1350
1350
    ADAFRUIT
    INVERTERMINICOINCELLELWIRE
1350 数据手册
      EL Wire Coin Cell Mini Inverter PRODUCT ID: 1350     Description A really tiny portable inverter for EL wire. Powers off of a single CR2032 coin battery (not included!), it  can drive up to 50cm / 20 inches of our high‐brightness EL wire or 10cm x 1cm long piece of EL tape for  3 hours (or longer if the EL wire is less than 50cm long). There is a button for selecting steady/blink/off  modes. Comes with a 2.5mm pitch female JST connector. Like all inverters we've used, the 2000 Hz  oscillation is slightly audible.    This inverter can only power 10 CENTIMETERS (2.5 INCHES) of 1cm wide tape or a 3cm x 3cm / 1.25" x  1.25" piece of EL panel    To connect a piece EL wire to this, you'll want a male connector wire    Soldering to EL wire is a little tricky but luckily we wrote a detailed step‐by‐step tutorial!  https://cdn‐learn.adafruit.com/downloads/pdf/el‐wire.pdf  Technical Details Dimensions:  o o o Dimensions: 46mm x 24mm x 10mm / 1.8" x .9" x .4"  Cable Length: 75mm / 3.0"  Weight: 10g        https://www.adafruit.com/product/1350 8‐8‐17
很抱歉,暂时无法提供与“1350”相匹配的价格&库存,您可以联系我们找货
