BXA-12529/PS1
BXA-12529/PS1
    JKLCOMPONENTS
    CCFL and UV Lamps Inverter 12V Input 850V, 5.5mA Output 1.97" L x 1.37" W x 1.00" H (50mm x 35mm x 2...
BXA-12529/PS1 数据手册
REV. " A B .~ ~~. ~ [2] 06.35 j / iV~ t ... .. .. .. . ... .. . . :::: : :: :: r- 9.5 - 12.7 WIRE RETENTION -AREA .. .'.. . . .. .. ~ !.O j 1 t C /' 6.35 31 NOTE@) t- 1 V :: I 9 9.5 t t _ RED CD r-. ~ YELLOW~ Vin HV () YELLOW~ ~ BLKCD GND -0GND BLACK ~ GND BLACK 305±13 (INPUT LEADS) 203±13 ~ f:: ~ ~ I- -6.35 +12VDC (HIGH VOLTAGE OUTPUT LEADS) 1114/98 WIRE DESIGN PLACEMENT 1219/03 CORRECT. ADD LOCATION OF WIRES 7/12107 IN COMPOUND & NOTES n 0 6.35 Q [2] 02.7 23.0 DEEP NOTE@) DATE DESCRIPTIONIECO NO. PROD. RELEASED NOTES: CD REVERSE POLARITY TO INVERTER INPUT WILL CAUSE AN OPEN CIRCUIT IN INTERNAL FUSE. r::::: ® ~ ~ ~ ~ "" "" ® U ® WIRE SIZE 22 AWG, SOFT FLEXIBLE PVC INSULATION NOMINAL O.D. 2.3mm TEMPERATURE RANGE -80 TO +105 C. ® REFERENCE DRAWING BXA-12529 FOR SINGLE LAMP OPERATION. 25.4 @) USE 6-32-0.75 INCH LONG TYPE F SCREWS IN LOCATIONS. OPERATING SPECIFICATIONS CHARACTERISTICS INPUT VOLTAGE: (vdc) INPUT CURRENT: (rnA) OUTPUT VOLTAGE: (Vrrns) OUTPUT CURRENT 2 X (rnA) OUTPUT FREQUENCY: (kHz) OPERATING TEMP: (CELSIUS) MIN TYP MAX 10.0 200 950 4.5 25 0 12.0 260 1000 5.5 35 25 13.2 500 1050 6.5 45 50 METRIC ~ THIRD ANGLE PROJECTION DRAWN BY DIMENSIONS ARE IN MILLIMETERS TOLERANCE UNLESS OTHERWISE SPECIFIED 1 PL+/2 PL+/- ANGLE+/APP'I/'DBY L. WENGSTROM L.R. 0.5 0.3 JKL COMPONENTS CORPORATION TITLE 0 12 VDC INPUT, DUAL OUTPUT, ENCAPSULATED CCFL INVERTER DATE SIZE FSCMNO. 7/12107 A 55335 - CAD DRAWINGMANUAL REVISIONS NOT PERMITTED I.......• NONE DRAWING NO. DATE BXA-12529/PS 1 11/4/98 I~;~'U" 7112107 I~:c 11SH;~1
BXA-12529/PS1 价格&库存
很抱歉,暂时无法提供与“BXA-12529/PS1”相匹配的价格&库存,您可以联系我们找货
