N286-01GSX-MLC
N286-01GSX-MLC
    TRIPPLITE
    TXRXSFP1GBPS850NM
N286-01GSX-MLC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States HP J4858C Compatible SFP Transceiver, 1000Base-SX, DDM, Multimode LC, 850 nm, 550 m MODEL NUMBER: N286-01GSX-MLC Highlights ● Supports data transfer rates up to 1 Gbps ● Transmits up to 1,804 ft. (550 m) with 50/125 MMF cabling ● Transmits up to 722 ft. (220 m) with 62.5/125 MMF cabling ● Complies with MSA standards ● 100% compatible with HP networking hardware System Requirements For a list of compatible switches, see the Switch Compatibility document in the Resources tab or the Technical Support page. Package Includes Adds an LC female connector to your HP 10/100/1000 network equipment. Description The N286-01GSX-MLC HP J4858C Compatible 1000Base-SX LC SFP Transceiver with an LC female connector functions just like the HP J4858C transceiver module and is designed to operate with HP networking equipment. It also meets or exceeds the J4858C’s original specifications and complies with MSA (Multi-Source Agreement) standards. This 1000Base-SX transceiver is fully hot-pluggable, so you can install it without shutting down the network or rebooting your device. It supports data transfer rates up to 1 Gbps with 850 nm wavelength signaling. It transmits across 1,804 feet (550 meters) of 50/125 MMF cabling or 722 feet (220 meters) of 62.5/125 MMF cabling. The N286-01GSX-MLC also supports digital diagnostics monitoring (DDM), so you can monitor optical output power, optical input power, temperature, laser bias current and transceiver supply voltage. Features 1000Base-SX Transceiver with LC Connector ● Hot-pluggable for installation without rebooting or shutting down ● Data transfer rates up to 1 Gbps ● Transmits up to 1,804 ft. (550 m) with 50/125 MMF cabling ● Transmits up to 722 ft. (220 m) with 62.5/125 MMF cabling ● 850 nm wavelength signaling ● Supports DDM Designed for Use with HP Networking Equipment ● Functionally equivalent to HP J4858C ● Meets or exceeds J4858C specs ● Complies with MSA standards Specifications 1/3 ● N286-01GSX-MLC HP J4858C Compatible 1000Base-SX LC SFP Transceiver ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332197443 Brand Compatibility HP PHYSICAL Shipping Dimensions (hwd / in.) 1.10 x 2.70 x 4.80 Shipping Dimensions (hwd / cm) 2.79 x 6.86 x 12.19 Shipping Weight (lbs.) 0.40 Shipping Weight (kg) 0.18 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 0,84 x 1,32 x 5,69 Unit Weight (lbs.) 0.05 Unit Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 32 to 158 °F (0 to 70 °C) Storage Temperature Range -40 to 185 F (-40 to 85 C) Relative Humidity 5 to 95% RH, Non-Condensing Operating Temperature 32 to 158 °F (0 to 70 °C) COMMUNICATIONS Network Compatibility 1 Gbps (Gigabit) Wavelength 850nm Transmission Distance 550 m CONNECTIONS Side A - Connector 1 SFP+ (MALE) Side B - Connector 1 LC DUPLEX (FEMALE) FEATURES & SPECIFICATIONS Data Transfer Rate 1 Gbps Optical Port LC Multi-Source Agreement (MSA) Compliant Yes WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N286-01GSX-MLC
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于工业控制、医疗设备、通信设备等领域。
7. 封装信息:采用DIP6封装,尺寸为9.1mm x 3.6mm。
N286-01GSX-MLC 价格&库存
很抱歉,暂时无法提供与“N286-01GSX-MLC”相匹配的价格&库存,您可以联系我们找货
