CL-840-LIN01-PC0-1220R
    INTEMATIX
    LENS 80CRI 4000K 4' LINEAR
CL-840-LIN01-PC0-1220R 数据手册
D ATA S H E E T Intematix ChromaLit Linear TM Remote Phosphor Light Source ChromaLit Linear enables new and creative designs for high lumen area and decorative lighting systems. Combining the benefits of remote phosphor with a unique delivery system, ChromaLit Linear delivers the uniform, glare free, color consistent lighting associated with remote phosphor systems with the additional benefit of a clean and familiar off state white appearance. Unlike many linear LED solutions which may be limited to low lumen decorative lighting applications, ChromaLit Linear delivers the light density required to displace high wattage fluorescent tubes for commercial area lighting. The remote phosphor architecture reduces system costs and increases efficacy compared to conventional LED designs while delivering superior light quality and consistency. With extended lengths and future options to integrate optical elements to enhance beam control, ChromaLit Linear brings uniform glare free illumination to applications such as troffers, mid and high bay fixtures, cove lights, architectural lights, and task and under cabinet light fixtures. Product Features Application Benefits • High flux density linear profile capable of up to 2500 lumens per foot with unlimited length possibilities • Enables new design options for functional and decorative lighting applications • Diffuse and uniform emission pattern • Glare free non-pixelated lighting • Sleek profile with white exterior finish • New shallow depth design potential • 3 SDCM color consistency • Uniform consistent lighting • Up to 30% higher system efficiency compared to white LED solutions • Increased energy savings and lower total cost of ownership • CCT options from 2700K to 5000K with minimum 80 or 90 CRI • Supports broad market requirements for high quality lighting with improved inventory management TA B L E O F C O N T E N T S Product Nomenclature 3 Minor Product Change Policy 3 Optical Characteristics 4 Performance Characteristics 4 Color Binning Information 5 Relative Spectral Power Distribution 6 Intensity Distribution Diagrams 6 Performance Characteristics Over Wavelength 7 Relative CRI Shift Over Wavelength 8 Relative Conversion Efficacy Over Temperature 8 Absolute Maximum and Minimum Ratings 9 Mechanical Characteristics 9 Reliability and Environmental Ratings 10 Handling Considerations 10 Company Information 10 All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Product Nomenclature ChromaLit Linear products are identified by the following product nomenclature: Product order code CL - ABC - DEFGH - IJK - LMNPQ Where: CL - Designates the ChromaLit product family A - Designates first digit in CRI 8 = 80 CRI minimum, 9 = 90 CRI minimum BC - Designates the first two digits in CCT 30 = 3000K, 40 = 4000K, etc. DEF - Designates shape LIN = ChromaLit Linear profile GH - Profile identification number 01 = 2500 lm/ft maximum, 16mm OD round, 8mm ID, 20mm wide flange IJK - Designates material and mechnical configuration LMNP - Designated product length in mm Q - Designates cut tolerance R = Rough cut, tolerance is -0/+6.4 mm (-0 / +0.25”) Example: CL-840-LIN01-PC0-1220R: ChromaLit Linear, profile 1, 80CRI, 4000K CCT, polycarbonate, 1220 mm length, rough cut Minor Product Change Policy The rigorous qualification testing of ChromaLit products ensures product performance. Slight cosmetic changes which do not affect the form fit or function of the product may occur as Intematix continues product optimization. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Optical Characteristics For use with blue pump LEDs, reference operation at 25oC. Product Description Nominal CCT1 (K) Color Consistency2 (SDCM) Min CRI1,4 Minimum CE3 (Lm/Wrad) Typical CE3 (Lm/Wrad) CL-927-LIN01-PC0 Linear remote phosphor system, white off-state appearance 2700 3 90 160 170 CL-830-LIN01-PC0 Linear remote phosphor system, white off-state appearance 3000 3 80 200 210 CL-930-LIN01-PC0 Linear remote phosphor system, white off-state appearance 3000 3 90 170 180 CL-835-LIN01-PC0 Linear remote phosphor system, white off-state appearance 3500 3 80 205 215 CL-840-LIN01-PC0 Linear remote phosphor system, white off-state appearance 4000 3 80 210 220 CL-850-LIN01-PC0 Linear remote phosphor system, white off-state appearance 5000 4 80 210 220 Performance Characteristics Product CL-927-LIN01-PC0 Nominal Typical Min CCT1 CE3 1,4 CRI (K) (Lm/Wrad) 2700 90 170 Typical Performance5 Maximum Recommended Performance6 Blue power per ft. (305mm) Wrad White lumens per ft. (305mm) lm Blue power per ft. (305mm) Wrad White lumens per ft. (305mm) lm 5.7 970 12.0 2040 CL-830-LIN01-PC0 3000 80 210 5.7 1200 12.0 2520 CL-930-LIN01-PC0 3000 90 180 5.7 1030 12.0 2160 CL-835-LIN01-PC0 3500 80 215 5.7 1225 12.0 2580 CL-840-LIN01-PC0 4000 80 220 5.7 1250 12.0 2640 CL-850-LIN01-PC0 5000 80 220 5.7 1250 12.0 2640 Notes 1. Reference Operation values included in the table above assume use of the ChromaLit Linear product in a specific reference design. Please refer to application notes for details on the reference design and operational guidelines. Intematix maintains a tolerance of +7% on luminous flux and radiant watt measurements. CRI values are minimums. 2. Color Consistency is defined as variation from part to part, color over angle within a part from -90 to +90 degrees from the vertical axis part, and over the length of the product. Color consistency is dependent on the average dominant wavelength of blue LEDs. ChromaLit will achieve the color consistency values indicated in the table above with uniform blue LED average dominant wavelength. 2.5nm (+1.25nm) of average blue LED wavelength variation will provide 4 SDCM of color consistency for 2700K, 3000K, 3500K and 4000K products and 5 SDCM for 5000K products. 5nm (+2.5nm) of average blue LED dominant wavelength variation will provide 5 SDCM of color consistency for 2700K, 3000K, 3500K and 4000K products and 6 SDCM for 5000K products. Values are approximate; please refer to the ChromaLit binning diagram for exact bin definition. 3. Conversion Efficacy is the luminous flux (white light) output per radiant watt of blue light input to ChromaLit. Wrad is the radiometric power measured in Watts. Conversion efficacy is rated based on reference operation and dominant blue LED wavelength of 455nm (peak wavelength of 450nm) at 25oC. To calculate the white light generated multiply the blue radiant output of the blue pump by the conversion efficiency value. To calculate the white efficacy (lumens per Watt) multiply the conversion efficiency by the wall plug efficiency (WPE) of the blue pump used under the rated use conditions or divide the white lumens by the electrical power consumed by the blue pump under operating conditions. 4. Minimum CRI rating is based on reference design using blue LEDs with average dominant wavelength of 455nm. Blue LED populations with an average wavelength shorter than 455nm may result in CRI’s below specified values. 5. Typical Performance ChromaLit Linear has been designed with the objective of delivering 1250 lumens per linear foot at 4000K 80 CRI. Based on the conversion efficiency of the phosphor this requires a typical blue pump engine generating 5.7 Wrad per linear foot. As conversion efficiency varies with CCT and CRI, lumen per foot values for other CCT and CRI products options will vary. 6. Maximum Recommended Performance ChromaLit Linear has been designed to deliver up to 2500 lumens per linear foot at 4000K 80 CRI. Based on the conversion efficiency of the phosphor this requires a typical blue pump engine generating 12.0 Wrad per linear foot. As conversion efficiency varies with CCT and CRI, lumen per foot values for other CCT and CRI product options will vary. This maximum recommended performance is primarily based on thermal limitations at the system design level. It is possible to achieve higher lumen density values with careful attention to system thermal management considerations. For assistance, please contact the Intematix applications engineering team. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Color Binning Diagram 0.440 CIE y 0.420 0.400 2700K 0.380 3500K 0.360 5000K 3000K 4000K Blackbody 0.340 0.320 0.320 0.340 0.360 0.380 0.400 0.420 0.440 0.460 0.480 CIE x Color Bin Center Points Nominal CCT (K) x y 2700 0.4578 0.4101 3000 0.4338 0.4030 3500 0.4073 0.3917 4000 0.3818 0.3797 5000 0.3447 0.3553 All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Relative Spectral Power Distribution Relative Radiant Power (%) Relative Radiant Power (%) 120% 100% 80% 3000K 80 CRI 3500K 80 CRI 60% 4000K 80 CRI 5000K 80 CRI 40% 2700K 90 CRI 3000K 90 CRI 20% 0% 400 450 500 550 600 650 700 750 Wavelength (nm) Wavelength (nm) Intensity Distribution Luminous Intensity Distribution Diagrams FWHM (Full Width Half Maximum) Beam Angle is 170o All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. 800 Luminous Intensity Polar Distribution Diagram Performance Characteristics Over Wavelength Relative Conversion Efficacy Relative Conversion Efficacy Over Wavelength Average Dominant Wavelength (nm) Note: Relative conversion efficacy does not reflect performance of blue LED over dominant wavelength. All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Relative CIE Chromaticity Shift Over Wavelength Average Dominant Wavelength Δ CIE X Coordinate Δ CIE Y Coordinate 450nm -0.003 -0.014 452.2nm -0.002 -0.007 455nm 0 0 457.5nm 0.001 0.005 460nm 0.001 0.008 Relative CRI Shift Over Wavelength 100 95 90 CRI CRI 85 80 75 70 65 60 450 452.5 455 457.5 Dominant Wavelength (nm) Dominant Wavelength (nm) Relative Conversion Efficacy Relative Conversion Efficacy over Temperature ChromaLit Temperature (oC) All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. 460 Absolute Maximum and Minimum Ratings Description Maximum operating temperature (Tmax1) Minimum operating temperature Maximum storage temperature Minimum storage temperature Response time to full light output Maximum and Minimum Values 90oC -40oC 90oC -40oC 10μs Tmax is the maximum temperature measured on the inner surface of ChromaLit. Please consult application notes for additional information on measurement location. 1 Mechanical Characteristics ChromaLit Linear is delivered in 4-foot (1220 mm) rough cut lengths. The tolerance on the rough cut is defined as -0 / +6.4 mm (-0 / +0.25 inches). This allows for the lighting manufacturer to trim the product to exact length as required for the application to ensure optimal performance. Custom cut and precision cut lengths with smaller cut tolerances are available on demand. Please contact your Intematix sales representative for further information. ChromaLit Linear Mechanical Diagram LIN01 Profile Notes 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Flatness in the linear direction is maintained to a tolerance of 2.7 mm per linear meter (0.032 inches per linear foot). All rights reserved. Product specifications are subject to change without notice. Last updated August, 2017. Reliability and Environmental Ratings Description Temperature / Humidity (non-condensing) Coefficient of Thermal Expansion Flame Rating1 RoHS REACH Typical Values 60oC 90% RH 70 ppm / oC HB RoHS Compliant REACH Compliant Flame rating indicated based on UL rating of bulk material used for ChromaLit Linear. Flammability is dependent on both material and geometry and ChromaLit Linear has been tested to exceed higher flammability ratings in finished lighting products. 1 Handling Considerations Since a dirty or damaged phosphor layer could result in alteration in product performance, ChromaLit Linear should be handled similarly to most optical components. It is best to handle the parts at the edges and prevent mechanical abrasion. If epoxies are used, they must be kept off of the entrance or exit apertures of ChromaLit, since they could greatly impact performance. If parts require cleaning, use a lint free tissue, isopropanol (IPA), or mild detergent. Dry using compressed air (CDA). About Intematix Intematix develops essential phosphor materials to drive the LED lighting revolution. The company’s comprehensive range of products and solutions can be used to build foundations for the world’s LED lighting products and systems including general lighting, displays, automotive and many others. A broad selection of products and innovative delivery systems accelerate time-to-market, improve light quality and efficacy and reduce costs. To learn more about the company, please visit www.intematix.com. 46410 Fremont Boulevard Fremont, CA 94538 Tel: +1 510.933.3300 Fax: +1 510.668.0793 sales@intematix.com www.intematix.com
CL-840-LIN01-PC0-1220R 价格&库存
很抱歉,暂时无法提供与“CL-840-LIN01-PC0-1220R”相匹配的价格&库存,您可以联系我们找货
  • 1250+140.842741250+18.21132
