BXA-12617C-6M
BXA-12617C-6M
    JKLCOMPONENTS
    CCFL and UV Lamps Inverter 12V Input 1200V Output 2.76" L x 0.71" W x 0.24" H (70mm x 18mm x 6mm) Ch...
BXA-12617C-6M 数据手册
REV 70±1.0 IP t 1 CN1 18±O.5 D 12±O.5 ~ • J .rr- .rr- U r-3 D ~ 3±O.5 ~ 1 F1 r - fJ - U r~ , t( n u ~ A -I 102 8 . DATE DESCRIPTIONIECO NO. RELEASE & CANCEL P-9808-12 8114/01 CONVERTED TO CAD 3/4/03 L \. j/ CN2 3- L O 1- Po , D=b 5±O.5 , 51±1.0 .-6 MAX. -- I Fll n -- 0 0 I 'l ~ JKL PART NUMBER: BXA-12617C-6M NO. PIN NUMBER MATING WIRE HARNESS 1 INPUT VOLTAGE (+V) CN1 2 L=ON (INHIBIT 1 PWM) CN2 3 INPUT VOLTAGE (GND) 1 HIGHVOLTAGEOUT 2 NlC 31 LAM I' BXC-10580 BXC-10643 NOTE: MATING CONNECTORS ARE NOT INCLUDED WITH INVERTER. JKL WIRE HARNESS BXC-10580 AND BXC-10643 CAN BE ORDERED SEPARATELY. It ~ II OPERATING SPECIFICATIONS CHARACTERISTICS INPUT VOLTAGE: (vdc) INPUT CURRENT@ 12V: (rnA) INPUT WATTS OPEN CIRCUIT VOLTS (Vrms) LAMP CURRENT (mArms) FREQUENCY (kHz PWM FREQUENCY (TYP.) (kHz) PWM PERCENT (TYP.) (%) OPERATING TEMP: (CELSIUS) STORAGE TEMP.: (CELSIUS) METRIC ~ THIRD ANGLE PROJECTION DRAWN BY DIMENSIONS ARE IN MILLIMETERS TOLERANCE. UNLESS OTHERWISE SPECIFIED 1 PL +/2 PL +/ANGLE +/_ APPV'D BY L. WENGSTROM F.D. 0.3 MIN TYP MAX 10.8 12.0 380 4.6 1200 6.2 60 0.5 13.2 580 7.0 5.5 50 0.1 15 0 -20 JKL -7.5 70 --- --- 25 25 50 70 COMPONENTS CORPORATION TITLE 12 VOLT DC INPUT INVERTER 0 CA'" 3/4/03 - CAD DRAWINGMANUAL REVISIONS NOT PERMITTED A I~;~~ SCALE DRAWING NO. RELEASED NONE DATE BXA-12617C-6M 8114/01 1REVISION DATE 314/03 1 REV. NO. A~ I 1 SHEET OF 1
BXA-12617C-6M 价格&库存
很抱歉,暂时无法提供与“BXA-12617C-6M”相匹配的价格&库存,您可以联系我们找货
