832
832
    ADAFRUIT
    TERMINAL STRIP STD 1 POS
832 数据手册
      EL Wire 12V Sound Activated Pocket Inverter PRODUCT ID: 832     Description A small, portable inverter for EL wire with an audio input! This inverter has a little microphone and will  light the connected EL according to the surrounding audio volume. Makes for an easy reactive project.    This inverter requires 12VDC input (it works great with our 8xAA battery holder) and it can drive 2‐3  meters (7 to 10 feet) of our high‐brightness EL wire OR 1 meter (3 feet) of EL tape OR a 10cmx10cm  piece of EL panel continuously for about 48 hours (off of 4xAA's).    There is a switch for selecting steady/sound/off modes ‐ steady is 'always on'. Comes with a single  2.5mm pitch female JST connectors, standard for all the EL wire and tape we carry. There's also two  power wires, you'll need to connect these to a 12VDC power source. The white striped wire goes to  +12V, the plain black wire goes to ground.    You can plug any of our EL wire/tape into this inverter directly. To connect a 'raw' piece EL wire to this,  you'll want a male connector wire    The EL inverter requires a 'load' to stabilize itself. Do not run the inverter without at least 2 ft of EL  wire attached! Otherwise the inverter can spike and damage itself    Like all inverters we've used, the 2000 Hz oscillation is slightly audible. To reduce the squeaking, we  suggest opening up the case padding it with thick foam tape/weatherstripping. Squirting some hot glue  around the capacitors may also help. We managed to get it silent this way.    Check out our EL TRON bag tutorial for ideas, and our EL wire couch video too!  https://cdn‐learn.adafruit.com/downloads/pdf/tron‐bag.pdf   https://www.youtube.com/watch?v=7si_73v31I0    Soldering to raw EL wire is a little tricky but luckily we wrote a detailed step‐by‐step tutorial! The  tutorial also covers a lot of information about EL and how it works.  https://cdn‐ learn.adafruit.com/downloads/pdf/el‐wire.pdf  Technical Details Dimensions:  o o Inverter Size: 85mm x 55mm x 22mm (3.4in x 2.2in x 0.85in)  JST cable length: approx. 20 cm  Weight: 41.80g    https://www.adafruit.com/product/832 8-8-17
很抱歉,暂时无法提供与“832”相匹配的价格&库存,您可以联系我们找货
