controlled light beams that maximize the usable lumens in the target
area. Not only does this lighting solution provide the throw or distance required for these lighting applications, it
does so with a smooth, high quality beam of superior intensity uniformity, color over angle mixing, and with an
absence of discomfort glare or shadows. With its performance and compact footprint, the LZP emitter-lens
combination offers a compact replacement solution for 35W Metal Halide lamps.
Optical Specification
degrees
Optical
efficiency 4
On-axis
intensity 5
cd/lm
85
3.8
32
69
85
1.5
Beam angle 2
Field angle 3
degrees
LLNF-3T11-H
LLFL-3T11-H
Part number 1
Notes:
1.
Lenses can also be ordered without the holder. Replace –H with –O for this option.
2.
Beam angle is defined as the full width at 50% of the max intensity (FWHM).
3.
Field angle is defined as the full width at 10% of the max intensity.
4.
Optical efficiency is defined as the ratio between the incoming flux and the outgoing flux.
5.
On-axis intensity is defined as the ratio between the total input lumen and the intensity in the optical center of the lens.
COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED.
LLNF-3T11-H, LLFL-3T11-H (1.1 – 03/29/2018)
LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | fax +1 408 922 0158 | em sales@ledengin.com | www.ledengin.com
Typical Relative Intensity over Angle
100%
90%
80%
LLNF-3T11-H
Relative Intensity
70%
LLFL-3T11-H
60%
50%
40%
30%
20%
10%
0%
-90 -80 -70 -60 -50 -40 -30 -20 -10 0 10 20
Angle (degrees)
30
40
50
60
70
80
90
General Characteristics
Symbol
Value
Rating
Unit
Height from Seating Plane
32.2
Typical
mm
Diameter
72.8
Typical
mm
Mechanical
Material
Lens
PMMA
Holder
Polycarbonate
Optical
1
Transmission (>90%)
λ
410-1100
Min-Max.
nm
Storage Temperature
Tstg
-40 ~ +110
Min-Max.
°C
Operating Temperature
Tsol
-40 ~ +110
Min-Max.
°C
Environmental
Notes:
1.
It is not recommended to use a UV emitter with this lens due to lower transmission at wavelengths < 410nm.
2
Mechanical dimensions
Lens with Holder
3
Assembly Instruction
Lens holders can be assembled to the PCB using an epoxy or polyurethane-based adhesive (example: Dow Corning
3145 RTV).
Cyanoacrylate (superglue) adhesive should not be used to avoid contamination of the lens (blooming of the
epoxy).
When integrating the lens into a fixture without the lens holder, special attention is needed to maintain the
distance between the lens bottom and the emitter top. Variation in this distance will result in variation of the
beam profile.
Lens Cleaning
Use a lint-free soft cloth to dust off the lens. For deeper cleaning a solution of neutral detergent (example:
dishwashing soap) can be used. Do not use any solvents or abrasive liquid/fabric.
4
About LED Engin
LED Engin, an OSRAM business based in California’s Silicon Valley, develops, manufactures, and sells advanced LED
emitters, optics and light engines to create uncompromised lighting experiences for a wide range of
entertainment, architectural, general lighting and specialty applications. LuxiGenTM multi-die emitter and
secondary lens combinations reliably deliver industry-leading flux density, upwards of 5000 quality lumens to a
target, in a wide spectrum of colors including whites, tunable whites, multi-color and UV LEDs in a unique patented
compact ceramic package. Our LuxiTuneTM series of tunable white lighting modules leverage our LuxiGen emitters
and lenses to deliver quality, control, freedom and high density tunable white light solutions for a broad range of
new recessed and downlighting applications. The small size, yet remarkably powerful beam output and superior insource color mixing, allows for a previously unobtainable freedom of design wherever high-flux density, directional
light is required. LED Engin is committed to providing products that conserve natural resources and reduce
greenhouse emissions; and reserves the right to make changes to improve performance without notice.
For more information, please contact sales@ledengin.com or +1 408 922-7200.
5
很抱歉,暂时无法提供与“LLFL-3T11-H”相匹配的价格&库存,您可以联系我们找货
