CS14055_STRADA-IP-2X6-T2
    LEDIL(芬兰)
CS14055_STRADA-IP-2X6-T2 数据手册
PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 STRADA-IP-2X6-T2 IESNA Type II (medium) beam applicable for European P-class standard pedestrian lighting and M-class roads TECHNICAL SPECIFICATIONS: Dimensions Height Fastening 71.4 x 173.0 mm 9.2 mm screw Ingress protection classes ROHS compliant IP67 yes MATERIAL SPECIFICATIONS: Component Type Material Colour STRADA-IP-2X6-T2 Multi-lens PMMA clear 2X6-SEAL25 Seal Silicone white Finish ORDERING INFORMATION: Component CS14055_STRADA-IP-2X6-T2 » Box size: 476 x 273 x 247 mm Qty in box Multi-lens 120 MOQ MPQ 40 40 Box weight (kg) 8.1 Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 See also our general installation guide: www.ledil.com/installation_guide Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (MEASURED): LED Bridgelux SMD 5050 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED QUICK FLUX 2x6 LED XG xxx G7+ FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED QUICK FLUX 2x6 LED XT xxx G5 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (MEASURED): LED XP-G2 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L2 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (MEASURED): LED XP-L2 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E HE FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED EHP-2x6-IP-3535 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (MEASURED): LED EHP-2x6-IP-5050 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON R FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel ES FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON T FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (MEASURED): LED LUXEON V FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON V2 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON XR-TX (L2T0-xxyy012M) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Z ES FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (MEASURED): LED RecLED 146x45mm 2900lm 730 STRADA-IP-2x6 G1 FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW319B FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW3x9A FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (MEASURED): LED NVSW519A FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square PC FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo FastFlex LED 2x6 DP G4 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo FastFlex LED 2x6 DP G5 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (MEASURED): LED HiLOM RH12 (LH351C) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED HiLOM RM12 ZP (LH502C) FWHM / FWTM Asymmetric Efficiency 95 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351Z FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED BALAM-VP-5250-750-36 FWHM / FWTM Asymmetric Efficiency 96 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (MEASURED): LED ROY-S26XPL2 (XP-L2) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XLE-S22C4XTEHE (XT-E HE) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XLE-S26XHP35 (XHP35 HD) FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED 2x6 5050 module - SMJD-3625012F-XX FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (MEASURED): LED SMJQ-D36W12Mx FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED SMJQ-D36W12Px FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M3 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (MEASURED): LED Z8Y22P FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED TL1L4 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED RLE 2x6 3000lm HP EXC2 OTD FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (SIMULATED): LED J Series 5050 Square LES 6V FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HD FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HI FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 HE FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (SIMULATED): LED LUXEON 5050 Round LES FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 5050 Square LES FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON TX FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED NF3W585AR FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (SIMULATED): LED NV4WB35AM FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219D FWHM / FWTM Asymmetric Efficiency 94 % LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (SIMULATED): LED PrevaLED Brick HP IP 2x6 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Duris S8 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (2W version) FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (3W version) FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (SIMULATED): LED OSCONIQ P 3737 (3W version) FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED Fortimo FastFlex LED 2x6 DPX G4 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351C FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (SIMULATED): LED LH351D FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH502D FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Acrich MJT 4040 FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED SEOUL DC 3030C FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (SIMULATED): LED SEOUL DC 5050 6V FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M FWHM / FWTM Asymmetric Efficiency 89 % LEDs/each optic 1 Light colour White Required components: LED Z5M1/Z5M2 FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5M4 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 PHOTOMETRIC DATA (SIMULATED): LED TL1L2 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED TL1L3 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/22 PRODUCT DATASHEET CS14055_STRADA-IP-2X6-T2 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 15/08/2022 Subject to change without prior notice Published: 24/05/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/22
物料型号(Product Datasheet): - 型号名称:CS14055_STRADA-IP-2X6-T2 - 尺寸:71.4 x 173.0 mm,高度9.2 mm - 固定方式:螺丝 - 防护等级:IP67 - 符合ROHS标准
器件简介(Technical Specifications): - 适用于欧洲P类标准行人照明和M类道路的IESNA II型(中等)光束
引脚分配(Ordering Information): - 组件:S14055_STRADA-IP-2X6-T2,多透镜 - 每箱数量:120 - 最小起订量(MOQ)和最大包装量(MPQ):40 - 箱重:8.1 kg
参数特性(Photometric Data Measured/Simulated): - 包括不同LED制造商的LED芯片,例如Bridgelux、CREE、LUMILEDS、NICHIA、OSRAM、PHILIPS、SAMSUNG等 - 光效:94%至96%不等 - 峰值强度:从0.6 cd/lm到1.6 cd/lm不等 - 色温:白色 - 所有测量数据都是基于特定LED芯片的,具有不同的FWHM(半高宽)和FWTM(半宽高)
功能详解(General Information): - 光束角度会因颜色、芯片尺寸和芯片位置公差而变化 - LEDiL保留随时更改材料等级的权利,以确保产品质量和可用性
应用信息(Materials): - LEDiL保留不经通知更改其产品的权利
封装信息(Product Data User Agreement and Disclaimer): - 提供的测量数据仅供参考,LEDiL不保证数据的完整性和正确性,且不承担由此造成的责任 - 用户同意免责声明,并在使用提供的文件时接受用户协议
CS14055_STRADA-IP-2X6-T2 价格&库存
很抱歉,暂时无法提供与“CS14055_STRADA-IP-2X6-T2”相匹配的价格&库存,您可以联系我们找货
    • 40+72.8098140+9.43142
