12085
12085
    CARCLO
    LENS 10MM DIFFUSED WIDE
12085 数据手册
B A C D E F G GENERAL VIEW X 6.0 I ISS. DATE c 2011 CTP-COIL CUSTOMER DRAWING 1 H ALL DIMENSIONS IN mm 3.3 J E.C.N. DESCRIPTION 1 12-Nov-10 FIRST ISSUE 2 23-Mar-11 03/11/1293 ADD RECESS DIMENSION & GENERAL INFO 3 17-Nov-11 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm 11/11/1314 1 5.15 4.95 1.25 2 2 0.3 4.95 SCALE 1:1 25.7 3 12.5 3 4.95 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND TEL: +44 1753 575011 FAX: +44 1753 811359 email: design@carclo-optics.com 4 4 4.95 GENERAL TOLERANCES (UNLESS STATED) LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 5.00 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° CUSTOMER 5 SECTION X-X CARCLO 6.3 X TITLE 10mm IP66 WIDE FROSTED - with Locations Pins & Flange 12.5 DRAWN 2.05 E 0.20 C E F G H 29-Nov-11 6 29-Nov-11 12085 CARCLO DRG. No. A3 D 12-Nov-10 CARCLO PART No. SIZE 1. MATERIAL - UV STABILISED CLEAR POLYCARBONATE 2. INCLUSIONS SPECIFIED TO BS ISO 10110. B PW 5:1 E A DATE SCALE DETAIL SCALE 8:1 NOTES: DATE MH APP'D 2.0 7 DATE BB CHK'D 6 SEE DETAIL 5 60655 I SHEET 2 OF 3 J 7 A B C D E F G H ISS. DATE c 2011 CTP-COIL ALL DIMENSIONS IN mm 1 PCB GLUE PAD AND ALIGNMENT HOLE LAYOUT DIMENSIONS 2 3.4 I J E.C.N. DESCRIPTION 1 12-Nov-10 FIRST ISSUE 2 23-Mar-11 03/11/1293 ADD RECESS DIMENSION & GENRAL INFO 3 17-Nov-11 CHANGE 2.0MM PEGS HEIGHT TO 0.8mm 11/11/1314 1 2 LED LENS POSITION 4.95 2.6 LOCATION HOLE IN PCB 3 3 9.7 CARCLO TECHNICAL PLASTICS (SLOUGH) 103 BUCKINGHAM AVE, SLOUGH SL1 4PF, ENGLAND } 4.95 TEL: +44 1753 575011 FAX: +44 1753 811359 email:design@carclo-optics.com 4 4 GENERAL TOLERANCES (UNLESS STATED) 4.95 LINEAR X +/- 0.25 X.X +/- 0.1 X.XX +/- 0.05 ANGULAR X +/- 1° X.X +/- 0.5° X.XX +/- 0.1° 9.7 CUSTOMER CARCLO 5 5 TITLE 10mm IP66 WIDE FROSTED - with Locations Pins & Flange 2.1 LOCATION HOLE IN PCB DRAWN 6 CHK'D 4.95 DATE MH APP'D 3.4 DATE BB DATE PW SCALE SIZE B C D E F G H 6 29-Nov-11 12085 CARCLO DRG. No. A3 A 29-Nov-11 CARCLO PART No. 5:1 7 12-Nov-10 60655 I SHEET 3 OF 3 J 7
12085 价格&库存
很抱歉,暂时无法提供与“12085”相匹配的价格&库存,您可以联系我们找货
