N286-10GLR-SLC
N286-10GLR-SLC
    TRIPPLITE
    TXRXSFP10GBPS1310NM
N286-10GLR-SLC 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Cisco-Compatible SFP-10G-LR SFP Transceiver, 10GBase-LR, DDM, Singlemode LC , 1310 nm, 10 km MODEL NUMBER: N286-10GLR-SLC Highlights ● Supports data transfer rates up to 10 Gbps ● Transmits up to 6 mi. (10 km) with 9/125 SMF cabling ● Supports digital diagnostics monitoring (DDM) ● Complies with MSA standards ● 100% compatible with Cisco networking hardware System Requirements For a list of compatible switches, see the Switch Compatibility document in the Resources tab or the Technical Support page. Package Includes Adds a duplex LC female connector to your Cisco 10/100/1000 network equipment. Description The N286-10GLR-SLC Cisco SFP-10G-LR Compatible 10GBase-LR LC SFP Transceiver with a duplex LC female connector functions just like the Cisco® SFP-10G-LR transceiver module and is designed to operate with Cisco networking equipment. It also meets or exceeds the SFP-10G-LR’s original specifications and complies with MSA standards. This 10GBase-LR transceiver is fully hot-pluggable, so you can install it without shutting down the network or rebooting your device. It supports data transfer rates up to 10 Gbps with 1310 nm wavelength signaling. It transmits across six miles (10 kilometers) of 9/125 SMF cabling. Its metallic housing allows low EMI. The N286-10GLR-SLC also supports DDM, so you can monitor optical output power, optical input power, temperature, laser bias current and transceiver supply voltage. It is electrical interface-compliant with SFF-8431 specification, and supports up to 11.1 Gbps bi-directional communication. Features 10GBase-LR Transceiver with Duplex LC Connector ● Hot-pluggable for installation without rebooting or shutting down ● Supports data transfer rates up to 10 Gbps ● Transmits up to 6 mi. (10 km) with 9/125 SMF cabling ● Metallic housing for low EMI ● Supports up to 11.1 Gbps bi-directional communication ● Supports DDM ● Electrical interface-compliant with SFF-8431 specification ● 1310 nm wavelength signaling Designed for Use with Cisco Networking Equipment ● Functionally equivalent to Cisco SFP-10G-LR ● Meets or exceeds SFP-10G-LR specs ● Complies with MSA standards 1/3 ● N286-10GLR-SLC Cisco SFP10G-LR Compatible 10GBaseLR LC SFP Transceiver ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Specifications OVERVIEW UPC Code 037332197429 Brand Compatibility Cisco PHYSICAL Shipping Dimensions (hwd / in.) 1.10 x 3.60 x 4.50 Shipping Dimensions (hwd / cm) 2.79 x 9.14 x 11.43 Shipping Weight (lbs.) 0.20 Shipping Weight (kg) 0.09 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 0,84 x 1,32 x 5,69 Unit Weight (lbs.) 0.05 Unit Weight (kg) 0.02 ENVIRONMENTAL Operating Temperature Range 32 to 158 °F (0 to 70 °C) Storage Temperature Range -40 to 185 F (-40 to 85 C) Relative Humidity 10 to 85% RH, Non-Condensing Operating Temperature 32 to 158 °F (0 to 70 °C) COMMUNICATIONS Network Compatibility 10 Gbps Wavelength 1310nm Transmission Distance 10 km CONNECTIONS Side A - Connector 1 SFP+ (MALE) Side B - Connector 1 LC DUPLEX (FEMALE) FEATURES & SPECIFICATIONS Data Transfer Rate 10 Gbps Optical Port LC Multi-Source Agreement (MSA) Compliant Yes 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
N286-10GLR-SLC 价格&库存
很抱歉,暂时无法提供与“N286-10GLR-SLC”相匹配的价格&库存,您可以联系我们找货
