1349
1349
    ADAFRUIT
    INVERTERMINI1-AAAELWIRE
1349 数据手册
      EL Wire 1xAAA Mini Inverter PRODUCT ID: 1349          Description A really tiny portable inverter for EL wire. Powers off of a single AAA battery (not included!), it can  drive up to 50cm / 20 inches of our high‐brightness EL wire or 10cm x 1cm long piece of EL tape for 3  hours (or longer if the EL wire is less than 50cm long). There is a switch on the side for selecting  steady/blink/off modes. Comes with a 2.5mm pitch female JST connector. Like all EL inverters we've  used, the 2000 Hz oscillation is slightly audible.    This inverter can only power 10 CENTIMETERS (2.5 INCHES) of 1cm wide tape or a 3cm x 3cm / 1.25" x  1.25" piece of EL panel     To connect a piece EL wire to this, you'll want a male connector wire if it isn't already attached    Soldering to EL wire is a little tricky but luckily we wrote a detailed step‐by‐step tutorial!  https://cdn‐learn.adafruit.com/downloads/pdf/el‐wire.pdf    Technical Details Dimensions:  o o o Size: 26.52mm / 1" x 50.47mm / 1.98" x 14.5mm / 0.57"  Cable Length: 82.55mm / 3.25"  Weight: 14.84g                                                               https://www.adafruit.com/product/1349 8‐8‐17
很抱歉,暂时无法提供与“1349”相匹配的价格&库存,您可以联系我们找货
  • 1+43.619421+5.65024
