COM-11222
COM-11222
    SPARKFUNELECTRONICS
    Electroluminescent (EL) Backlighting Inverter 3.54" L x 1.34" W x 0.79" H (90.00mm x 34.00mm x 20.00...
COM-11222 数据手册
Page 1 of 2   EL Inverter - Battery Pack COM -1 1222 RO HS   images are CC BY-NC-SA 3.0 Description: Even though the Tron movies have been out for a while, electroluminescence is still the coolest thing since sliced bread. The only downer is carrying around a battery pack and bulky external inverter. Good news, we’ve found a slim battery-powered inverter for your next small EL project! This little black box takes two AA batteries and has two JST connectors for your EL wire/panel/tape. There are two modes: continuous on and flashing and it even has a belt clip! We got a chance to play with these inverters and you can easily hack these to work with our Li-Po batteries (yep, at the fully charged 4.2V). To get inside, you’ll need to remove a pair of screws (one is hiding under the CE sticker) and afterwards you’ll want to wrap things up with electrical tape to avoid getting shocked (it just tingles a little). The following current readings were taken while the pack was connected to one or more of our 3m EL wire: • • • • Single strand always on: 190 to 260mA Single strand blinking: 90 to 120mA Two strands always on: ~300mA Two strands blinking: ~150mA Different color strands were used but the lengths were identical. Your mileage may vary. If you need to pick up some Li-Po batteries, electrical tape or EL wire to hack your own battery pack, check the related items below! Page 2 of 2 Dimensions: 20 x 34 x 90mm https://www.sparkfun.com/products/11222 11/24/2015
COM-11222 价格&库存
很抱歉,暂时无法提供与“COM-11222”相匹配的价格&库存,您可以联系我们找货
