PRODUCT
DATASHEET
C12609_VIRPI-W
VIRPI-W
~40° wide beam
TECHNICAL SPECIFICATIONS:
Dimensions
Height
Fastening
ROHS compliant
74.9 x 74.9 mm
9.5 mm
glue, pin
yes
MATERIAL SPECIFICATIONS:
Component
Type
Material
Colour
VIRPI-W
Multi-lens
PMMA
clear
Finish
ORDERING INFORMATION:
Component
C12609_VIRPI-W
» Box size: 470 x 280 x 300 mm
Qty in box
360
MOQ
MPQ
45
15
Last update: 12/10/2021
Subject to change without prior notice
LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries.
Box weight (kg)
12.6
1/12
PRODUCT
DATASHEET
C12609_VIRPI-W
See also our general installation guide: www.ledil.com/installation_guide
2/12
PRODUCT
DATASHEET
C12609_VIRPI-W
PHOTOMETRIC DATA (MEASURED):
LED
XB-D
FWHM / FWTM
40.0° / 65.0°
Efficiency
90 %
Peak intensity
1.7 cd/lm
LEDs/each optic
1
Light colour
White
Required components:
LED
XH-B/G
FWHM / FWTM
43.0° / 70.0°
Efficiency
91 %
Peak intensity
1.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-E2
FWHM / FWTM
41.0° / 66.0°
Efficiency
91 %
Peak intensity
1.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
XP-G
FWHM / FWTM
48.0° / 71.0°
Efficiency
92 %
Peak intensity
1.3 cd/lm
LEDs/each optic
1
Light colour
White
3/12
PRODUCT
DATASHEET
C12609_VIRPI-W
LED
XP-G2
FWHM / FWTM
49.0° / 72.0°
Efficiency
91 %
Peak intensity
1.3 cd/lm
LEDs/each optic
1
Light colour
White
LED
XT-E
FWHM / FWTM
41.0° / 65.0°
Efficiency
90 %
Peak intensity
1.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON Rebel ES
FWHM / FWTM
42.0° / 69.0°
Efficiency
91 %
Peak intensity
1.6 cd/lm
LEDs/each optic
1
Light colour
White
LED
NF2x757A
FWHM / FWTM
33.0° / 59.0°
Efficiency
92 %
Peak intensity
2.3 cd/lm
LEDs/each optic
1
Light colour
White
4/12
PRODUCT
DATASHEET
C12609_VIRPI-W
LED
NVSxx19A
FWHM / FWTM
40.0° / 65.0°
Efficiency
90 %
Peak intensity
1.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
Duris S5 (Single chip)
FWHM / FWTM
31.0° / 60.0°
Efficiency
93 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSCONIQ P 2226
FWHM / FWTM
32.0° / 62.0°
Efficiency
90 %
Peak intensity
2.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square EC
FWHM / FWTM
43.0° / 68.0°
Efficiency
91 %
Peak intensity
1.6 cd/lm
LEDs/each optic
1
Light colour
White
5/12
PRODUCT
DATASHEET
C12609_VIRPI-W
LED
LM231 A/B
FWHM / FWTM
32.0° / 62.0°
Efficiency
92 %
Peak intensity
2.3 cd/lm
LEDs/each optic
1
Light colour
White
6/12
PRODUCT
DATASHEET
C12609_VIRPI-W
PHOTOMETRIC DATA (SIMULATED):
LED
LUXEON 3535L
FWHM / FWTM
28.0° / 59.0°
Efficiency
93 %
Peak intensity
2.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON C
FWHM / FWTM
30.0° / 60.0°
Efficiency
86 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON CZ
FWHM / FWTM
32.0° / 63.0°
Efficiency
94 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON IR Domed 150
FWHM / FWTM
23.0° / 54.0°
Efficiency
94 %
LEDs/each optic
1
Light colour
IR
7/12
PRODUCT
DATASHEET
C12609_VIRPI-W
LED
LUXEON SunPlus 20 Line (150 deg)
FWHM / FWTM
29.0° / 60.0°
Efficiency
87 %
Peak intensity
2.5 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON SunPlus 35 Line
FWHM / FWTM
26.0° / 58.0°
Efficiency
93 %
Peak intensity
3 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON T
FWHM / FWTM
42.0° / 67.0°
Efficiency
93 %
Peak intensity
1.8 cd/lm
LEDs/each optic
1
Light colour
White
LED
LUXEON TX
FWHM / FWTM
38.0° / 66.0°
Efficiency
93 %
Peak intensity
2 cd/lm
LEDs/each optic
1
Light colour
White
8/12
PRODUCT
DATASHEET
C12609_VIRPI-W
LED
SST-10-B130
FWHM / FWTM
47.0° / 68.0°
Efficiency
96 %
Peak intensity
1.6 cd/lm
LEDs/each optic
1
Light colour
Red
LED
SST-20
FWHM / FWTM
32.0° / 62.0°
Efficiency
96 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
LED
NVSxx19B/NVSxx19C
FWHM / FWTM
44.0° / 69.0°
Efficiency
94 %
Peak intensity
1.7 cd/lm
LEDs/each optic
1
Light colour
White
LED
OSLON Square CSSRM2/CSSRM3
FWHM / FWTM
36.0° / 69.0°
Efficiency
94 %
Peak intensity
1.9 cd/lm
LEDs/each optic
1
Light colour
White
9/12
PRODUCT
DATASHEET
C12609_VIRPI-W
LED
LH181B
FWHM / FWTM
29.0° / 56.0°
Efficiency
95 %
Peak intensity
2.9 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351B
FWHM / FWTM
55.0° / 76.0°
Efficiency
94 %
Peak intensity
1.2 cd/lm
LEDs/each optic
1
Light colour
White
LED
LH351C
FWHM / FWTM
54.0° / 75.0°
Efficiency
94 %
Peak intensity
1.1 cd/lm
LEDs/each optic
1
Light colour
White
LED
SEOUL DC 3030
FWHM / FWTM
35.5° / 62.8°
Efficiency
94 %
Peak intensity
2.3 cd/lm
LEDs/each optic
1
Light colour
White
10/12
PRODUCT
DATASHEET
C12609_VIRPI-W
LED
Z8Y22
FWHM / FWTM
31.5° / 57.9°
Efficiency
94 %
Peak intensity
2.4 cd/lm
LEDs/each optic
1
Light colour
White
11/12
PRODUCT
DATASHEET
C12609_VIRPI-W
GENERAL INFORMATION:
NOTE: The typical beam angle will be changed by different color, chip size
and chip position tolerance. The typical total beam angle is the full angle
measured where the luminous intensity is half of the peak value.
MATERIALS:
As part of our continuous research and improvement processes, and to ensure
the best possible quality and availability of our products, LEDiL reserves the
right to change material grades without notice.
PRODUCT DATA USER AGREEMENT AND DISCLAIMER:
The measured data in the provided downloadable LEDiL Product Datasheets
and Mechanical 2D-Drawings is rounded and provided as reference for
planning. LEDiL Oy's optical specifications have been verified by conducting
performance testing of the products in accordance with the company's quality
system. The reported data are averaged results of multiple measurements with
typical variation. LEDiL Oy reserves the right to without prior notification make
changes and improvements to its products.
LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of
any kind for the contents and correctness of the provided data. The provided
data has been generated with highest diligence but the provided data may in
reality not represent the complete possible variation range of all intrinsic
parameters. Therefore, in certain cases a deviation from the provided data
could occur.
LEDiL Oy
Joensuunkatu 13
FI-24240 SALO
Finland
LEDiL Inc.
228 West Page Street
Suite D
Sycamore IL 60178
USA
Ledil Optics Technology
(Shenzhen) Co., Ltd.
# 405 , Block B
Casic Motor Building
Shenzhen 518057
P.R.CHINA
Local sales and technical
support
www.ledil.com/
where_to_buy
Shipping locations
Salo, Finland
Hong Kong, China
Distribution Partners
www.ledil.com/
where_to_buy
LEDiL Oy reserves the right to undertake technical changes of its products
without further notification which could lead to changes in the provided data.
LEDiL Oy assumes no liability of any kind for the possible deviation from any
provided data or any other damage resulting from the usage of the provided
data.
The user agrees to this disclaimer and user agreement with the download or
usage of the provided files.
12/12
很抱歉,暂时无法提供与“C12609_VIRPI-W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 15+49.3423715+6.17160
- 30+48.9873930+6.12720
- 45+48.8099045+6.10500
- 75+48.6324175+6.08280
- 150+48.09994150+6.01620
- 国内价格 香港价格
- 15+40.2016115+5.02830
- 60+39.4029060+4.92840
- 150+38.95918150+4.87290
- 375+38.51545375+4.81740
- 600+37.80549600+4.72860
- 国内价格 香港价格
- 15+34.6106615+4.32900
- 45+33.9894445+4.25130
- 75+33.8119575+4.22910
- 300+33.10199300+4.14030
- 450+32.65826450+4.08480
