D ATA S H E E T
Intematix ChromaLit 360
TM
Remote Phosphor Light Source: Ellipse, Candle, Dome
ChromaLit 360 light sources enable brighter, more energy efficient LED bulbs and lighting fixtures by
providing wide angle lighting distribution, improved light quality, and greater design freedom. These
remote phosphor light sources from Intematix provide highly uniform light distribution and are offered in
a variety of lumen levels for applications in indoor and outdoor general lighting, decorative and retrofit
light bulb designs.
Features & Benefits
Applications & Uses
High light quality with choice of CCT & CRI
options
LED retrofit light bulbs
Portable consumer lighting
Uniform, glare-free light that is diffuse and
offers soft shadows
Down lights
Reduces costs with a smaller heatsink thereby
lowering supply chain costs
Streamlined supply and production of LED
lighting systems
Up to 30% higher system efficacy compared to
conventional LED lighting designs
Wall sconces
Pendants
Chandelier and other decorative applications
Appliances
TA B L E O F C O N T E N T S
Product Nomenclature
3
Minor Product Change Policy
3
Optical Characteristics
4
Color Binning Information
4
Relative Spectral Power Distribution
5
Intensity Distribution Diagrams
6
Performance Characteristics Over Wavelength
8
Relative Conversion Efficacy Over Temperature
8
Absolute Maximum and Minimum Ratings
10
Mechanical Characteristics
10
Reliability and Environmental Ratings
14
Handling Considerations
14
Company Information
14
Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017.
ChromaLit 360 products are identified by the following product nomenclature:
Product order code
CL-ABC-DEFGH-IJ
Where:
A - Designates the first digit of CRI
8 = 80 CRI minimum
BC - Designates the first two digits of CCT
30 = 3000K, 40 = 4000K, etc.
DEF - Designates shape
CAN = candle, ELP = ellipse, DOM = dome
GH - Product identification number
IJ - Designates the standard polycarbonate material used
Example:
CL-830-CAN15-PC represents ChromaLit 80CRI, 3000K CCT, Candle 15, polycarbonate
The rigorous qualification testing of ChromaLit products ensures product performance. Slight
cosmetic changes which do not affect the form fit or function of the product may occur as Intematix
continues product optimization.
Optical and Performance Characteristics1
Color Designation
CL-827
CL-927
CL-830
CL-930
CL-835
CL-840
CL-750
CCT2 Color Consistency3 Min
(K)
MacAdam Ellipses CRI4
2700
2700
3000
3000
3500
4000
5000
3-step
3-step
3-step
3-step
3-step
3-step
4-step
80
90
80
90
80
80
70
Minimum Conversion
Efficacy5
(Lm/Wrad) at 25oC
Typical Conversion
Efficacy5
(Lm/Wrad) at 25oC
170
155
185
160
195
200
215
180
165
200
170
205
210
225
Notes
1.
Performance based on reference design. Please refer to application note for details on reference design. Intematix maintains a tolerance of +7% of
luminous flux and radiant watt measurements. Intematix maintains a tolerance of 0.5 MacAdam Ellipses on color consistency measurements.
2.
Correlated Color Temperature
3.
Color Consistency is dependent on the AVERAGE dominant wavelength of blue LED source. ChromaLit maintains color consistency within a
3-step MacAdam Ellipse given a uniform blue LED source with a constant average wavelength. 2.5nm (+1.25nm) of average blue LED wavelength
variation will provide 4-step MacAdam Ellipses of color consistency. 5nm (+2.5nm) of average blue LED wavelength variation will provide 5-step
MacAdam Ellipses of color consistency. Values are approximate, please refer to bin diagram on the following page for exact bin definition.
4.
Minimum Color Rendering Index rating is based on reference design using blue LEDs with average dominant wavelength of 455nm.
5.
Conversion Efficacy is the luminous flux (white light) output per radiant watt of blue light input to ChromaLit. Wrad is the radiometric power measured
in watts. Conversion efficacy is rated based on reference operation and dominant blue LED wavelength of 455nm (peak wavelength of 450nm).
CIE y
Color Binning Diagram
CIE x
Color Bin Center Points
CCT (K)
x
y
2700
3000
3500
4000
5000
0.4578
0.4338
0.4073
0.3818
0.3447
0.4101
0.4030
0.3917
0.3797
0.3553
Relative Radiant Power (%)
Wavelength (nm)
Intensity Distribution - Ellipse
Relative Intensity
Luminous Intensity Distribution Diagram1
Angle (Deg)
Beam Angle (Full Angle)
Maximum Intensity Angle (Half Angle)
280o
75o
Luminous Intensity Polar Diagram
1
Intensity distribution pattern is characterized using CL-750-ELP60-PC products.
Intensity Distribution - Candle
Relative Intensity
Angle (Deg)
255o
70o
1
Intensity distribution pattern is characterized using CL-750-CAN40-PC products.
Intensity Distribution - Dome
Relative Intensity
Angle (Deg)
215o
0o
1
Intensity distribution pattern is characterized using CL-750-DOM60-PC products.
Performance Characteristics over Wavelength
Relative Conversion Efficacy over Wavelength1
Average Dominant Wavelength (nm)
1
Relative conversion efficacy does not reflect performance of blue LED over dominant wavelength.
Performance Characteristics over Temperature
ChromaLit Temperature (oC)
Relative CIE Chromaticity Shift over Wavelength
Δ CIE X Coordinate
Δ CIE Y Coordinate
450nm
-0.003
-0.014
452.2nm
-0.002
-0.007
455nm
457.5nm
0.001
0.005
460nm
0.001
0.008
Description
Maximum operating temperature (Tmax1)
Minimum operating temperature
Max storage temperature
Minimum storage temperature
Response time to full light output
Maximum Values
110oC
-40oC
110oC
-40oC
很抱歉,暂时无法提供与“CL-830-DOM60-PC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+16.9229810000+2.19919
