HRFC-AT5K-A15A(40)
HRFC-AT5K-A15A(40)
    HRS(广濑)
    CONN FC ATTENUATOR 15DB 10MW
HRFC-AT5K-A15A(40) 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. FC Type Fixed Attenuators MU SC FC Harsh Environment ■Features 1. Excellent operational gualities 2. Maxmum input power : 250mW Attenuators 3. Please contact us if you have any requests. Hirose will offer excellent solutions to meet your reguirements Important Notice Plug key width : 2.1mm Adapter key width :2.2mm Terminators ■Applications Power level adjustment of optical fiber communication networks. 77 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ■Product Specifications MU ●High Power FC-Type Fixed Attenuator (Max. input power : 250mW) Ratings Operating temperature range -25°C to +70°C Storage temperature range -25°C to +85°C Max. Input Power 250mW Fiber type SM Mechanical Harsh Environment FC Environmental Characteristis Characteristis SC Optical Characteristis Item Test Method Return Loss Specifications ≥40dB Attenuation Measurement at a point within the respective warelength range of 1310 ± 30 nm and 1550 ± 30(DSF). Adapter gauge holding force Zirconia gauge of 2.499 ±0.0005 mm diameter. 2.0N to 3.9N Durability (cycles, mating/unmating) 500 times Vibration Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, acceleration of 98.1m/s2, 3 hours in each of the 3 axis. Shock Acceleration of 981 m/s2, 6 ms duration, sine halfwave waveform, 3 cycles in each of the 3 axis. Composite temperrature -Humidity cyclic test 1) Meets Attenuation/Return Loss requirements. Temperature : -10°C to 65°C, humidity : 90% to 96% 2) No visible dislocation of clamp or cable. Time : 240 hours(10cycles) Change of temperature Temperature: -25°C / +70°C Time: 60 / 60 / 60 / 60 (Minutes) Cycles :100 cycles Dry heat 500 hours at 85°C Cold 500 hours at -25°C Salt Mist 48 hours in a 5% concentration of salt mist See the attenuation table on the next page. No significant corrosion. Attenuators ■Materials Part Material Coupling Copper alloy Body Stainless steel Ferrule Zirconia Split sleeve Zirconia ■Ordering Information HRFC - AT 11 K - A ** 1 Terminators 1 Series name : HRFC 2 3 4 5 6 4 Polishing code K: AdPC(≥40dB) 2 Attenuator 5 Optical fiber type A: Single Mode 3 Specification series 6 Attenuation : 01,02,03,04,05,06, 07,08,09,10,15,20,25 78 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative. ●High Power SC-Type Fixed Attenuator (Max. input power : 250mW) Ø10 FC- MU M8∞0.75 30 CL No. Attenuation 820-8001-7 01dB Attenuation Tolerance HRFC-AT11K-A02 820-8002-0 02dB HRFC-AT11K-A03 820-8003-2 03dB HRFC-AT11K-A04 820-8004-5 04dB HRFC-AT11K-A05 820-8005-8 05dB HRFC-AT11K-A06 820-8006-0 06dB HRFC-AT11K-A07 820-8007-3 07dB ±0.7dB HRFC-AT11K-A08 820-8008-6 08dB ±0.8dB HRFC-AT11K-A09 820-8009-9 09dB ±0.9dB HRFC-AT11K-A10 820-8010-8 10dB ±1.0dB HRFC-AT11K-A15 820-8011-0 15dB HRFC-AT11K-A20 820-8012-3 20dB HRFC-AT11K-A25 820-8013-6 25dB Return Loss Wavelength Split sleeve Fiber type ≥40dB 1310nm 1550nm Zirconia SM SC Part Number HRFC-AT11K-A01 ±0.5dB ±0.6dB FC ±1.5dB Harsh Environment Note : Please take utmost care when inserting a FC plug into a FC attenuator. When applying excessive force to the FC plug or inserting in an odd angle, the zirconia sleeve within the attenuator might be damaged. Attenuators Terminators 79 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hirose Electric: HRFC-AT5K-A15A(40)
HRFC-AT5K-A15A(40) 价格&库存
很抱歉,暂时无法提供与“HRFC-AT5K-A15A(40)”相匹配的价格&库存,您可以联系我们找货
