PRODUCT
DATASHEET
C12607_VIRPI-S
VIRPI-S
~15° spot beam
TECHNICAL SPECIFICATIONS:
Dimensions
Height
Fastening
ROHS compliant
74.9 x 74.9 mm
9.5 mm
glue, pin
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
VIRPI-S
Multi-lens
PMMA
clear
Finish
ORDERING INFORMATION:
Component
C12607_VIRPI-S
» Box size: 480 x 280 x 300 mm
Qty in box
360
MOQ
MPQ
45
15
Last update: 10/10/2022
Subject to change without prior notice
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
Box weight (kg)
12.0
1/13
PRODUCT
DATASHEET
C12607_VIRPI-S
See also our general installation guide: www.ledil.com/installation_guide
2/13
PRODUCT
DATASHEET
C12607_VIRPI-S
PHOTOMETRIC DATA (MEASURED):
LED
XB-D
FWHM / FWTM
13.0° / 30.0°
Efficiency
92 %
Peak intensity
9.2 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
XP-E2
FWHM / FWTM
11.0° / 27.0°
Efficiency
94 %
Peak intensity
12.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G
FWHM / FWTM
16.0° / 36.0°
Efficiency
94 %
Peak intensity
6.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G2
FWHM / FWTM
16.0° / 34.0°
Efficiency
94 %
Peak intensity
7.3 cd/lm
LEDs/each optic
1
Light colour
White
3/13
PRODUCT
DATASHEET
C12607_VIRPI-S
LED
XT-E
FWHM / FWTM
15.0° / 34.0°
Efficiency
94 %
Peak intensity
7.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Rebel ES
FWHM / FWTM
16.0° / 29.0°
Efficiency
94 %
Peak intensity
6.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19A
FWHM / FWTM
16.0° / 34.0°
Efficiency
93 %
Peak intensity
6.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square EC
FWHM / FWTM
15.0° / 31.0°
Efficiency
94 %
Peak intensity
8.6 cd/lm
LEDs/each optic
1
Light colour
White
4/13
PRODUCT
DATASHEET
C12607_VIRPI-S
PHOTOMETRIC DATA (SIMULATED):
LED
J Series 3030
FWHM / FWTM
14.0° / 28.0°
Efficiency
95 %
Peak intensity
11.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
XD16
FWHM / FWTM
14.0° / 30.0°
Efficiency
94 %
Peak intensity
9.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON C
FWHM / FWTM
11.0° / 25.0°
Efficiency
86 %
Peak intensity
14.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON CZ
FWHM / FWTM
8.8° / 19.0°
Efficiency
94 %
Peak intensity
26 cd/lm
LEDs/each optic
1
Light colour
White
5/13
PRODUCT
DATASHEET
C12607_VIRPI-S
LED
LUXEON HL1Z
FWHM / FWTM
10.0° / 20.0°
Efficiency
96 %
Peak intensity
20.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON HL1Z
FWHM / FWTM
10.0° / 20.0°
Efficiency
88 %
Peak intensity
19.2 cd/lm
LEDs/each optic
1
Light colour
White
Protective plate, glass
LED
LUXEON HL2Z
FWHM / FWTM
14.0° / 26.0°
Efficiency
97 %
Peak intensity
11.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON HL2Z
FWHM / FWTM
14.0° / 26.0°
Efficiency
90 %
Peak intensity
11 cd/lm
LEDs/each optic
1
Light colour
White
6/13
PRODUCT
DATASHEET
C12607_VIRPI-S
LED
LUXEON SunPlus 20 Line (150 deg)
FWHM / FWTM
13.0° / 25.0°
Efficiency
88 %
Peak intensity
15.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON SunPlus 35 Line
FWHM / FWTM
12.0° / 23.0°
Efficiency
94 %
Peak intensity
16 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON T
FWHM / FWTM
16.0° / 31.0°
Efficiency
93 %
Peak intensity
8.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON TX
FWHM / FWTM
15.0° / 29.0°
Efficiency
91 %
Peak intensity
10.1 cd/lm
LEDs/each optic
1
Light colour
White
7/13
PRODUCT
DATASHEET
C12607_VIRPI-S
LED
SST-10-B130
FWHM / FWTM
12.0° / 27.0°
Efficiency
95 %
Peak intensity
13.1 cd/lm
LEDs/each optic
1
Light colour
Red
LED
SST-20
FWHM / FWTM
12.0° / 24.0°
Efficiency
95 %
Peak intensity
13.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxE21A
FWHM / FWTM
12.0° / 26.0°
Efficiency
95 %
Peak intensity
12.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19B/NVSxx19C
FWHM / FWTM
18.0° / 33.0°
Efficiency
94 %
Peak intensity
7.3 cd/lm
LEDs/each optic
1
Light colour
White
8/13
PRODUCT
DATASHEET
C12607_VIRPI-S
LED
OSCONIQ P 3030
FWHM / FWTM
10.0° / 22.0°
Efficiency
95 %
Peak intensity
18.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON SSL 150
FWHM / FWTM
14.0° / 28.0°
Efficiency
96 %
Peak intensity
11.4 cd/lm
LEDs/each optic
1
Light colour
Red
LED
OSLON SSL 80
FWHM / FWTM
14.0° / 30.0°
Efficiency
95 %
Peak intensity
9.7 cd/lm
LEDs/each optic
1
Light colour
Red
LED
SFH 4715AS
FWHM / FWTM
13.0° / 24.0°
Efficiency
94 %
LEDs/each optic
1
Light colour
IR
9/13
PRODUCT
DATASHEET
C12607_VIRPI-S
LED
LH181B
FWHM / FWTM
14.0° / 28.0°
Efficiency
95 %
Peak intensity
10.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351B
FWHM / FWTM
17.0° / 33.0°
Efficiency
97 %
Peak intensity
7.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351C
FWHM / FWTM
18.0° / 34.0°
Efficiency
97 %
Peak intensity
7.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351D
FWHM / FWTM
22.0° / 42.0°
Efficiency
96 %
Peak intensity
4.3 cd/lm
LEDs/each optic
1
Light colour
White
10/13
PRODUCT
DATASHEET
C12607_VIRPI-S
LED
LM301B
FWHM / FWTM
12.0° / 26.0°
Efficiency
96 %
Peak intensity
12.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
SEOUL DC 3030
FWHM / FWTM
14.9° / 29.9°
Efficiency
94 %
Peak intensity
9.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z5M1/Z5M2
FWHM / FWTM
15.0° / 29.0°
Efficiency
98 %
Peak intensity
9.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
Z8Y19
FWHM / FWTM
14.0° / 26.0°
Efficiency
94 %
Peak intensity
11.2 cd/lm
LEDs/each optic
1
Light colour
White
11/13
PRODUCT
DATASHEET
C12607_VIRPI-S
LED
Z8Y22
FWHM / FWTM
16.9° / 33.1°
Efficiency
94 %
Peak intensity
7.2 cd/lm
LEDs/each optic
1
Light colour
White
12/13
PRODUCT
DATASHEET
C12607_VIRPI-S
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
13/13
