FCP13895_SEANNA-A
FCP13895_SEANNA-A
    LEDIL(芬兰)
FCP13895_SEANNA-A 数据手册
PRODUCT DATASHEET FCP13895_SEANNA-A SEANNA-A ~2.3° spot beam. Assembly with holder. TECHNICAL SPECIFICATIONS: Dimensions Height Fastening ROHS compliant Ø 155.2 mm 82 mm pin, screw yes MATERIAL SPECIFICATIONS: Component Type Material Colour SEANNA-A Single lens PMMA clear SEANNA-FRES Single lens PMMA clear SEANNA-HLD-B Holder PA66GF30 black SEANNA-HLD-B-TOPRING Holder PA66GF30 black SEANNA-HLD-B-BOTTOMRING Holder PA66GF30 black SEANNA-SCREW Accessory Stainless steel clear Finish ORDERING INFORMATION: Component FCP13895_SEANNA-A » Box size: Qty in box Single lens MOQ 20 MPQ 2 Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 6.5 1/19 PRODUCT DATASHEET FCP13895_SEANNA-A See also our general installation guide: www.ledil.com/installation_guide Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (MEASURED): LED XD16 FWHM / FWTM 1.0° / 3.0° Efficiency 91 % Peak intensity 629 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 1.0° / 3.0° Efficiency % Peak intensity 718 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HD FWHM / FWTM 2.4° / 5.3° Efficiency 94 % Peak intensity 255 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HI FWHM / FWTM 1.6° / 3.2° Efficiency 94 % Peak intensity 492 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (MEASURED): LED NVSW3x9A FWHM / FWTM 1.9° / 4.1° Efficiency 92 % Peak intensity 310 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Black Flat FWHM / FWTM 1.2° / 2.3° Efficiency 94 % Peak intensity 1196 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 1.5° / 3.3° Efficiency 94 % Peak intensity 587 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED MK-R FWHM / FWTM 4.0° / 10.4° Efficiency 91 % Peak intensity 82 cd/lm LEDs/each optic 1 Light colour White Required components: LED XB-D FWHM / FWTM 1.3° / 3.2° Efficiency 87 % Peak intensity 698 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HD FWHM / FWTM 2.4° / 4.2° Efficiency 89 % Peak intensity 257 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35 HI FWHM / FWTM 1.6° / 3.6° Efficiency 83 % Peak intensity 496 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED XHP35.2 HD FWHM / FWTM 2.0° / 6.0° Efficiency 89 % Peak intensity 161.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP35.2 HI FWHM / FWTM 2.0° / 4.0° Efficiency 89 % Peak intensity 161 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50 FWHM / FWTM 3.3° / 6.7° Efficiency 87 % Peak intensity 122 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP50.2 FWHM / FWTM 2.7° / 6.8° Efficiency 84 % Peak intensity 128.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED XHP70 FWHM / FWTM 4.3° / 10.4° Efficiency 81 % Peak intensity 69.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED XHP70.2 FWHM / FWTM 4.5° / 10.1° Efficiency 83 % Peak intensity 71.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L FWHM / FWTM 2.4° Efficiency % Peak intensity 272 cd/lm LEDs/each optic 1 Light colour White Required components: LED XM-L2 FWHM / FWTM 2.0° / 3.9° Efficiency 85 % Peak intensity 275 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED XM-L3 FWHM / FWTM 2.0° / 6.0° Efficiency 90 % Peak intensity 196.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E FWHM / FWTM 1.2° / 2.9° Efficiency 92 % Peak intensity 955 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 2.0° / 6.0° Efficiency 85 % Peak intensity 211.5 cd/lm LEDs/each optic 1 Light colour Blue Required components: LED XP-G FWHM / FWTM 1.4° / 3.4° Efficiency 90 % Peak intensity 578 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED XP-G2 FWHM / FWTM 1.4° / 3.2° Efficiency 91 % Peak intensity 628 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G2 HE FWHM / FWTM 2.0° / 4.0° Efficiency 89 % Peak intensity 286.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 2.0° / 4.0° Efficiency 88 % Peak intensity 246.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-P FWHM / FWTM 2.0° / 6.0° Efficiency 84 % Peak intensity 246.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED XQ-E HD FWHM / FWTM 1.1° / 2.5° Efficiency 92 % Peak intensity 1460 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HI FWHM / FWTM 1.2° / 2.0° Efficiency 90 % Peak intensity 1300 cd/lm LEDs/each optic 1 Light colour White Required components: LED XT-E FWHM / FWTM 1.4° / 3.5° Efficiency 88 % Peak intensity 519 cd/lm LEDs/each optic 1 Light colour White Required components: LED LZ4 (00xW00) FWHM / FWTM 3.3° / 8.2° Efficiency 91 % Peak intensity 136 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED LUXEON CZ FWHM / FWTM 1.4° / 3.7° Efficiency 94 % Peak intensity 424 cd/lm LEDs/each optic 1 Light colour Green Required components: LED LUXEON CZ FWHM / FWTM 1.3° / 3.4° Efficiency 94 % Peak intensity 564 cd/lm LEDs/each optic 1 Light colour PC Amber Required components: LED LUXEON CZ FWHM / FWTM 1.6° / 3.8° Efficiency 93 % Peak intensity 371 cd/lm LEDs/each optic 1 Light colour Blue Required components: LED LUXEON CZ FWHM / FWTM 1.2° / 3.3° Efficiency 94 % Peak intensity 564 cd/lm LEDs/each optic 1 Light colour Red Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED LUXEON CZ FWHM / FWTM 1.7° / 3.9° Efficiency 93 % Peak intensity 346 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON HL2X FWHM / FWTM 2.0° / 4.0° Efficiency 89 % Peak intensity 317.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON M/MX FWHM / FWTM 3.6° / 9.0° Efficiency 89 % Peak intensity 99 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON MZ FWHM / FWTM 2.2° / 6.0° Efficiency 84 % Peak intensity 151 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED LUXEON Rebel FWHM / FWTM 1.3° / 3.2° Efficiency 90 % Peak intensity 704 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rebel ES FWHM / FWTM 1.6° / 3.6° Efficiency 90 % Peak intensity 530 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON Rubix FWHM / FWTM 2.0° / 6.0° Efficiency 83 % Peak intensity 141.9 cd/lm LEDs/each optic 1 Light colour Blue Required components: LED LUXEON Rubix FWHM / FWTM 2.0° / 6.0° Efficiency 83 % Peak intensity 157.7 cd/lm LEDs/each optic 1 Light colour Green Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED LUXEON Rubix FWHM / FWTM 2.0° / 6.0° Efficiency 85 % Peak intensity 196.2 cd/lm LEDs/each optic 1 Light colour Red Required components: LED LUXEON Rubix FWHM / FWTM 2.0° / 4.0° Efficiency 88 % Peak intensity 290.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON S1000 FWHM / FWTM 3.8° / 8.0° Efficiency 88 % Peak intensity 100 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON V2 FWHM / FWTM 2.0° / 4.0° Efficiency 88 % Peak intensity 250.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED SBT-90 FWHM / FWTM 2.0° / 6.0° Efficiency 76 % Peak intensity 175.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED SBT-90 FWHM / FWTM 2.3° / 4.8° Efficiency 90 % Peak intensity 253 cd/lm LEDs/each optic 1 Light colour White Required components: LED NV4WB35AM FWHM / FWTM 2.0° / 4.0° Efficiency 90 % Peak intensity 185.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSW219F FWHM / FWTM 2.0° / 4.0° Efficiency 89 % Peak intensity 296 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED NVSW519A FWHM / FWTM 2.0° / 4.0° Efficiency 89 % Peak intensity 251.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED KW CSLPM1.TG FWHM / FWTM 2.0° / 4.0° Efficiency 90 % Peak intensity 229.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED KW CULPM1.TG FWHM / FWTM 2.0° / 6.0° Efficiency 92 % Peak intensity 176.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ C 2424 FWHM / FWTM 2.0° / 4.0° Efficiency 90 % Peak intensity 241.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED OSCONIQ P 3737 (2W version) FWHM / FWTM 2.0° / 4.0° Efficiency 89 % Peak intensity 258.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 3737 (3W version) FWHM / FWTM 2.0° / 4.0° Efficiency 90 % Peak intensity 232.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSCONIQ P 7070 FWHM / FWTM 3.5° / 7.1° Efficiency 91 % Peak intensity 122.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square PC FWHM / FWTM 1.5° / 3.6° Efficiency 89 % Peak intensity 550 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/19 PRODUCT DATASHEET FCP13895_SEANNA-A PHOTOMETRIC DATA (SIMULATED): LED LH351B FWHM / FWTM 2.0° / 4.0° Efficiency 90 % Peak intensity 279.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351C FWHM / FWTM 2.0° / 4.0° Efficiency 91 % Peak intensity 279.2 cd/lm LEDs/each optic 1 Light colour White Required components: LED LH351D FWHM / FWTM 2.0° / 4.0° Efficiency 91 % Peak intensity 235.3 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y50P FWHM / FWTM 3.0° / 7.0° Efficiency 79 % Peak intensity 90.4 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/19 PRODUCT DATASHEET FCP13895_SEANNA-A GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 07/02/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/19
FCP13895_SEANNA-A 价格&库存
很抱歉,暂时无法提供与“FCP13895_SEANNA-A”相匹配的价格&库存,您可以联系我们找货
FCP13895_SEANNA-A
  • 20+303.53628
  • 40+295.94667
  • 80+291.39374
库存:20
FCP13895_SEANNA-A
    • 1+397.57947
    • 5+388.85268
    • 10+380.47995
    库存:20
    FCP13895_SEANNA-A
