N286-10GSR-MDLC
N286-10GSR-MDLC
    TRIPPLITE
    Fiber Optic Transceiver Module 11.1Gbps 850nm LC Duplex Pluggable, SFP+
N286-10GSR-MDLC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cisco-Compatible SFP-10G-SR 10Gbase-SR SFP+ Transceiver, DDM, Multimode LC, 850nm, 300M Highlights ● Cisco switch compatible...Comparable to SFP-10G-SR= ● Compliant with SFP MultiSource Agreement (MSA) standards ● 300 meter transmission distance using 10Gb 50/125 MMF cabling MODEL NUMBER: N286-10GSR-MDLC System Requirements For a list of compatible switches, see the Switch Compatibility document in the Resources section of this model’s web page, or in its Technical Support page. Package Includes Description Tripp Lite N286-10GSR-MDLC, SFP+ (mini-GBIC) transceiver module, is designed for use with Cisco networking equipment, and is functionally equivalent to Cisco part number SFP-10G-SR=. This transceiver is manufactured to meet or exceed the specifications of the original Cisco unit, and to comply with Multi Source Agreement (MSA) standards. Tripp Lite guarantees 100% compatibility with Cisco networking hardware, and will initialize and perform identically to an OEM transceiver. See "Features" tab for a list of most common Cisco devices used with this model transceiver. Features ● Cisco switch compatible...Comparable to SFP-10G-SR= ● Compliant with SFP Multi-Source Agreement (MSA) standards ● 300 meter transmission distance using 10Gb 50/125 Multimode cabling ● 850nm wavelength VCSEL Laser ● Duplex LC Connector ● 10Gbase-SR transceiver supports data transfer rates up to 11.1Gbps using 10Gb 50/125 MMF cabling ● Electrical interface compliant with SFF-8431 ● Supports Digital Diagnostic Monitoring (DDM) ● Hot-pluggable Specifications OVERVIEW UPC Code 037332185495 Brand Compatibility Cisco 1/3 ● N286-10GSR-MDLC ● Quick Start Guide 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Shipping Dimensions (hwd / in.) 0.87 x 2.87 x 4.84 Shipping Dimensions (hwd / cm) 2.21 x 7.29 x 12.29 Shipping Weight (lbs.) 0.10 Shipping Weight (kg) 0.05 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 0,84 x 1,32 x 5,69 Unit Weight (lbs.) 0.05 Unit Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 32 to 158 °F (0 to 70 °C) Storage Temperature Range -40F to 185F Relative Humidity 5 to 95% RH, Non-Condensing Operating Temperature 32 to 158 °F (0 to 70 °C) COMMUNICATIONS Network Compatibility 10 Gbps Wavelength 850nm Transmission Distance 300 m CONNECTIONS Side A - Connector 1 SFP+ (MALE) Side B - Connector 1 LC DUPLEX (FEMALE) FEATURES & SPECIFICATIONS Data Transfer Rate 10 Gbps Optical Port LC Multi-Source Agreement (MSA) Compliant Yes WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N286-10GSR-MDLC 价格&库存
很抱歉,暂时无法提供与“N286-10GSR-MDLC”相匹配的价格&库存,您可以联系我们找货
