CL-835-L152-XT
CL-835-L152-XT
    INTEMATIX
    CHROMALIT LT SOURCE LINEAR
CL-835-L152-XT 数据手册
D ATA S H E E T Intematix ChromaLit XT TM Remote Phosphor Light Source ChromaLit XT offers powerful elegance for brilliant lighting design. Power comes from a very high operating temperature and efficiency enabling thousands of lumens from a small light emitting area, ideal for down lights and other lighting modules. Elegance is a result of ChromaLit XT’s neutral offstate color making it the first choice for attractive light fixture design. With reliability second to none, ChromaLit XT offers a new range of long life applciations in both indoor and outdoor lighting. Product Features Application & Benefits • Diffuse and uniform emission pattern • • 3 SDCM color consistency • Up to 30% higher system efficacy compared to • white LED solutions • Glare free non-pixelated lighting • CCT options ranging from 2700K to 5600K with • a CRI range of 70 to 98 Increased energy savings and lower total cost of ownership • Omni-directional light distribution • • Substrate material - glass Supports broad market requirements for high quality lighting with improved inventory management • Meets V0 flammability requirement and UV resistant Enables new design options for functional lighting applications Uniform consistent lighting TA B L E O F C O N T E N T S Product Nomenclature 3 Minor Product Change Policy 3 Optical Characteristics 4 Color Binning Information 4 Relative Spectral Power Distribution 5 Intensity Distribution Diagrams 6 Performance Characteristics Over Wavelength 7 Relative Conversion Efficacy Over Temperature 7 Absolute Maximum and Minimum Ratings 8 Mechanical Characteristics 8 Reliability and Environmental Ratings 10 Handling Considerations 10 Company Information 10 Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Product Nomenclature ChromaLit XT products are identified by the following product nomenclature: Product order code CL-ABC-DEFG-HI Where: A - Designates the first digit of CRI 8 = 80 CRI minimum BC - Designates the first two digits of CCT 30 = 3000K, 40 = 4000K, etc. DEFG - Designates dimensions R75 = 75mm Round HI - Designates product family (XT) v Example: CL-827-R75-XT represents ChromaLit 80CRI, 2700K CCT, 75mm Round, XT product family Minor Product Change Policy The rigorous qualification testing of ChromaLit products ensures product performance. Slight cosmetic changes which do not affect the form fit or function of the product may occur as Intematix continues product optimization. Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Optical and Performance Characteristics1 Color Designation CL-827 CL-927 CL-830 CL-930 CL-835 CL-840 CL-750 CCT2 Color Consistency3 Min (K) MacAdam Ellipses CRI4 2700 2700 3000 3000 3500 4000 5000 3-step 3-step 3-step 3-step 3-step 3-step 4-step 80 90 80 90 80 80 70 Minimum Conversion Efficacy5 (Lm/Wrad) at 25oC Typical Conversion Efficacy5 (Lm/Wrad) at 25oC 180 150 187 155 195 205 222 190 160 197 165 205 215 232 Notes 1. Performance based on reference design. Please refer to application note for details on reference design. Intematix maintains a tolerance of +7% of luminous flux and radiant watt measurements. Intematix maintains a tolerance of 0.5 MacAdam Ellipses on color consistency measurements. 2. Correlated Color Temperature 3. Color Consistency is dependent on the AVERAGE dominant wavelength of blue LED source. ChromaLit maintains color consistency within a 3-step MacAdam Ellipse given a uniform blue LED source with a constant average wavelength. 2.5nm (+1.25nm) of average blue LED wavelength variation will provide 4-step MacAdam Ellipses of color consistency. Values are approximate, please refer to bin diagram on the following page for exact bin definition. 4. Minimum Color Rendering Index rating is based on reference design using blue LEDs with average dominant wavelength of 455nm. 5. Conversion Efficacy is the luminous flux (white light) output per radiant watt of blue light input to ChromaLit. Wrad is the radiometric power measured in watts. Conversion efficacy is rated based on reference operation and dominant blue LED wavelength of 455nm (peak wavelength of 450nm). CIE y Color Binning Diagram ChromaLit Bin Coordinates CIE x CCT (K) x y 2700 3000 3500 4000 5000 0.4578 0.4338 0.4073 0.3818 0.3447 0.4101 0.4030 0.3917 0.3797 0.3553 Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Relative Radiant Power (%) Relative Spectral Power Distribution Relative Radiant Power (%) Wavelength (nm) Wavelength (nm) Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Intensity Distribution Relative Intensity Luminous Intensity Distribution Diagram1 Angle (Deg) 1 Intensity distribution pattern is characterized using CL-830-LR-XT products and reference design. Luminous Intensity Polar Distribution Diagram Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Performance Characteristics over Wavelength Relative Conversion Efficacy Relative Conversion Efficacy over Wavelength1 Average Dominant Wavelength (nm) 1 Relative conversion efficacy does not reflect performance of blue LED over dominant wavelength. Relative Conversion Efficacy Performance Characteristics over Temperature ChromaLit Temperature (oC) Relative CIE Chromaticity Shift over Wavelength Average Dominant Wavelength Δ CIE X Coordinate Δ CIE Y Coordinate 450nm -0.003 -0.014 452.2nm -0.002 -0.007 455nm 0 0 457.5nm 0.001 0.005 Intematix Confidential. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. 460nm 0.001 0.008 Absolute Maximum and Minimum Ratings Description Maximum operating temperature (Tmax1) Minimum operating temperature Max storage temperature Minimum storage temperature Response time to full light output Maximum Values 180oC -40oC 180oC -40oC
CL-835-L152-XT
物料型号:ChromaLit XT产品通过特定的产品命名规则标识,例如CL-827-R75-XT代表80CRI,2700K色温,75mm圆形,属于XT产品系列。
器件简介:ChromaLit XT是一款高亮度、高效率的远程荧光光源,适用于筒灯和其他照明模块,具有中性的非工作状态颜色,是照明装置设计的首选。
引脚分配:文档中未提及引脚分配信息。
参数特性: - 色温(CCT)范围从2700K到5600K - 色一致性为3步MacAdam椭圆 - 最小显色指数(CRI)从70到98 - 转换效率在25°C时,最小值为180lm/W,典型值为190lm/W(以2700K 80CRI为例)
功能详解: - 具有扩散和均匀的发射模式 - 无眩光、无像素化照明 - 360度全方位光分布 - 基板材料为玻璃
应用信息: - 为功能性照明应用提供新的设计选项 - 支持广泛的市场要求,提供高质量的照明解决方案 - 满足V0阻燃要求和抗紫外线性能
封装信息: - 提供圆形、方形和线性封装选项,具有不同的尺寸和典型流明输出 - 基板厚度为2.4mm,材质为低铁玻璃 - 包装规格根据尺寸不同而有所变化
CL-835-L152-XT 价格&库存
很抱歉,暂时无法提供与“CL-835-L152-XT”相匹配的价格&库存,您可以联系我们找货
