1000 Eaton Boulevard
Cleveland, OH 44122
United States
HP J4859C Compatible SFP Transceiver,
1000Base-LX, DDM, Singlemode LC, 1310 nm, 10
km
MODEL NUMBER: N286-01GLX-SLX
Highlights
Supports data transfer rates up
to 1 Gbps
Transmits up to 6 mi. (10 km)
with 9/125 SMF cabling
Supports digital diagnostic
monitoring (DDM)
Complies with MSA standards
100% compatible with HP
networking hardware
System Requirements
For a list of compatible switches,
see the Switch Compatibility
document in the Resources tab or
the Technical Support page.
Package Includes
Adds a duplex LC female connector to your HP 10/100/1000 network equipment.
Description
The N286-01GLX-SLX HP J4859C Compatible 1000Base-LX LC SFP Transceiver with a duplex LC
female connector functions just like the HP J4859C transceiver module and is designed to operate with
HP networking equipment. It also meets or exceeds the J4859C’s original specifications and complies with
MSA (Multi-Source Agreement) standards.
This 1000Base-LX transceiver is fully hot-pluggable, so you can install it without shutting down the
network or rebooting your device. It supports data transfer rates up to 1 Gbps with 1310 nm wavelength
signaling. It transmits across six miles (10 kilometers) of 9/125 SMF cabling.
The N286-01GLX-SLX also supports DDM, so you can monitor optical output power, optical input power,
temperature, laser bias current and transceiver supply voltage. It is electrical interface-compliant with
SFF-8431 specification.
Features
1000Base-LX Transceiver with Duplex LC Connector
● Hot-pluggable for installation without rebooting or shutting down
Data transfer rates up to 1 Gbps
Transmits up to 6 miles (10 km) with 9/125 SMF cabling
Supports DDM
Electrical interface-compliant with SFF-8431 specification
1310 nm wavelength signaling
Designed for Use with HP Networking Equipment
● Functionally equivalent to HP J4859C
Meets or exceeds J4859C specs
Specifications
1/3
SFP Transceiver
Owner’s manual
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332197436
Brand Compatibility
HP
PHYSICAL
Shipping Dimensions (hwd / in.)
1.10 x 3.60 x 4.60
Shipping Dimensions (hwd / cm)
2.79 x 9.14 x 11.68
Shipping Weight (lbs.)
0.10
Shipping Weight (kg)
0.05
Unit Dimensions (hwd / in.)
0.000 x 0.000 x 0.000
Unit Dimensions (hwd / cm)
0,84 x 1,32 x 5,69
Unit Weight (lbs.)
0.05
Unit Weight (kg)
0.02
ENVIRONMENTAL
Operating Temperature Range
32 to 158 °F (0 to 70 °C)
Storage Temperature Range
-40 to 185 F (-40 to 85 C)0.33 x 0.52 x 2.24
Relative Humidity
10 to 85% RH, Non-Condensing
COMMUNICATIONS
Network Compatibility
1 Gbps (Gigabit)
Wavelength
1310nm
Transmission Distance
10 km
CONNECTIONS
Side A - Connector 1
SFP+ (MALE)
Side B - Connector 1
LC DUPLEX (FEMALE)
FEATURES & SPECIFICATIONS
Data Transfer Rate
1 Gbps
Optical Port
LC
Multi-Source Agreement (MSA)
Compliant
Yes
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
2/3
Cleveland, OH 44122
United States
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
3/3
很抱歉,暂时无法提供与“N286-01GLX-SLX”相匹配的价格&库存,您可以联系我们找货
