NDL-104LP
NDL-104LP
    JKLCOMPONENTS
    INVERTER 20-60CM2 FOR EL LAMP
NDL-104LP 数据手册
MAXIMUM RATINGS ITEMS OPERATING RANGE MAXIMUM RATINGS Input voltage 6Vde Operating temperatura -10 to 50" Storage temperatura -20 to 70" 3.0 to 5.5 V de REUABIUTY DATA CONDITIONS NOTES Temperature shock -20170·Cfor 1 hour each, 10 cycles 1,2,3 Soldering heat rasistanca 260·C 10 seconds 1,2,3 Lead strength 1KG 10 seconds 1,2,3 Vibration Frequency 10 to 55 Hz, amplitude each direction of X, Y, Z) sweep time 1 minutelcycle ITEMS = = =1.5mm (1 hour for 1,2,3 NOTES: 1. Th. chIIIngad YIIIUM of Input cun-.nt, output volt.g. and output fraquaney mull: ba within 10% of ltIair 1l11li.1 valuu. 2. No _gnific.nI ch.ng. or .bnormalily in axtam.l.p~ranca must occur. 3. Dil1"!8Mionl mull: c:onrorm to lpecific.tiOnl. OPERATING CHARACTERISTICS PART NUMBER NDL-104LP RECOMMENDED ELEMENT AREA NOMINAL VALUE (c:m 2 ) LOAD AREA 20 to 60 40 ,'' ' > BRIGHTNESS ,'' ' ' '> 40 to 100 FREQUENCY (Hz) 570 OUTPUT VOLTAGE (V-> to 900 65 to 90 -23±0.:': :':.0±0.5 r2.O±0.5 GROUN~~ TERMINAL OUTPUT TERMINAL ~ Voo ,, D '[;l ~ 0 , ~ 23j 0.5 27 0.3 ~D o ~ [;l f'--'NPUT TERMINAL i.==32.5±0.'" Ef!3 ~~±0.5 I 3.5 REF. 'U?::.=± -I~0.7±0.05 COMPONENTS CORPORATION NDL·104LP ~-"
NDL-104LP 价格&库存
很抱歉,暂时无法提供与“NDL-104LP”相匹配的价格&库存,您可以联系我们找货
