BXA-12613-7M
BXA-12613-7M
    JKLCOMPONENTS
    INVERTER DIMMING DUAL 12V 7MA
BXA-12613-7M 数据手册
PERFORMANCE SPECIFICATIONS: DESCRIPTION SYM MIN TYP MAX INPUT VOLTAGE VIN liN 10.8 --- 12.0 INPUT CURRENT 720 13.2 --- MA DC OUTPUT VOLT AG E VL --- 1000 --- V RMS IL 6.0 7.0 8.0 MA RMS OUTPUT CURRENT OSC. FREQUENCY PWM FREQUENCY Fo 45.0 55.0 65.0 Fpw 435 455 475 UNITS V DC "EV ABSOLUTE MAXIMUM RATINGS: MAXIMUM INPUT VOLTAGE: 16.0 VDC MAXIMUM RELATIVE HUMIDITY: 90% DEseRIPTIONlEeO NO. KHz 135.0 Hz TESTED WITH 2 EACH 3MH X 240MM LAMPS, AT 25'C, VIN= 12.0V ± O.IV. •I 105.0 "I 11 OPERATING CHARACTERISTICS: INPUT VOLTAGE RANGE: NOMINAL INPUT POWER: OUTPUT DIMMING RANGE (R MODE): OPERATING TEMPERATURE RANGE: STORAGE TEMPERATURE RANGE: 10.8V DC TO 13.2V DC 10.0 WATTS 40% TO 100% O°C TO 60° -20'C TO 70'C DESCRIPTION INPUT HOUSING TERMINAL CN-1 INPUT HARNESS CN-2& OUTPUT 1 &2 CN-3 HOUSING TERMINAL CN-2& OUTPUT 1 &2 CN-3 HARNESS 2.5 0 J + ~., ~, 0 ~. 0 1,"0 11.0- 02.8 ,---./ 2 PLACES PART NUMBER MFG. ~ ---------------------~ 6.0 I I I 51021-0700 50079-8000 MOLEX f BXC-10630 JKL MATING CONNECTORS: REF. DATE 712104 ENGR. RELEASE TO CAD CN-1 8.0 D =Ett::sfJ I CJ T WIRING DIAGRAM: eN1 IIn~ +12VDC -0 Vin HvI0 '6' Vin N/C ~ BHR-03VS-1 SBH-OOH-PO.5 JST I BXC-10643 (2 required) JKL f@ GND I '4' GND GND --- 10K t I CONTROL FUNCTIONS: ~ RTN Vr2 'i' Vr1 1'3' '-- HV CNT (INPUT PIN 3) IS USED AS AN INHIBIT FUNCTION, "GND" OR "OPEN" EQUALS OFF. "+V" EQUALS ON. R MODE DIMMING: VR1 AND VR2 (INPUT PINS 1 AND 2) ARE USED TO PROVIDE, THE DIMMING FUNCTION, "0" OHMS EQUALS 100% LIGHT OUTPUT, "10K" OHMS EQUALS 40% LIGHT OUTPUT. NOTE: THE SWITCH AND POTENTIOMETER SHOWN ON THE WIRING DIAGRAM ARE NOT A PART OF THE BXA-12613-7M INVERTER. THESE PARTS ARE AVAILABLE FROM MOST ELECTRONIC PARTS DISTRIBUTORS. -II 'i' ~ CN> METRIC ~ THIRD ANGLE PROJECTION DRAWN BY DIMENSIONS ARE IN MILLIMETERS TOLERANCE UNLESS OTHERWISE SPECIFIED 1 PL +/- REF. 2 PL +/ANGLE+/- J.K. DAlE 7/2104 - CAD DRAWINGMANUAL REVISIONS NOT PERMITTED Jf JKL COMPONENTS CORPORATION TITLE a APPVDBY L. WENGSTROM r- ,-- - I I RTNI® N/ci ®- r-- CNT -® ~ 1 CN2 12V DC INPUT, DUAL OUTPUT, DIMMING CCFL INVERTER A IS5335 SCALE NONE DRAWING NO. RELEASED DATE BXA-12613-7M 712/04 I ~ISION DATE I REV. NO. SHEET 1 oF1
BXA-12613-7M 价格&库存
很抱歉,暂时无法提供与“BXA-12613-7M”相匹配的价格&库存,您可以联系我们找货
