FA12626_LXP-W
FA12626_LXP-W
    LEDIL(芬兰)
    LENS W/HOLDER 21.6MM RND CREE
FA12626_LXP-W 数据手册
PRODUCT DATASHEET FA10832_LXP-W LXP-W ~40° wide beam optimized for CREE XP-E. 14.7 mm high assembly with installation tape. TECHNICAL SPECIFICATIONS: Dimensions Height Ø 21.6 mm 14.7 mm Fastening ROHS compliant tape yes MATERIAL SPECIFICATIONS: Component Type Material Colour LR1-W Single lens PMMA clear LXP-LH1-TAPE-BLK Holder PC black LEILA-TAPE Tape Acrylic foam black Finish ORDERING INFORMATION: Component FA10832_LXP-W » Box size: 470 x 235 x 270 mm Single lens Qty in box MOQ MPQ 2304 288 144 Last update: 03/01/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 12.1 1/6 PRODUCT DATASHEET FA10832_LXP-W See also our general installation guide: www.ledil.com/installation_guide Last update: 03/01/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/6 PRODUCT DATASHEET FA10832_LXP-W PHOTOMETRIC DATA (MEASURED): LED XP-E FWHM / FWTM 44.0° / 62.0° Efficiency 91 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E-HEW FWHM / FWTM 44.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED XP-G FWHM / FWTM 43.0° / 67.0° Efficiency 88 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-L HI FWHM / FWTM 45.0° / 67.0° Efficiency 85 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 03/01/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/6 PRODUCT DATASHEET FA10832_LXP-W PHOTOMETRIC DATA (MEASURED): LED XT-E FWHM / FWTM 45.0° Efficiency % LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 44.0° / 67.0° Efficiency 88 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 03/01/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/6 PRODUCT DATASHEET FA10832_LXP-W PHOTOMETRIC DATA (SIMULATED): LED XP-G3 FWHM / FWTM 45.0° / 69.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON V2 FWHM / FWTM 45.0° / 64.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z5 FWHM / FWTM 46.0° / 64.0° Efficiency 93 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 03/01/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/6 PRODUCT DATASHEET FA10832_LXP-W GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 03/01/2022 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/6
FA12626_LXP-W
物料型号:FA10832_LXP-W
器件简介:这是一个为CREE XP-E优化的宽光束角度(约40°)的LED光学透镜组件,总高度为14.7毫米,带有安装胶带。
引脚分配:文档中未提及引脚分配信息。
参数特性: - 尺寸:直径21.6毫米 - 高度:14.7毫米 - 固定方式:胶带固定,符合ROHS标准
功能详解: - 提供了与不同LED型号(如CREE的XP-E、XP-E-HEW、XP-G、XP-L HI、XT-E,OSRAM的OSLON Square CSSRM2/CSSRM3)兼容的光度数据,包括半高全宽(FWHM)、半宽全高(FWTM)、效率、峰值强度等。
应用信息:文档中未明确提及应用信息,但根据产品特性,可能适用于需要宽光束角度的照明应用。
封装信息: - 材料规格:包括PMMA材料的单透镜、PC材料的黑色支架、丙烯酸泡沫胶带。 - 订购信息:每个盒子包含2304个单位,最小订购量(MOQ)为288,中等订购量(MPQ)为144,盒子尺寸为470x235x270毫米,重量为12.1公斤。
FA12626_LXP-W 价格&库存
很抱歉,暂时无法提供与“FA12626_LXP-W”相匹配的价格&库存,您可以联系我们找货
