C13185_GERI-RZ
C13185_GERI-RZ
    LEDIL(芬兰)
    SMD
C13185_GERI-RZ 数据手册
A 0.1 h 0.8 1.2 From pbb top Typical positioning: - Dimension h (0,8) depends on led-type chosen. - Dimension h is adjusted to meet 0.1mm suggestion unless mechanical fitting is not harmed. - Cree XM-L RGBW drawn 28.4 3 3 Front view from led base top B C D E F G H 4 Positioning: - OSRAM SMT RGB - LUXEON Z RGB 4 3 2 45 Top view 2 Isometric view 44.9 INDEX PART NO DESCRIPTION MATERIAL COLOUR 1 Tolerances if not otherwise shown According to DIN ISO 2768-1 Linear measures: Up to 30mm class F, otherwise class M. According to DIN ISO 2768-2 Form and position: class K THIRD ANGLE PROJECTION: 1 This drawing is the property of LEDiL Oy. It may not be reproduced, copied or communicated without a written agreement with LEDiL Oy." G GERI-RZ PMMA 8N Ledil Oy Salorankatu 10 FIN 24240 SALO Finland DRAWING TITLE GERI-RZ SIZE 1 PART NUMBER A3 SCALE H C13185 C13185 1:1 WEIGHT SHEET B A 1/1
C13185_GERI-RZ 价格&库存
很抱歉,暂时无法提供与“C13185_GERI-RZ”相匹配的价格&库存,您可以联系我们找货
