564
564
    ADAFRUIT
    POCKETINVERTERELWIRE4-AAA
564 数据手册
      EL wire 4xAAA pocket inverter PRODUCT ID: 564     Description A small, portable inverter for EL wire. Powers off of 4 AAA batteries (not included!), it can drive 3‐4  meters (10 to 13 feet) of our high‐brightness EL wire OR 1 meter (3 feet) of EL tape OR a 10cmx10cm  piece of EL panel for about 7 hours.    There is a switch for selecting steady/blink/off modes. Comes with four 2.5mm pitch female JST  connectors, standard for all the EL wire and tape we carry. The JST cables snap into the inverter, so if  you don't need all 4 cables, you can use as few as you want. The inverter does not 'sequence' the 4  cables, so if you use 'blink mode' all the strands will blink at the same time.    There is a 1.7mm DC jack on the side so you can put in 5‐6VDC to power this off of a different battery  or power source, This cable has a matching DC plug on the end)    You can plug any of our EL wire/tape into this inverter directly. To connect a 'raw' piece EL wire to this,  you'll want a male connector wire    The EL inverter requires a 'load' to stabilize itself. Do not run the inverter without at least 2 ft of EL  wire attached! Otherwise the inverter can spike and damage itself    Like all inverters we've used, the 2000 Hz oscillation is slightly audible. To reduce the squeaking, we  suggest opening up the case padding it with thick foam tape/weatherstripping. Squirting some hot glue  around the capacitors may also help. We managed to get it silent this way.    Check out our EL TRON bag tutorial for ideas!    https://cdn‐learn.adafruit.com/downloads/pdf/tron‐bag.pdf    Soldering to raw EL wire is a little tricky but luckily we wrote a detailed step‐by‐step tutorial! The  tutorial also covers a lot of information about EL and how it works.  https://cdn‐learn.adafruit.com/downloads/pdf/el‐wire.pdf  Technical Details Dimensions:  o o o Inverter Size: 85mm x 55mm x 22mm (3.4in x 2.2in x 0.85in)  JST cable length: approx. 20 cm  Weight (without batteries): 60g                                                       https://www.adafruit.com/product/564 8‐8‐17
很抱歉,暂时无法提供与“564”相匹配的价格&库存,您可以联系我们找货
  • 1+87.404681+11.35846
  • 1+87.235801+11.32720
库存:2
