BXA-12594-5M
BXA-12594-5M
    JKLCOMPONENTS
    INVERTER DIMMING SINGLE 12V 5MA
BXA-12594-5M 数据手册
REV PERFORMANCE SPECIFICATIONS: DESCRIPTION SYM MIN TYP MAX INPUT VOLTAGE VIN 10.0 12.0 16.0 INPUT CURRENT liN --- 230 --OUTPUT VOLTAGE VL 900 1000 --OUTPUT CURRENT 4.0 5.0 6.0 IL OSC. FREQUENCY Fo 45.0 55.0 65.0 Fpw 435 455 475 PWM FREQUENCY TESTED WITH I EACH 3MM X 164MM LAMP, AT VIN= 12.0V ± O.IV. UNITS V DC MA DC V RMS MA RMS KHz Hz 25°C, ABSOLUTE MAXIMUM RATINGS: MAXIMUM INPUT VOLTAGE: MAXIMUM RELATIVE HUMIDITY: OPERATING CHARACTERISTICS: INPUT VOLTAGE RANGE: NOMINAL INPUT POWER: OUTPUT DIMMING RANGE (R MODE): OUTPUT DIMMING RANGE (V MODE): OPERATING TEMPERATURE RANGE: STORAGE TEMPERATURE RANGE: 8.0 VDC TO 16.0 VDC 5.0 WATTS 33% TO 100% N/A O°C TO 60°C -20°C TO 70°C CONTROL FUNCTIONS: CNT (INPUT PIN 3) IS USED AS AN INHIBIT FUNCTION, "GND" EQUALS ON. "+V" OR "OPEN" EQUALS OFF. NOTE: THE SWITCH AND POTENTIOMETER SHOWN ON THE WIRING DIAGRAM ARE NOT A PART OF THE BXA-12594-5M INVERTER. THESE PARTS ARE AVAILABLE FROM MOST ELECTRONIC PARTS DISTRIBUTORS. 712/04 16.0 VDC 90% 95.0 t 11.0 J 2.75 r- r""1 1{.0 ~ .I .1 68.0 t CN-2 0 1 16.5 MAX. 1KJ CN-1 (() 2.2---.l ~ ~ I2PLCSI -------------------------- 6.5MAX 51 I I T T I CF I WIRING DIAGRAM: CN1 R MODE DIMMING: VRI AND VR2 (INPUT PINS 4 AND 5) ARE USED TO PROVIDE, THE DIMMING FUNCTION, '0" OHMS EQUALS 100% LIGHT OUTPUT, "10K" OHMS EQUALS 33% LIGHT OUTPUT. DATE DESCRIPTION/ECO NO. ENGR. RELEASE TO CAD lin ---.... +12VDC GND L~QK I t -(j) Vin -® GND GND -@ CNT -@ Vr2 -® ± CN2 --II N/C CD- r-- N/C
BXA-12594-5M 价格&库存
很抱歉,暂时无法提供与“BXA-12594-5M”相匹配的价格&库存,您可以联系我们找货
