1507
1507
    ADAFRUIT
    LED STRIP RGB DGTL 144LED/M WHT
1507 数据手册
Adafruit NeoPixel Überguide Created by Phillip Burgess https://learn.adafruit.com/adafruit-neopixel-uberguide Last updated on 2022-08-24 04:28:38 PM EDT ©Adafruit Industries Page 1 of 88 Table of Contents The Magic of NeoPixels 5 • Important Things to Know About NeoPixels in General Form Factors 7 NeoPixel Strips and Strands 7 • • • • • • • • RGB NeoPixel Strips Mini Skinny RGB NeoPixel Strips Side-Light NeoPixel Strips RGBW NeoPixel Strips “Neon-Like” NeoPixel Flex Strip Ultraviolet NeoPixel Strips NeoPixel Strands Finer Details About NeoPixel Strips NeoPixel Rings 17 • NeoPixel Ring Product Selector • Finer Details About NeoPixel Rings NeoPixel Matrices • • • • • Rigid 8x8 NeoPixel Matrices NeoPixel Matrix Product Selector Flexible NeoPixel Matrices Finer Details About NeoPixel Matrices We also have a few special-purpose matrices on the NeoPixel Shields page! NeoPixel Shields • • • • • 28 NeoPixel Stick NeoPixel Stick Product Selector NeoPixel Jewels NeoPixel Jewel Product Selector 1/4 60 NeoPixel Ring NeoPixel Ring Product Selector Side Light NeoPixel LED PCB Bar Individual NeoPixels • • • • • • • • 24 NeoPixel Shield for Arduino NeoPixel Shield Product Selector NeoPixel FeatherWing Pimoroni Unicorn Hat Particle/Spark NeoPixel Ring Kit Other NeoPixel Shapes • • • • • • • 20 30 Integrated NeoPixel Products Flora RGB Smart NeoPixels Breadboard-Friendly RGB Smart NeoPixels NeoPixel Mini PCB Discrete NeoPixel Products Through-Hole NeoPixels SMT NeoPixels WS2811 Driver IC ©Adafruit Industries Page 2 of 88 Basic Connections 38 Best Practices 41 • Improper use can damage your NeoPixels. Before diving in, be aware of the following: Powering NeoPixels • • • • 42 Estimating Power Requirements Giant Power Supplies Distributing Power Driving 5V NeoPixels from 3.3V Microcontrollers Logic Level Shifting 49 Software 52 Arduino Library Installation 52 • Install Adafruit_NeoPixel via Library Manager • Manually Install Adafruit_NeoPixel Library • A Simple Code Example: strandtest Arduino Library Use • • • • • HSV (Hue-Saturation-Value) Colors… …and Gamma Correction Help! Pixels Gobble RAM Arduino Library Best Practices NeoMatrix Library • • • • • • 70 FastLED Library FAQ and Further Programming Insights  DMA NeoPixels for ARM Cortex-M0 Boards Third-Party Libraries Writing Your Own Library Python & CircuitPython • • • • • • 63 Adafruit_GFX Primer Layouts Tiled Matrices Other Layouts RAM Again Gamma Correction Advanced Coding • • • • • 55 76 CircuitPython Microcontroller Wiring Python Computer Wiring CircuitPython Installation of NeoPixel Library Python Installation of NeoPixel Library CircuitPython & Python Usage Full Example Code Python Docs 81 MakeCode 81 • Guide Link: NeoPixels with MakeCode ©Adafruit Industries Page 3 of 88 Downloads • • • • • • • • • 81 NeoPixel 12-LED Ring NeoPixel 16-LED Ring NeoPixel 24-LED Ring NeoPixel 1/4 60-LED Ring NeoPixel Jewel Breadboard Friendly NeoPixel Breakout NeoPixel NeoMatrix 8x8 NeoPixel Arduino Shield NeoPixel 8 Stick ©Adafruit Industries Page 4 of 88 The Magic of NeoPixels Incorporating scads of LEDs into an electronic project used to be a hairy prospect, a veritable rat’s nest of wires and code. The arrival of dedicated LED driver chips brought welcome relief, offloading grunt work from the microcontroller and allowing one to focus on the application. Much simpler, but still not “Christmas light” simple. The WS2812 Integrated Light Source — or NeoPixel in Adafruit parlance — is the latest advance in the quest for a simple, scalable and affordable full-color LED. Red, green and blue LEDs are integrated alongside a driver chip into a tiny surface-mount package controlled through a single wire. They can be used individually, chained into longer strings or assembled into still more interesting form-factors. We know you’re eager to get started…but If this is your first time using NeoPixels, please at least read the “Best Practices” page before connecting anything! Important Things to Know About NeoPixels in General • Not all addressable LEDs are NeoPixels. “NeoPixel” is Adafruit’s brand for individually-addressable RGB color pixels and strips based on the WS2812, WS2 811 and SK6812 LED/drivers, using a single-wire control protocol. Other LED products we carry — DotStars, WS2801 pixels, LPD8806 and “analog” strips — use different methodologies (and have their own tutorials). When seeking technical support in the forums, a solution can be found more quickly if the correct LED type is mentioned, i.e. avoid calling DotStars “NeoPixels”…similar, but different! ©Adafruit Industries Page 5 of 88 • NeoPixels don’t just light up on their own; they require a microcontroller (such as Arduino) and some programming. We provide some sample code to get you started. To create your own effects and animation, you’ll need some programming practice. If this is a new experience, work through some of the beginning Arduino tutorials to get a feel for the language. • NeoPixels aren’t the answer for every project. The control signal has very strict timing requirements, and some development boards (such as Netduino or Raspberry Pi) can’t reliably achieve this in every situation. This is why we continue to offer other LED types; some are more adaptable to certain tasks. Can I use NeoPixels for POV (persistence of vision) displays? Not recommended. The refresh rate is relatively low (about 400 Hz to 2 KHz), and when in fast motion may appear “speckled.” They look fine in stationary displays though (signs, decorations, jewelry, etc.). For POV use, DotStar strips (https:// adafru.it/kDg) will look much better (they have a 12–20 KHz refresh rate). How about for light painting? Definitely! The slower movement used for photographic light painting doesn’t call attention to the limited refresh rate; the results look great (https://adafru.it/jTb), especially with a light diffuser. Is there a limit to the number of NeoPixels in a chain? There’s no inherent limit in the maximum length of a NeoPixel chain, but eventually you’ll encounter any of various practical limits: 1. RAM: NeoPixels require some RAM from the host microcontroller; more pixels = more RAM. It’s only a few bytes each, but as most microcontrollers are pretty resource-constrained, this becomes a very real consideration for large projects. 2. Power: each NeoPixel draws a little bit of current; more pixels = more power. Power supplies likewise have some upper limit. 3. Time: NeoPixels process data from the host microcontroller at a fixed data rate; more pixels = more time and lower animation frame rates. ©Adafruit Industries Page 6 of 88 Form Factors NeoPixel products are available in a zillion form factors…from individual tiny pixels to huge matrices…plus strips, rings and everything in-between. The same software drives all of them; they’re all “NeoPixels.” Pick a category from the left column for product links and tips & tricks specific to each type of NeoPixel. NeoPixel Strips and Strands The most popular type of NeoPixels are these flexible LED strips…they can be cut to length and fit into all manner of things. We’ve got over a dozen varieties! Two vital things to be aware of: • Though strips are described as “flexible,” they do not tolerate continuous and repeated bending. “Formable” might be a better word. A typical application is architecture, where they can be curved around columns and then stay put. Repeated flexing (as on costumes) will soon crack the solder connections. For wearable use, either affix shorter segments to a semi-rigid base (e.g. a hat, BMX armor, etc.), or use the individual sewable NeoPixels shown later. • Watch your power draw. Though each pixel only needs a little current, it adds up fast…NeoPixel strips are so simple to use, one can quickly get carried away! We’ll explain more on the “Powering NeoPixels” page. ©Adafruit Industries Page 7 of 88 RGB NeoPixel Strips NeoPixel Digital RGB LED Weatherproof Strip is available in three different “densities”: 30, 60 and 144 LEDs per meter, on a white or black backing strip. 30 LEDs per meter, white strip (http:// adafru.it/1376) 30 LEDs per meter, black strip (http:// adafru.it/1460) 60 LEDs per meter, white strip (http:// adafru.it/1138) 60 LEDs per meter, black strip (http:// adafru.it/1461) 144 LEDs per meter, white strip (http:// adafru.it/1507) 144 LEDs per meter, black strip (http:// adafru.it/1506) The approximate peak power use (all LEDs on at maximum brightness) per meter is: 30 LEDs: 9 Watts (about 1.8 Amps at 5 Volts). 60 LEDs: 18 Watts (about 3.6 Amps at 5 Volts). 144 LEDs : 43 watts (8.6 Amps at 5 Volts). Mixed colors and lower brightness settings will use proportionally less power. ©Adafruit Industries Page 8 of 88 ©Adafruit Industries Page 9 of 88 For those using Circuit Playground Express (https://adafru.it/wpF) or just needing a “no soldering” option (as in most classrooms), we have a special halfmeter, 30-LED NeoPixel strip with alligator clips attached (https://adafru.it/DIV). Easy! Mini Skinny RGB NeoPixel Strips Mini Skinny NeoPixel strips are about half the width of classic NeoPixel strips. They’re available in two densities and backing colors: 30 LEDs per meter, white strip (http:// adafru.it/2949) 30 LEDs per meter, black strip (http:// adafru.it/2954) 60 LEDs per meter, white strip (https:// adafru.it/lFs) 60 LEDs per meter, black strip (http:// adafru.it/2964) 144 LEDs per meter, white strip (https:// adafru.it/lXa) 144 LEDs per meter, black strip (https:// adafru.it/lXb) 30 and 60 LED/meter strips are 7.5 mm wide, or 5 mm if you remove the strip from the casing (vs 12.5 mm / 10 mm for classic strips). The high-density 144/m strips are about 10 mm wide, or 7.5mm with the casing removed. Power requirements are similar to standard-width NeoPixel strips as described above. ©Adafruit Industries Page 10 of 88 Side-Light NeoPixel Strips Side-Light NeoPixel strips have the interesting property of illuminating next to the strip rather than over it. They’re not quite as bright as regular NeoPixels, but may have interesting uses in tight spaces or for edge-lit acrylic. These strips are available in three densities on black flexstrip: 60 LEDs, 1 meter black strip (https:// adafru.it/Et0) 90 LEDs, 1 meter black strip (https:// adafru.it/Et1) 120 LEDs, 1 meter black strip (https:// adafru.it/Et2) ©Adafruit Industries Page 11 of 88 RGBW NeoPixel Strips A recent addition is RGBW NeoPixel strips. These add a fourth LED element — pure white — which is more “true” and pleasing to the eye than white mixed from red+green+blue. Like the RGB strips, they’re available in different pixel densities and backing strip colors. 30 RGBW LEDs per meter, white strip (http://adafru.it/2832) 30 RGBW LEDs per meter, black strip (http://adafru.it/2824) 60 RGBW LEDs per meter, white strip (http://adafru.it/2842) 60 RGBW LEDs per meter, black strip (http://adafru.it/2837) 144 RGBW LEDs per meter, white strip (http://adafru.it/2847) 144 RGBW LEDs per meter, black strip (http://adafru.it/2848) With a fourth LED per pixel, these strips may potentially draw up to 33% more current than their RGB equivalents. The maximum brightest cases are (approximately): 30 RGBW LEDs: 12 Watts (2.4 Amps at 5 Volts) 60 RGBW LEDs: 24 Watts (4.8 Amps at 5 Volts) 144 RGBW LEDs: 57 Watts (11.5 Amps at 5 Volts) Width is the same as “classic” NeoPixel strip…these are not the “skinny” size. ©Adafruit Industries Page 12 of 88 “Neon-Like” NeoPixel Flex Strip This distinctive NeoPixel flex strip has a gorgeous diffused neon-like appearance thanks to its thick silicone casing. This strip contains 60 LED along the meter but in groups of 3-LEDs-per-pixel. So basically, in your NeoPixel program, this looks like a 20-pixel-long strand. Unlike the other varieties of NeoPixel strip, this one needs to be powered from 9 Volts (minimum) to 12 Volts (ideal) DC. NeoPixel RGB Neon-like LED Flex Strip with Silicone Tube - 1 meter (https:// adafru.it/Et3) ©Adafruit Industries Page 13 of 88 Ultraviolet NeoPixel Strips A single-color ultraviolet variant of NeoPixel strip is available for special applications, currently one pixel density and backing color: 32 UV LEDs per meter, white strip (https:// adafru.it/BZ5) This can provide unusual effects when combined with UV-reactive paints, fluorescent laser-cut acrylic, etc. The usual NeoPixel R, G and B channels translate to three individual UV diodes. So we recommend you pretty much just set all three channels to the same value, ranging from (0, 0, 0) to (255, 255, 255). Same width as “classic” NeoPixel strip, and power draw at full brightness should be just a bit more than RGB 30/m: about 9.6W/meter (1.9A @ 5V). ©Adafruit Industries Page 14 of 88 NeoPixel Strands Like NeoPixel strips, these “strands” are flexible and can be wrapped around things. The pixels are spaced further apart (2 or 4 inches) with each pixel is sealed in its own tiny plastic capsule, making them weatherproof (but not rated for continuous submersion). There are 20 pixels in a strand. NeoPixel Strand — 20 LED 4" Pitch (https:// adafru.it/Et3) NeoPixel Strand — 20 LEDs at 2" Pitch (https://adafru.it/CV5) Finer Details About NeoPixel Strips • NeoPixel strips often have extra wires so they can connect to both a microcontroller and power source, but these will always correspond to one of ©Adafruit Industries Page 15 of 88 the same three signals: +5V, ground or data. If not using the extra wires, you can clip off any exposed tips and/or insulate with some heat-shrink tube. • 144 pixel/m NeoPixel strips and 32/m UV strips are sold in one meter lengths. Each meter is a separate strip with end connectors. Longer contiguous lengths are not offered in 144 pixels/m RGB, RGBW or 32/m UV. • 30 and 60 pixel/m NeoPixel strips are sold in one meter multiples. Orders for multiple meters will be a single contiguous strip, up to a limit: 4 meters for 60 pixels/m strip, 5 meters for 30 pixels/m. • For 30 and 60 pixels/meter strips, if purchasing less than a full reel (4 or 5 meters, respectively), the strip may or may not have 3-pin JST plugs soldered at one or both ends. These plugs are for factory testing and might be at either end — the plug does not always indicate the input end! Arrows printed on the strip show the actual data direction. You may need to solder your own wires or plug. • The flex strips are enclosed in a weatherproof silicone sleeve, making them immune to rain and splashes, but are not recommended for continuous submersion. Early 144 pixel/meter strips were not weatherproof, but the current inventory now offers this feature. • The silicone sleeve can be cut and removed for a slimmer profile, but this compromises the strip's weather resistance. • Very few glues will adhere to the weatherproof silicone sleeve. Using zip ties for a “mechanical” bond is usually faster and easier. The only reliable glues we’ve found are Permatex 66B (or Permatex 80050) Clear RTV Silicone (not all silicone glues will work!) and Loctite Plastics Bonding System, a 2-part cyanoacrylate glue. Customers have reported excellent results with Permatex Ultra Grey Silicone Gasket Maker , Lexel® adhesive and Clear Gorilla Glue as well. • However, do not use Permatex 66B silicone to seal the open end of a cut strip! L ike many RTV silicones, 66B releases acetic acid when curing, which can destroy electronics. It’s fine on the outside of the strip, but not the inside. Use G E Silicone II for sealing strip ends, or good ol’ hot melt glue. • 2-sided carpet tape provides a light grip on the silicone sleeve; something like a Post-It Note. Or you can try clear duct tape over the top. ©Adafruit Industries Page 16 of 88 • All LED strips are manufactured in 1/2 meter segments that are then joined into a longer strip. The pixel spacing across these joins is usually 2-3 millimeters different than the rest. This is not a manufacturing mistake, just physical reality. Some batches of 144 pixel strip don’t have pads between the LEDs. If you cut these into shorter sections, the only way to connect to them (except at the half-meter segments) is to carefully solder directly to the LED. The corner with the notch is the GND pin. NeoPixel strips are just the start…we’ve got shapes too! Rings, grids, shields and more… NeoPixel Rings NeoPixel rings are circular rigid printed circuit boards festooned with NeoPixel LEDs. Originally designed for our NeoPixel Goggles kit (http://adafru.it/2221), they proved so popular with other projects…timepieces, GPS wayfinders, jewelry, etc…that we now offer several sizes and varieties… Rather than list a zillion different links, we have a single landing page for selecting among all the different NeoPixel ring products: ©Adafruit Industries Page 17 of 88 NeoPixel Ring Product Selector (http://adafru.it/3042) NeoPixel rings are offered in 12, 16, 24 and 60 pixel varieties. 60-pixel rings are actually sold as 15-pixel quarters. For a full circle, you’ll need to purchase 4 and solder them together. Or you might find creative ideas for individual arcs! Number of Pixels Outer Diameter Inner Diameter 12 37 mm / 1.5" 23 mm / 1" 16 44.5 mm / 1.75" 31.75 mm / 1.25" 24 65.5 mm / 2.6" 52.5 mm / 2.05" 60 (4x 15-pixel arcs) 158 mm / 6.2" 145 mm / 5.7" All rings are about 3.6 millimeters / 0.15" thick (1.6 mm for PCB, 2 mm for NeoPixels). ©Adafruit Industries Page 18 of 88 RGB NeoPixels are the most affordable and can produce millions of color combinations. RGBW NeoPixels offer an eye-pleasing “true” white in addition to RGB. These are available in three different color temperaures: Cool white: approximately 6000 Kelvin (K). Neutral: approx 4500K. Warm white: approx. 3000K. RGBW pixels incorporate a translucent diffuser layer to help mix and soften the light output. This makes them appear less intense than RGB pixels (which are “water clear”), but it’s really the same LEDs inside. ©Adafruit Industries Page 19 of 88 Finer Details About NeoPixel Rings • When soldering wires to these rings, you need to be extra vigilant about solder blobs and short circuits. The spacing between components is very tight! It’s often easiest to insert the wire from the front and solder on the back. • If using alligator clips, we recommend first soldering short jumper wires to the ring inputs and connecting the clips to those, for similar reasons. (Some of our tutorials and product photos do show alligator clips directly connected to the rings, but we’ve had a lot of experience using them.) There’s also a 24-pixel RGB ring (http:// adafru.it/2268) specifically designed for the Particle (formerly Spark) Photon development board. This one’s not “see-through” like the others — the space at the center provides a socket for the Photon board (http:// adafru.it/2721). NeoPixel Matrices NeoPixel matrices are two-dimensional grids of NeoPixels, all controlled from a single microcontroller pin. Rigid 8x8 NeoPixel Matrices Like NeoPixel rings, these 64-pixel matrices are assembled on a rigid printed circuit board and are available in both RGB and RGBW varieties. NeoPixel Matrix Product Selector (http://adafru.it/3052) All measure 71 millimeters (2.8 inches) square and about 3.6 mm thick. There are several mounting holes, and the DOUT pin allows multiple matrices to be linked in series. ©Adafruit Industries Page 20 of 88 RGB NeoPixels are the most affordable and can produce millions of color combinations. RGBW NeoPixels offer an eye-pleasing “true” white in addition to RGB. These are available in three different color temperaures: • Cool white: approximately 6000 Kelvin (K). • Neutral: approx 4500K. • Warm white: approx. 3000K. RGBW pixels incorporate a translucent diffuser layer to help mix and soften the light output. This makes them appear less intense than RGB pixels (which are “water clear”), but it’s really the same LEDs inside. ©Adafruit Industries Page 21 of 88 Flexible NeoPixel Matrices Flexible NeoPixel matrices are available in three different sizes: 8x8 RGB pixels (http://adafru.it/2612) 16x16 RGB pixels (http://adafru.it/2547) 8x32 RGB pixels (http://adafru.it/2294) Size Dimensions ©Adafruit Industries Total # of LEDs Max Power Draw (approx) Page 22 of 88 8x8 80 mm / 3.15" square 64 19 Watts (3.8 Amps at 5 Volts) 16x16 160 mm / 6.3" square 256 77 Watts (15 Amps at 5 Volts) 8x32 320 mm x 80 mm / 12.6" x 3" 256 77 Watts (15 Amps at 5 Volts) Flex matrices are about 2 millimeters (0.08 inches) thick. Though called “flexible,” these matrices do not tolerate continuous and repeated bending. “Formable” might be a better word — they can be bent around a rigid or semi-rigid shape, like a hat. Repeated flexing (as on costumes) will soon crack the solder connections. (The videos on the product pages are to highlight just how flexible these matrices are, but this really is a “don’t try this at home” thing.) Flex matrices are available with RGB pixels only; RGBW is not offered. Finer Details About NeoPixel Matrices As mentioned on the NeoPixel Strips page, keep power consumption in mind when working with NeoPixel matrices. With so many pixels at your disposal, it’s easy to get carried away. ©Adafruit Industries Page 23 of 88 If you need a size or shape of NeoPixel matrix that’s not offered here, it’s possible to c reate your own using sections of NeoPixel strip! NeoPixel matrices don’t enforce any particular “topology” — some may have rows of pixels arranged left-to-right, others may alternate left-to-right and right-to-left rows, or they could be installed in vertical columns instead. This will require some planning in your code. Our NeoMatrix library supports most matrix topologies. We also have a few special-purpose matrices on the NeoPixel Shields page! NeoPixel Shields Though not all “Shields” in the strictly-speaking Arduino sense, a few NeoPixel products are designed to fit directly atop (or below) certain microcontroller boards… ©Adafruit Industries Page 24 of 88 NeoPixel Shield for Arduino This 5x8 NeoPixel Shield for Arduino (http://adafru.it/1430) fits neatly atop an Arduino Uno or compatible boards (5V logic recommended). Like many of our NeoPixel products, they’re available in RGB and various RGBW pixel types: NeoPixel Shield Product Selector (https://adafru.it/ lCw)   By default, the LEDs are powered from the Arduino’s 5V pin. As long as you aren't lighting up all the pixels at full brightness that should be fine. Or power the shield with an external power supply by soldering the included terminal block. The NeoPixels are controlled on digital pin 6, but with some deft wiring you could change this to any pin. ©Adafruit Industries Page 25 of 88 NeoPixel FeatherWing Quite possibly The Cutest Thing in the History of Cute Little Things, the NeoPixel FeatherWing (http://adafru.it/2945) is is 4x8 pixel matrix that fits perfectly atop any of our Feather microcontroller boards (https://adafru.it/l7B). The NeoPixels are normally controlled from digital pin 6, but pads on the bottom make this reassignable. In particular, the default pin for Feather Huzzah ESP8266 must be moved, try pin #15! The NeoPixel Featherwing is RGB only; there’s no RGBW version. ©Adafruit Industries Page 26 of 88 Pimoroni Unicorn Hat The Pimoroni Unicorn Hat (http://adafru.it/ 2288) is aptly named after a mythical animal — normally we’ll say that NeoPixels don’t work with the Raspberry Pi, but Pimoroni has worked up some magical software (https://adafru.it/lCx) that makes this combination possible! It’s an 8x8 RGB matrix that fits neatly atop the Raspberry Pi Model A+, B+ or Pi 2. Due to the way Unicorn HAT works, you can't use your Pi's analog audio alongside it. If you see odd random colour patterns and flickering make sure analog audio is disabled. Particle/Spark NeoPixel Ring Kit Previously mentioned on the “Rings” page, but for posterity: this 24-pixel RGB ring (http://adafru.it/2268) is specifically designed for the Particle (formerly Spark) Photon development board. ©Adafruit Industries Page 27 of 88 Other NeoPixel Shapes NeoPixel Stick The simplest thing…a row of 8 NeoPixels along a rigid circuit board. These make great bargraph indicators! Like our rings and matrices, NeoPixel sticks are available in RGB and RGBW varieties. NeoPixel Stick Product Selector (http://adafru.it/ 3039)   All measure 51.1 x 10.2 millimeters (2.0 x 0.4 inches). ©Adafruit Industries Page 28 of 88 NeoPixel Jewels When you need more “punch” than a single NeoPixel can provide, these 7-pixel jewels provide a lot of light in a compact shape. Again, RGB and RGBW varieties are available. NeoPixel Jewel Product Selector (http://adafru.it/ 3047)   All measure 23 millimeters (0.9 inches) in diameter. 1/4 60 NeoPixel Ring Though originally designed to be used in groups of four to complete a 60 NeoPixel Ring, the individual 15-pixel quarter rings can also be used to solve interesting design problems! RGB and RGBW are available. NeoPixel Ring Product Selector (http://adafru.it/ 3042) ©Adafruit Industries Page 29 of 88 Side Light NeoPixel LED PCB Bar A half-meter rigid PCB tightly packed with 60 side-light NeoPixels. This is a strange animal but might be just the thing for compact light-painting projects or edge-lit signage. What might you make of it? Side Light NeoPixel LED PCB Bar - 60 LEDs - 120 LED/meter - 500mm Long (https://adafru.it/Et5) Individual NeoPixels If you need just a small number of pixels…or if ready-made shapes and strips don’t quite provide what you’re after…individual NeoPixels provide the most control over placement and quantity. Integrated NeoPixel Products Some individual NeoPixel products come ready to use, with a small PCB holding the LED, a decoupling capacitor for power, and points for connecting wires. ©Adafruit Industries Page 30 of 88 Flora RGB Smart NeoPixels The original Adafruit NeoPixel form factor! Flora RGB Smart NeoPixels were designed for wearable projects using conductive thread, but can also be soldered normally with wires. These are available in two formats: Pack of 4 (http://adafru.it/1260), ready to use as-is. Sheet of 20 (http://adafru.it/1559), cut them off the sheet as you need them and save a little money. Flora RGB Smart Pixels measure about 12.5 millimeters (0.5 inches) in diameter. These are RGB only; there’s no RGBW version. ©Adafruit Industries Page 31 of 88 Breadboard-Friendly RGB Smart NeoPixels These are similar to the sewable Flora NeoPixels, but with a pin arrangement that (with the addition of headers) fits neatly into a breadboard for prototyping. Also available in two formats: Pack of 4 (http://adafru.it/1312), ready to use as-is. Sheet of 25 (http://adafru.it/1558), cut off as needed. For both types, headers (http://adafru.it/ 392) are optional and not included. Breadboard-Friendly NeoPixels measure 10.2 x 12.7 millimeters (0.4 x 0.5 inches) and are RGB only; there’s no RGBW version. ©Adafruit Industries Page 32 of 88 NeoPixel Mini PCB NeoPixel Mini Button PCBs are the smallest ready-to-use NeoPixel format — each on its own tiny board with an input resistor and decoupling capacitor. NeoPixel Mini Button PCB (https://adafru.it/ f9D) — RGB version, sold in packs of 5 NeoPixel RGBW Mini Button PCB (https:// adafru.it/UBW) — RGBW, sold in packs of 10 These have no mounting holes or soldering vias…wires must be soldered directly to pads on the back of the PCB. Each is about 10 millimeters (0.3 inches) in diameter. Discrete NeoPixel Products For advanced users needing fully customized designs, discrete NeoPixel components are available. You’ll need to provide your own PCB and (depending on the pixel type) surface-mount soldering skill. It’s very strongly recommended that each NeoPixel have an accompanying 0.1 μF capacitor between +V and ground. This prevents communication problems due to brownout of the on-pixel driver logic. It’s occasionally sufficient to have one capacitor between pairs of pixels; some of our NeoPixel rings work that way. ©Adafruit Industries Page 33 of 88 Through-Hole NeoPixels Discrete Through-hole NeoPixels are available in two sizes: 8mm Diffused (http://adafru.it/1734) – pack of 5. 5mm Diffused (http://adafru.it/1938) – pack of 5. 5mm Clear (http://adafru.it/1837) have been discontinued, but the product page is still available if you require pinout information. Through-hole NeoPixels are RGB only; there’s no RGBW version. Use of a 0.1 μF capacitor (http://adafru.it/753) between + and ground on each pixel is strongly encouraged. ©Adafruit Industries Page 34 of 88 SMT NeoPixels ©Adafruit Industries Page 35 of 88 Surface-mount “5050” (5 millimeter square) NeoPixels are available in many varieties: 5050 RGB LED (http://adafru.it/1655) – pack of 10. RGBW NeoPixel – Cool White – white case (http://adafru.it/2759) – pack of 10. RGBW NeoPixel – Neutral White – white case (http://adafru.it/2758) – pack of 10. RGBW NeoPixel – Warm White – white case (http://adafru.it/2757) – pack of 10. RGBW NeoPixel – Cool White – black case (http://adafru.it/2762) – pack of 10. RGBW NeoPixel – Neutral White – black case (http://adafru.it/2761) – pack of 10. RGBW NeoPixel – Warm White – black case (http://adafru.it/2760) – pack of 10. NeoPixel – Cool White (http://adafru.it/ 2375) (3X white, no RGB) – pack of 10. NeoPixel – Warm White (http://adafru.it/ 2376) (3X white, no RGB) – pack of 10. All measure 5 millimeters square. Adding a 0.1 μF capacitor between + and ground is recommended for each pixel, positioned close by, though often one cap per two pixels will suffice. The white- and black-cased pixels are functionally identical; this is purely an aesthetic choice for your design. “Cool white” measures approximately 6000 Kelvin. “Neutral white” is approx. 4500K. “Warm White” is approx. 3000K. ©Adafruit Industries Page 36 of 88 Tiny surface-mount “3535” (3.5 millimeters square) NeoPixels are available in two RGB versions; no RGBW is available. NeoPixel Mini 3535 RGB – white case (http://adafru.it/2659) – pack of 10. NeoPixel Mini 3535 RGB – black case (http://adafru.it/2686) – pack of 10. Decoupling capacitor recommended, as described above. As with the “5050” NeoPixels, white- and black-cased versions are functionally identical, this is an aesthetic design option. WS2811 Driver IC The NeoPixel driver logic is available separately (http://adafru.it/1378) from the LEDs, allowing power-users to create extremely customized designs…perhaps using other LED colors, or combined with power MOSFETs (http://adafru.it/355) to control high-current LEDs or “analog” RGB LED strips (https://adafru.it/lCy) using the NeoPixel protocol. These require circuit design skills, custom PCBs and fine surface-mount soldering. A 0.1 uF decoupling capacitor is recommended for each chip. ©Adafruit Industries Page 37 of 88 Basic Connections To get started, let’s consider the example of an Arduino microcontroller connected to the computer’s USB port (though it works with many other microcontroller boards as well). We’ll elaborate on the finer points of powering NeoPixels later, but in general you’ll usually be using a 5V DC power supply (e.g. “wall wart”) or — for wearable projects — a 3.7 Volt lithium-polymer battery. Identify the “input” end of your NeoPixel strip, pixel(s) or other device. On some, there will be a solder pad labeled “DIN” or “DI” (data input). Others will have an arrow showing the direction that data moves. The data input can originate from any digital pin on the Arduino, but all the example code is set up for digital pin 6 by default. The NeoPixel shield comes wired this way. Some NeoPixel strips have extra wires so they can connect to both a microcontroller and power source, but these will always correspond to one of the same three inputs: +5V, ground or data. If not using the extra wires, you can clip off any exposed tips and/or insulate with some heat-shrink tube. If there are four distinct wires, then it’s probably a DotStar (https://adafru.it/zbD) strip, or maybe LPD8806 (https://adafru.it/UAY) (less common nowadays). NeoPixels powered by 5v ideally require a 5V data signal. If using a 3.3V microcontroller, it’s wise to use a logic level shifter such as a 74AHCT125 (https:// adafru.it/e5g) or 74HCT245 (http://adafru.it/1779). If you are powering your NeoPixels with 3.7v directly from a LiPoly cell, a 3.3v data signal is OK. See the “Logic Level Shifting” page for further information. If using a Flora, Feather or other microcontroller board with an attached lithiumpolymer battery: connect the +5V input on the strip to the pad labeled VBAT or BAT on the board, GND from the strip to any GND pad on the microcontroller board, and DIN to Flora pin D6. If the board doesn’t have a pin #6, you’ll need to modify the example code to change the pin number. For other Arduino boards with a separate +5V DC power supply for the NeoPixels: co nnect the +5V input on the strip to the + (positive) terminal on the power supply (don’t connect to the Arduino), DIN to digital pin 6 on the Arduino, and – (minus or GND) on the strip must connect to both the minus (–) terminal on the DC supply and a GND pin on the Arduino (there are usually several — any will do). ©Adafruit Industries Page 38 of 88 “DOUT” or “DO” (data out) at the end of a NeoPixel chain can be left unconnected. If adding more pixels later, data-out from one chain connects to data-in of the next. The 144 pixel strips are so tightly packed, there’s no room for labels other than –, + and the data direction arrows. Data is the third, un-labeled pad. The order of the three pins can vary between different strip batches and densities. ALWAYS use the labels printed ON THE STRIP. Look closely, NEVER blindly follow a NeoPixel strip wiring diagram; it might be based on a different product! When connecting NeoPixels to any LIVE power source or microcontroller, ALWAYS CONNECT GROUND (–) BEFORE ANYTHING ELSE. Conversely, disconnect ground last when separating. When using a DC power supply, or an especially large battery, we recommend adding a large capacitor (100 to 1000 µF, 6.3V or higher) across the + and – terminals. This prevents the initial onrush of current from damaging the pixels. See the photo on the next page for an example. With through-hole NeoPixels (5mm or 8mm round), add a 0.1 µF capacitor between the + and – pins of EACH PIXEL. Individual pixels may misbehave without this “decoupling cap.” Strips and boards have these caps built-in. Adding a ~470 ohm resistor between your microcontroller's data pin and the data input on the NeoPixels can help prevent spikes on the data line that can damage ©Adafruit Industries Page 39 of 88 your first pixel. Please add one between your micro and NeoPixels! Our NeoPixel rings already have this resistor on there Can NeoPixels be powered directly from the Arduino’s 5V pin? Sometimes. The Arduino can continuously supply only about 500 milliamps to the 5V pin. Each NeoPixel can draw up to 60 milliamps at full brightness. So yes, you can skip the separate DC supply and power directly off the Arduino as long as just a few pixels are used, more if the colors and overall brightness are low. When in doubt, give the pixels a separate power supply. Can I power the NeoPixels and microcontroller from the same power supply? Quite often yes — on the Arduino Uno, use the Vin pin next to GND, or the DC jack. Most well-designed boards from companies you recognize will do the right thing when both USB and external power are connected, and they incorporate a lowdropout regulator so a 5V power supply still provides very-nearly 5V to the board… close enough that everything works. If using a super bare-bones board, perhaps an inexpensive clone or something that’s less clever about handling different power inputs…you can use the 5V pin for input, but it’s a smart idea in that case to not have that and USB connected at the same time; best to disconnect one or the other while iterating a design, always powering the board from just one source. ©Adafruit Industries Page 40 of 88 Best Practices Improper use can damage your NeoPixels. Before diving in, be aware of the following: • Before connecting NeoPixels to any large power source (DC “wall wart” or even a large battery), add a capacitor (500–1000 µF at 6.3V or higher) across the + and – terminals as shown above. The capacitor buffers sudden changes in the current drawn by the strip. • Place a 300 to 500 Ohm resistor between the Arduino data output pin and the input to the first NeoPixel. The resistor should be at the end of the wire closest to the NeoPixel(s), not the microcontroller. Some products already incorporate this resistor…if you’re not sure, add one…there’s no harm in doubling up! Also, newer NeoPixels are less picky about this. Nothing’s needed at the “out” end of a strip…you can leave the data out “floating.” • Try to minimize the distance between the Arduino and first pixel, so the signal is clear. A meter or two is usually no problem. Much longer and things can become unreliable. Individual NeoPixels can act as repeaters for long runs. • Avoid connecting NeoPixels to a live circuit. If you simply must, always connect ground first, then +5V, then data. Disconnect in the reverse order. • If powering the pixels with a separate supply, apply power to the pixels before applying power to the microcontroller. Otherwise they’ll try to power “parasitically” through the data line, which could spell trouble for the microcontroller. ©Adafruit Industries Page 41 of 88 • Observe the same precautions as you would for any static-sensitive part; ground yourself before handling, etc. • NeoPixels powered by 5v ideally need a 5V data signal. If using a 3.3V microcontroller you must use a logic level shifter such as a 74AHCT125 (https:// adafru.it/e5g) or 74HCT245 (http://adafru.it/1779). See the “Logic Level Shifting” page for more details. If you are powering your NeoPixels with 3.7v directly from a LiPoly cell, a 3.3v data signal is OK. • Make sure that your connections are secure. Alligator clips do not make reliable connections to the tiny solder pads on NeoPixel rings. Better to solder a small pigtail wire to the ring and attach the alligator clips to that. • If your microcontroller and NeoPixels are powered from two different sources (e.g. separate batteries for each), there must be a ground connection between the two. Some of our projects don’t make the above precautions…these are typically small battery-powered devices and power spikes aren’t a big concern. Any project with a lot pixels or a large power source should definitely include the power capacitor and data line resistor. Powering NeoPixels When connecting NeoPixels to any live power source or microcontroller, ALWAYS CONNECT GROUND (–) BEFORE ANYTHING ELSE. Conversely, disconnect ground last when separating. Adding a 300 to 500 Ohm resistor between your microcontroller's data pin and the data input on the first NeoPixel can help prevent voltage spikes that might otherwise damage your first pixel. Please add one between your micro and NeoPixels! NeoPixels are usually described as “5 Volt devices,” but the reality is a little more nuanced than that. Some (not all) NeoPixel products can work with slightly higher voltages. This depends on the additional support components around the chip, based on available space, cost and the most likely application. Refer to the specific product description page for guidance on acceptable voltage limits for each type. When in doubt, aim for 5 Volts. Lower voltages are always acceptable, with the caveat that the LEDs may be slightly ©Adafruit Industries Page 42 of 88 dimmer. There’s a limit below which the LED will fail to light, or will start to show the wrong color. Before connecting a NeoPixel strip to ANY source of power, a large capacitor (500– 1000 µF at 6.3 Volts or higher) across the + and – terminals provides a small power reservoir for abrupt changes in brightness that the power source might not otherwise handle — a common source of NeoPixel “glitching.” For a polarized electrolytic capacitor as seen here, the negative (–) lead is usually indicated by a stripe and/or may be shorter than the + lead. This is an item we don’t stock, but they can be found from parts distributors like Digi-Key (https://adafru.it/UAX). For many wearable projects we recommend a lithium-polymer battery (http://adafru.it/328). These deliver 3.7 Volts — perfect for directly feeding lowpower microcontrollers such as the Adafruit Flora, yet sufficient for a short length of NeoPixels. Three alkaline cells (such as AA batteries) can be installed in a battery holder (http:// adafru.it/771) to provide 4.5 Volts. Though larger and heaver than the fancy lithiumpolymer pack, they’re inexpensive and readily available. ©Adafruit Industries Page 43 of 88 Four nickel-metal hydride (NiMH) rechargeable cells can similarly be used in a 4-cell battery holder (http://adafru.it/830) to provide 4.8 Volts. Make sure you only use NiMH cells in this configuration. Four alkaline cells (the disposable type) will output 6V total — that’s too high for some NeoPixels, and definitely too much for the microcontroller! USB power banks can sometimes be used a couple of ways… Powering a microcontroller board through its USB port, tapping power for the NeoPixels from the board’s 5V or VIN pin. Dissecting a USB cable to provide 5V directly to the pixels. Many USB power banks shut off automatically when current draw is low (e.g. few or no pixels lit), so this requires experimentation and isn’t ideal for all situations. A buck converter (https://adafru.it/efD) can efficiently step a higher DC voltage down to 5V for NeoPixels and microcontrollers … for example if you have a 12V power source, like a car battery. Different converters have a specific input voltage range and output maximum current, so check specifications carefully. Battery-operated LED project planning is discussed in greater detail in Battery Power for LED Pixels and Strips (https://adafru.it/cDU). ©Adafruit Industries Page 44 of 88 For most non-portable “desktop” projects, a 5V DC switching power supply (http:// adafru.it/276) is ideal. This small 2 Amp supply is good for a a meter or so of NeoPixel strip. We’ll explain larger projects in a moment. Be extremely cautious with bench power supplies. Some — even reputable, wellregarded brands — can produce a large voltage spike when initially switched on, instantly destroying your NeoPixels! If you use a bench supply, do not connect NeoPixels directly. Turn on the power supply first, let the voltage stabilize, then connect the pixels (GND first). Estimating Power Requirements Each individual NeoPixel draws up to 60 milliamps at maximum brightness white (red + green + blue). In actual use though, it’s rare for all pixels to be turned on that way. When mixing colors and displaying animations, the current draw will be much less. It’s impossible to estimate a single number for all circumstances, but we’ve been using 1/3 this (20 mA per pixel) as a gross rule of thumb with no ill effects. But if you know for a fact that you need every pixel on at maximum brightness, use the full 60 mA figure. To estimate power supply needs, multiply the number of pixels by 20, then divide the result by 1,000 for the “rule of thumb” power supply rating in Amps. Or use 60 (instead of 20) if you want to guarantee an absolute margin of safety for all situations. For example: 60 NeoPixels × 20 mA ÷ 1,000 = 1.2 Amps minimum 60 NeoPixels × 60 mA ÷ 1,000 = 3.6 Amps minimum The choice of “overhead” in your power supply is up to you. Maximum safety and ©Adafruit Industries Page 45 of 88 reliability are achieved with a more generously-sized power supply, and this is what we recommend. Most power supplies can briefly push a little extra current for short periods. Many contain a thermal fuse and will simply shut down if overworked. So they may technically work, but this is the electronics equivalent of abusing a rental car. Keep in mind, 60 mA is a worst case estimate! We’ve written a whole separate tutorial on getting things under control: Sipping Power with NeoPixels (https:// adafru.it/wbm). I estimate I need a 3.6 Amp power supply. I have a 10 Amp supply on-hand. Will this cause my NeoPixels to explode? As long as the output is 5 Volts DC, you’re golden. The LEDs will only draw as much current (Amperes) as they need. So extra Amps are OK — in fact, it can be a thing. The larger power supply will run cooler because it’s not being pushed to its limit. Excessive however, will definitely kill your LEDs. Extra Amps = good. Extra Volts = bad. What about batteries and “Amp hours”? Amp-hours are current over time. A 2,600 mAh (milliamp-hour) battery can be thought of as delivering 2.6 Amps continuously for one hour, or 1.3 Amps for 2 hours, and so forth. In reality, it’s not quite linear like that; most batteries have disproportionally shorter run times with a heavy load. Also, most batteries won’t take kindly to being discharged in an hour — this can even be dangerous! Select a battery sufficiently large that it will take at least a couple hours to run down. It’s both safer for you and better for the longevity of the battery. I need to power LOTS of NeoPixels and don’t have a power supply that large. Can I use several smaller ones? Maybe. There are benefits to using a single supply, and large power supplies are discussed below. “Non-optimal” doesn’t necessarily mean “pessimal” though, and we wouldn’t discourage anyone from using what resources they have. If you go this route, the key is to have all of the ground pins among the strips connected in common, but the +5V from each power supply should be connected ©Adafruit Industries Page 46 of 88 only to one length of NeoPixels — those should all be joined. Every power supply is a little different — not 5 Volts — and this keeps some from back-feeding into others. Giant Power Supplies Adafruit offers 5V DC power supplies up to 10 Amps (http://adafru.it/658). This is usually sufficient for a couple hundred NeoPixels or more. For really large installations, you’ll need to look elsewhere. One possibility is to repurpose an ATX computer power supply. The nice beefy server types often provide up to 30 Amps. Some minor modifications are needed…Google around for “ATX power supply hack.”  Note that the ATX 5V rail can be very unstable if there's no load on the 12V rail! Even larger (and scarier, and much more expensive) are laboratory power supplies with ratings into the hundreds of Amps. Sometimes this is what’s needed for architectural scale projects and large stage productions. And occasionally we get requests for help… Please note that projects of this scale are potentially very dangerous, and the problems of power distribution are fundamentally different than hobby-scale projects. As much as we enjoy helping our customers in the forums, they are for product technical support and not full-on engineering services. If you’re developing a project of this scope, hire a professional electrician with experience in high-power, lowvoltage systems such as photovoltaics or large RVs and boats. This is no charade. Power for large-scale NeoPixel installations is discussed further in this NeoPixel curtain guide (https://adafru.it/Blc). Distributing Power The longer a wire is, the more resistance it has. The more resistance, the more voltage drops along its length. If voltage drops too far, the color of NeoPixels can be affected. Consider a full 4 meter reel of NeoPixels. With 5V applied at one end of the strip, for those pixels closest to this end, power traverses only a few inches of copper. But at the far end of the strip, power traverses 8 meters of copper — 4 meters out on the +5V line, 4 meters back on the ground line. Those furthest pixels will be tinted brown due to the voltage drop (blue and green LEDs require higher voltage than red). ©Adafruit Industries Page 47 of 88 Pro Tip: NeoPixels don’t care what end they receive power from. Though data moves in only one direction, electricity can go either way. You can connect power at the hea d, the tail, in the middle, or ideally distribute it to several points. For best color consistency, aim for 1 meter or less distance from any pixel to a power connection. With larger NeoPixel setups, think of power distribution as branches of a tree rather than one continuous line. Resistance is just as much a concern on tiny projects too! For wearable electronics we like conductive thread…it’s flexible and withstands hand washing. Downside is that it doesn’t carry much current. Here several strands of conductive thread have been grouped to provide better capacity for the + and – conductors down a pair of suspenders. (From the Pac Man Pixel Suspenders (https://adafru.it/ciD) guide.) Driving 5V NeoPixels from 3.3V Microcontrollers Increasingly, microcontrollers are running at 3.3 Volts instead of 5 Volts. That’s great news for efficiency, but can present a communication problem with 5V NeoPixels. The 3.3V signal from the microcontroller may not be “loud” enough to register with the higher-voltage device. The manufacturer recommends a minimum signal voltage of 70% of the NeoPixel voltage. ©Adafruit Industries Page 48 of 88 There are two ways this can be addressed: 1. Lower the voltage to the NeoPixels so it’s closer (or equal) to that of the microcontroller. This is why we recommend LiPo batteries for FLORA projects: 3.7V is enough to run a short length of pixels, and the microcontroller is comfortable at that voltage as well. 2. Use a logic level shifter (https://adafru.it/e5g) to step up the signal from the microcontroller to the first pixel. The “Logic Level Shifting” page explains why some projects can work even without thispart. For more info on using a level shifter with your NeoPixels, have a look at this guide. (h ttps://adafru.it/FXc) Logic Level Shifting More and more contemporary microcontrollers are 3.3 Volt devices, in fact 5V is becoming a rare breed. The need for logic level shifting—boosting 3.3V signals up to the 5V supply voltage of NeoPixels—is frequently cited, but reality is more nuanced. Even in our own projects, we’ll often leave this part out. What’s up? “NeoPixels require 5V logic” is a rule of thumb, a simplification that covers the vast majority of cases. When in doubt, 5V logic has you covered. More accurately, “WS2812-compatible devices require logic above some percentage of the supply voltage, but that percentage varies from one make and model of device to another, and there are individual component tolerances and external factors like temperature to consider,” but that’s a whole lot of words and unknowns, so you can see why the rule of thumb gets used. Lets unpack the whole statement though, to better understand why we sometimes don’t bother with level shifting… Percentage of Supply Voltage The voltage level that distinguishes logic “high” from “low” is not precisely at 5.000V, but somewhere above zero and below the supply voltage (that is, whatever’s powering the NeoPixels). A datasheet will often provide some number…let’s say 3.5V… but that’s under specific test conditions, e.g. with a specific supply voltage (which the documentation should also mention alongside such figures). That is to say…the ©Adafruit Industries Page 49 of 88 minimum reliable “high” logic level is not a hard number, but a relative figure or a percentage of the supply voltage, like VDD−0.5V or VDD×0.7. In the latter case, V DD×0.7, this is saying the high logic state should be at least 70% of the supply voltage (but can be up to 100%, or even a few percent higher if pixels and controller are powered from separate supplies). That 70% figure isn’t canonically true (more later), but is cited often enough; itself another rule of thumb. 70% of 5V is 3.5V, still above the 3.3V output of most microcontrollers. But one shenanigan we can pull is to use a lower supply voltage. Three AA alkaline cells provide about 4.5V, and 70% of that is 3.15V…so 3.3V logic is robust enough! The output of a lithium-polymer cell might range from 3.7–4.2V (70% = 2.6–3V), so again we’re good. NeoPixels are ostensibly 5V devices, but in reality are perfectly happy at slightly lower voltages (again, datasheet). 5 Volts is just a super common and ubiquitous voltage, provided directly by USB and many power bricks. It’s an analog world and other voltages are valid. WS2812-Compatible WorldSemi was the original manufacturer of this sort of integrated SMD addressable LEDs. Since then, others have come along producing components that use similar signaling, but aren’t 1:1 exact versions. These “WS2812-compatible” devices are often improved—better PWM frequency, more tolerant of solder reflow temperatures—and this sometimes includes a more generous logic level range, even if the datasheet isn’t explicit about this. In fact, few if any Adafruit products use the “classic” WorldSemi parts anymore. In some of these cases, that 70% rule of thumb above might be relaxed to, say, 60%. This now means that some 5V parts are perfectly happy with 3.3V logic. There are still factors to be considered, and it’s a smart move to use level shifting if you’re not sure…but if it’s not some life-saving critical infrastructure, and if it tests reliably enough in development, we might forego level shifting in some projects for simplicity! ©Adafruit Industries Page 50 of 88 Tolerances and External Factors Electronics is often depicted as being all cold, unyielding numbers…but in reality, ever ything is “ish.” A “5 Volt” power supply is really 5-ish Volts. 3.3V is really 3.3-ish Volts. This is actually an argument in favor of level shifting, but explaining why sometimes a project works without, even when it shouldn’t. Mass manufacturing just isn’t that precise; random factors creep in. Most consumergrade electronic devices might have tolerances of ±5 percent…or even a bit more. Take that 5V supply, for instance…produced by the thousands or millions…and then picture a bell curve, with 5V in the middle and most parts falling close to that. Yet you’ll have a few outliers approaching 4.5 or 5.5V…but still within allowable tolerances. Anything testing outside some range would be scrapped. It’s not just power supplies. Every single electronic component, even each individual NeoPixel, will have slightly different tolerances…sometimes in opposite directions. What can happen is that you build a project on your workbench where it tests perfectly, but later it fails when plugged into an “identical” power supply or “identical” NeoPixel strip. One or more parts…power, microcontroller, pixels, were right at the edge of some tolerance and it’s only by chance that they worked together. Change just one variable and it’s pushed over the edge! EVEN STRANGER: electronics can be subtly affected by temperature, barometric pressure, ambient light and other “random” factors! Usually a very small amount, but in edge cases this can lead to unreliable operation. For a casual “just a quick workbench demo” project, maybe the fact that it works in this one controlled setting is good enough and you can skip level shifting. But when it matters, shift! Datasheets You’d think that a manufacturer’s own component datasheet would be The Final Word™ in settling such matters, but even this is sometimes filled with colorful metaphors. These specifications are often written in the planning stages, and the final manufactured device might work beyond the intended bounds. Or sometimes figures are overly conservative to future-proof any changes. A part might recommend ≥3.5V ©Adafruit Industries Page 51 of 88 logic when it really could be happy with anything over 3V, at least today. LED manufacturers sometimes make changes to improve production efficiency, even if this alters certain operating thresholds; some padding to the numbers allows wiggle room here. Often enough, some “5V” parts (like SK6812 pixels—one of the WS2812-compatible alternatives) have proven quite reliable with 3.3V logic, even when documentation suggests otherwise. So this is another situation where we might forego level shifting. Summary If you want a NeoPixel project to be maximally robust and bulletproof, logic level shifting ensures reliable signaling. Our NeoPXL8 FeatherWings and Friend (https:// adafru.it/10DG) incorporate this, and all 3.3V ItsyBitsy boards (https://adafru.it/S4E) have a 5V logic boost on pin 5. Quite often though you can get away without level shifting, as when using a lower supply voltage. With a 5V supply and no shifting, you’re taking that small chance of unreliable operation, or “works on-desk but not in-field.” That might be good enough for casual, non-critical projects. Ask yourself if failure is an option! This guide shows a couple of level-shifting ICs and how to wire them up. (https:// adafru.it/FXc) Software NeoPixels got their start on Arduino, but have since branched out to other boards and languages. Pick a category from the left column for information specific to each coding environment. Arduino Library Installation Controlling NeoPixels “from scratch” is quite a challenge, so we provide a library letting you focus on the fun and interesting bits. The library works with most mainstream Arduino boards and derivatives: Uno, Mega, Leonardo, Micro, Adafruit Flora, etc. — most anything with an Atmel AVR 8-bit processor from 8 to 16 MHz — and also works with the Arduino Due and all varieties of the PJRC Teensy boards. ©Adafruit Industries Page 52 of 88 Because processor-specific assembly language is used, this library does not work on Netduino, ChipKIT or other advanced “Arduino-like” boards. Others may have written code and libraries for such boards, but we’re not able to provide technical support for any bugs or trouble you might encounter there; it’s some real frontier engineering. Some of these alternative libraries are covered in the “Advanced Coding” section. Install Adafruit_NeoPixel via Library Manager Recent versions of the Arduino IDE (1.6.2 and later) make library installation super easy via the Library Manager interface. From the Sketch menu, > Include Library > Ma nage Libraries...  In the text input box type in "NeoPixel". Look for "Adafruit NeoPixel by Adafruit" and select the latest version by clicking on the popup menu next to the In stall button. Then click on the Install button. After it's installed, you can click the "close" button. Manually Install Adafruit_NeoPixel Library If you’re using an older version of the IDE, or just want to set things up manually, “classic” installation of the library is as follows: you can visit the Adafruit_NeoPixel library page (https://adafru.it/aZU) at Github and download from there, or just click this button: Download Adafruit_NeoPixel for Arduino https://adafru.it/cDj 1. Uncompress the ZIP file after it’s finished downloading. ©Adafruit Industries Page 53 of 88 2. The resulting folder should contain the files Adafruit_NeoPixel.cpp, Adafruit_Ne oPixel.h and an “examples” sub-folder. Sometimes in Windows you’ll get an intermediate-level folder and need to move things around. 3. Rename the folder (containing the .cpp and .h files) to Adafruit_NeoPixel (with the underscore and everything), and place it alongside your other Arduino libraries, typically in your (home folder)/Documents/Arduino/Libraries folder. Libraries should never be installed in the “Libraries” folder alongside the Arduino application itself…put them in the subdirectory of your home folder. 4. Re-start the Arduino IDE if it’s currently running. Here’s a tutorial (https://adafru.it/aYM) that walks through the process of correctly installing Arduino libraries manually. A Simple Code Example: strandtest Launch the Arduino IDE. From the File menu, select Examples→Adafruit NeoPixel→strandtest (or, in earlier IDE releases, it’s File→Sketchbook→Libraries→Adafruit_NeoPixel→strandtest). If the Adafruit_NeoPixel rollover menu is not present, the library has not been correctly installed, or the IDE needs to be restarted after installation. Check the installation steps above to confirm it’s properly named and located. Select your board type and serial port from the Tools menu, and try uploading to the board. If the NeoPixels are connected and powered as previously described, you should see a little light show. Nothing happens! Check your connections. The most common mistake is connecting to the output end of a strip rather than the input. Something happens but the LEDs are blinking in a weird way! If you are using an RGBW NeoPixel product (look at the LEDs, are they divided in half with a yellow semicircle? You have RGBW Neopixels!) ©Adafruit Industries Page 54 of 88 Change this line: Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800); to Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_RGBW + NEO_KHZ800); and reupload the strandtest example. I don't have RGBW LEDs and the LEDs are still blinking weird! 99% of the time this is due to not having a shared ground wire connected to the Arduino. Make sure the Ground wire from the Neopixels connects to BOTH your power supply ground AND the Arduino ground. Arduino Library Use Doxygen-generated documentation for the Adafruit_NeoPixel library is available here. (https://adafru.it/Etk) It’s assumed at this point that you have the Adafruit_NeoPixel library for Arduino installed and have run the strandtest example sketch successfully. If not, return to the prior page for directions to set that up. To learn about writing your own NeoPixel sketches, let’s begin by dissecting the strandtest sketch… All NeoPixel sketches begin by including the header file: #include <Adafruit_NeoPixel.h> The block of code that follows is mostly descriptive comments. Only a couple lines are really doing any work: // Which pin on the Arduino is connected to the NeoPixels? // On a Trinket or Gemma we suggest changing this to 1: #define LED_PIN 6 // How many NeoPixels are attached to the Arduino? #define LED_COUNT 60 ©Adafruit Industries Page 55 of 88 // Declare our NeoPixel strip object: Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800); // Argument 1 = Number of pixels in NeoPixel strip // Argument 2 = Arduino pin number (most are valid) // Argument 3 = Pixel type flags, add together as needed: // NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs) // NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers) // NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products) // NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2) // NEO_RGBW Pixels are wired for RGBW bitstream (NeoPixel RGBW products) The first few lines assign numbers to the symbols “LED_PIN” and “LED_COUNT” for later reference. It doesn’t need to be done this way, but makes it easier to change the pin and length where the NeoPixels are connected without digging deeper into the code. The last line declares a NeoPixel object. We’ll refer to this by name later to control the strip of pixels. There are three parameters or arguments in parenthesis: 1. The number of sequential NeoPixels in the strip. In the example this is set to LED_COUNT, which was defined as 60 above, equal to 1 meter of mediumdensity strip. Change this to match the actual number you’re using. 2. The pin number to which the NeoPixel strip (or other device) is connected. Normally this would be a number, but we previously declared the symbol LED_PI N to refer to it by name here. 3. A value indicating the type of NeoPixels that are connected. In most cases you can leave this off and pass just two arguments; the example code is just being extra descriptive. If you have a supply of classic “V1” Flora pixels, those require NEO_KHZ400 + NEO_RGB to be passed here. RGBW NeoPixels also require a different value here: NEO_RGBW. For through-hole 8mm NeoPixels, use NEO_RGB instead of NEO_GRB in the strip declaration. For RGBW LEDs use NEO_RGBW (some RGBW strips use NEO_GRBW, so try that if you're getting unexpected results!) Then, in the setup() function, call begin() to prepare the data pin for NeoPixel output: void setup() { strip.begin(); strip.show(); // Initialize all pixels to 'off' } The second line, strip.show(), isn’t absolutely necessary, it’s just there to be thorough. That function pushes data out to the pixels…since no colors have been set yet, this initializes all the NeoPixels to an initial “off” state in case some were left lit by a prior program. ©Adafruit Industries Page 56 of 88 The Adafruit Trinket 5V 16 MHz board requires a little extra setup. You can see the steps required in the “strandtest” example sketch. In the strandtest example, loop() doesn’t set any pixel colors on its own — it calls other functions that create animated effects. So let’s ignore it for now and look ahead, inside the individual functions, to see how the strip is controlled. There are a couple different ways to set the color of a pixel. The first is: strip.setPixelColor(n, red, green, blue); or, if you're using RGBW strips: strip.setPixelColor(n, red, green, blue, white); The first argument — n in this example — is the pixel number along the strip, starting from 0 closest to the Arduino. If you have a strip of 30 pixels, they’re numbered 0 through 29. It’s a computer thing. You’ll see various places in the code using a for loop, passing the loop counter variable as the pixel number to this function, to set the values of multiple pixels. The next three arguments are the pixel color, expressed as red, green and blue brightness levels, where 0 is dimmest (off) and 255 is maximum brightness. The last o ptional argument is for white, which will only be used if the strip was defined during creation as an RGBW type and the strip actually is RGBW type. To set the 12th pixel (#11, counting from 0) to magenta (red + blue), you could write: strip.setPixelColor(11, 255, 0, 255); to set the 8th pixel (#7 counting from 0) to half-brightness white (with an RGBW strip), with no light from red/green/blue, use: strip.setPixelColor(7, 0, 0, 0, 127); An alternate syntax has just two arguments: strip.setPixelColor(n, color); Here, color is a 32-bit type that merges the red, green and blue values into a single number. This is sometimes easier or faster for some (but not all) programs to work ©Adafruit Industries Page 57 of 88 with; you’ll see the strandtest code uses both syntaxes in different places. You can also convert separate red, green and blue values into a single 32-bit type for later use: uint32_t magenta = strip.Color(255, 0, 255); Then later you can just pass “magenta” as an argument to setPixelColor rather than the separate red, green and blue numbers every time. You can also (optionally) add a white component to the color at the end, like this: uint32_t greenishwhite = strip.Color(0, 64, 0, 64); setPixelColor() does not have an immediate effect on the LEDs. To “push” the color data to the strip, call show(): strip.show(); This updates the whole strip at once, and despite the extra step is actually a good thing. If every call to setPixelColor() had an immediate effect, animation would appear jumpy rather than buttery smooth. Multiple pixels can be set to the same color using the fill() function, which accepts one to three arguments. Typically it’s called like this: strip.fill(color, first, count); “color” is a packed 32-bit RGB (or RGBW) color value, as might be returned by strip.Color(). There is no option here for separate red, green and blue, so call the Color() function to pack these into one value. “first” is the index of the first pixel to fill, where 0 is the first pixel in the strip, and strip.numPixels() - 1 is the last. Must be a positive value or 0. “count” is the number of pixels to fill. Must be a positive value. If called without a count argument (only color and first), this will from first to the end of the strip. ©Adafruit Industries Page 58 of 88 If called without first or count arguments (only color), the full strip will be set to the requested color. If called with no arguments, the strip will be filled with black or “off,” but there’s also a different syntax which might be easier to read: strip.clear(); You can query the color of a previously-set pixel using getPixelColor(): uint32_t color = strip.getPixelColor(11); This returns a 32-bit merged RGB color value. This is always RGB, even if the “ColorHSV()” function (described below) was used. The number of pixels in a previously-declared strip can be queried using numPixels(): uint16_t n = strip.numPixels(); The overall brightness of all the LEDs can be adjusted using setBrightness(). This takes a single argument, a number in the range 0 (off) to 255 (max brightness). For example, to set a strip to 1/4 brightness: strip.setBrightness(64); Just like setPixel(), this does not have an immediate effect. You need to follow this with a call to show(). setBrightness() was intended to be called once, in setup(), to limit the current/ brightness of the LEDs throughout the life of the sketch. It is not intended as an animation effect itself! The operation of this function is “lossy” — it modifies the current pixel data in RAM, not in the show() call — in order to meet NeoPixels’ strict timing requirements. Certain animation effects are better served by leaving the brightness setting at the default maximum, modulating pixel brightness in your own sketch logic and redrawing the full strip with setPixel(). HSV (Hue-Saturation-Value) Colors… The NeoPixel library has some support for colors in the “HSV” (hue-saturation-value) color space. This is a different way of specifying colors than the usual RGB (red- ©Adafruit Industries Page 59 of 88 green-blue). Some folks find it easier or more “natural” to think about…or quite often it’s just easier for certain color effects (the popular rainbow cycle and such). In the NeoPixel library, hue is expressed as a 16-bit number. Starting from 0 for red, this increments first toward yellow (around 65536/6, or 10922 give or take a bit), and on through green, cyan (at the halfway point of 32768), blue, magenta and back to red. In your own code, you can allow any hue-related variables to overflow or underflow and they’ll “wrap around” and do the correct and expected thing, it’s really nice. Saturation determines the intensity or purity of the color…this is an 8-bit number ranging from 0 (no saturation, just grayscale) to 255 (maximum saturation, pure hue). In the middle, you’ll start to get sort of pastel tones. Value determines the brightness of a color…it’s also an 8-bit number ranging from 0 (black, regardless of hue or saturation) to 255 (maximum brightness). setPixelColor() and fill() both still want RGB values though, so we convert to these from HSV by using the ColorHSV() function: uint32_t rgbcolor = strip.ColorHSV(hue, saturation, value); If you just want a “pure color” (fully saturated and full brightness), the latter two arguments can be left off: uint32_t rgbcolor = strip.ColorHSV(hue); In either case, the resulting RGB value can then be passed to a pixel-setting function, e.g.: strip.fill(rgbcolor); ©Adafruit Industries Page 60 of 88 There is no corresponding function to go the other way, from RGB to HSV. This is on purpose and by design, because conversion in that direction is often ambiguous — there may be multiple valid possibilities for a given input. If you look at some of the example sketches you’ll see they keep track of their own hues…they don’t assign colors to pixels and then try to read them back out again. …and Gamma Correction Something you might observe when working with more nuanced color changes is that things may appear overly bright or washed-out. It’s generally not a problem with simple primary and secondary colors, but becomes more an issue with blends, transitions, and the sorts of pastel colors you might get from the ColorHSV() function. Numerically the color values are correct, but perceptually our eyes make something different of it, as explained in this guide (https://adafru.it/w2B). The gamma32() function takes a packed RGB value (as you might get out of Color() or ColorHSV()) and filters the result to look more perceptually correct. uint32_t rgbcolor = strip.gamma32(strip.ColorHSV(hue, sat, val)); You might notice in strandtest and other example sketches that we never use ColorHSV() without passing the result through gamma32() before setting a pixel’s color. It’s that desirable. However, the gamma32 operation is not built in to ColorHSV() — it must be called as a separate operation — for a few reasons, including that advanced programmers might want to provide a more specific color-correction function of their own design (gamma32() is a “one size fits most” approximation) or may need to keep around the original “numerically but not perceptually correct” numbers. There is no corresponding reverse operation. When you set a pixel to a color filtered through gamma32(), reading back the pixel value yields that filtered color, not the original RGB value. It’s precisely because of this sort of decimation that advanced NeoPixel programs often treat the pixel buffer as a write-only resource…they generate each full frame of animation based on their own program state, not as a series of read-modify-write operations. Help! ©Adafruit Industries Page 61 of 88 I’m calling setPixel() but nothing’s happening! There are two main culprits for this: 1. forgetting to call strip.begin() in setup(). 2. forgetting to call strip.show() after setting pixel colors. Another (less common) possibility is running out of RAM — see the last section below. If the program works but has unpredictable results, consider that. Can I have multiple NeoPixel objects on different pins? Certainly! Each requires its own declaration with a unique name: Adafruit_NeoPixel strip_a = Adafruit_NeoPixel(16, 5); Adafruit_NeoPixel strip_b = Adafruit_NeoPixel(16, 6); The above declares two distinct NeoPixel objects, one each on pins 5 and 6, each containing 16 pixels and using the implied default type (NEO_KHZ800 + NEO_GRB). Can I connect multiple NeoPixel strips to the same Arduino pin? In many cases, yes. All the strips will then show exactly the same thing. This only works up to a point though…four strips on a single pin is a good and reliable number. If you need more than that, individual NeoPixels can be used as buffers to “fan out” to more strips: connect one Arduino pin to the inputs of four separate NeoPixels, then connect each pixels’ output to the inputs of four strips (or fewer, if you don’t need quite that many). If the strips are 10 pixels long, declare the NeoPixel object as having 11 pixels. The extra “buffer” pixels will be at position #0 — just leave them turned off — and the strips then run from positions 1 through 10. I'm getting the wrong colors. Red and blue are swapped! When using through-hole 8mm NeoPixels (or V1 Flora pixels), use NEO_RGB for the third parameter in the Adafruit_NeoPixel declaration. For all other types of NeoPixels, use NEO_GRB. The colors fall apart when I use setBrightness() repeatedly! See note above; setBrightness() is designed as a one-time setup function, not an animation effect. ©Adafruit Industries Page 62 of 88 Also see the “Advanced Coding” page — there’s an alternative library that includes “nondestructive” brightness adjustment, among other features! Pixels Gobble RAM Each NeoPixel requires about 3 bytes of RAM. This doesn’t sound like very much, but when you start using dozens or even hundreds of pixels, and consider that the mainstream Arduino Uno only has 2 kilobytes of RAM (often much less after other libraries stake their claim), this can be a real problem! For using really large numbers of LEDs, you might need to step up to a more potent board like the Arduino Mega or Due. But if you’re close and need just a little extra space, you can sometimes tweak your code to be more RAM-efficient. This tutorial has some pointers on memory usage. (https://adafru.it/coj) Arduino Library Best Practices This blog post has suggestions on writing “modern” NeoPixel code (https://adafru.it/ 105c) to avoid old copy-and-paste bad habits and deprecated techniques. NeoMatrix Library The Adafruit_NeoMatrix library for Arduino builds upon Adafruit_NeoPixel to create two-dimensional graphic displays using NeoPixels. You can then easily draw shapes, text and animation without having to calculate every X/Y pixel position. Small NeoPixel matrices are available in the shop. Larger displays can be formed using sections of NeoPixel strip, as shown in the photo above. ©Adafruit Industries Page 63 of 88 In addition to the Adafruit_NeoPixel library (which was already downloaded and installed in a prior step), NeoMatrix requires two additional libraries: 1. Adafruit_NeoMatrix (https://adafru.it/cDt) 2. Adafruit_GFX (https://adafru.it/cBB) If you’ve previously used any Adafruit LCD or OLED displays, you might already have the latter library installed. Installation for both is similar to Adafruit_NeoPixel before: unzip, make sure the folder name matches the .cpp and .h files within, then move to your Arduino libraries folder and restart the IDE. If using an older (pre-1.8.10) Arduino IDE, you’ll also need to locate and install Adafruit _BusIO (https://adafru.it/Ldl). Arduino sketches need to include all three headers just to use this library: #include <Adafruit_GFX.h> #include <Adafruit_NeoMatrix.h> #include <Adafruit_NeoPixel.h> Adafruit_GFX Primer Adafruit_GFX is a library providing a set of graphics functions such as lines, circles and text…all of our LCD and OLED displays use this. If you don’t have prior experience, the key concepts of Adafruit_GFX are explained in another guide (https:// adafru.it/doL). We’ll focus on just the NeoMatrix particulars from here on… Layouts Adafruit_NeoMatrix uses exactly the same coordinate system, color functions and graphics commands as the Adafruit_GFX library. If you’re new to the latter, a separate tutorial explains its use (https://adafru.it/aPe). There are also example sketches included with the Adafruit_NeoMatrix library. We’ll just focus on the constructor here — how to declare a two-dimensional display made from NeoPixels. Powering the beast is another matter, covered on the prior page. ©Adafruit Industries Page 64 of 88 The library handles both single matrices — all NeoPixels in a single uniform grid — and tiled matrices — multiple grids combined into a larger display: Let’s begin with the declaration for a single matrix, because it’s simpler to explain. We’ll be demonstrating the NeoPixel Shield for Arduino in this case — an 8x5 matrix of NeoPixels. When looking at this shield with the text in a readable orientation, the first pixel, #0, is at the top left. Each successive pixel is right one position — pixel 1 is directly to the right of pixel 0, and so forth. At the end of each row, the next pixel is at the left side of the next row. This isn’t something we decide in code…it’s how the NeoPixels are hard-wired in the circuit board comprising the shield. We refer to this layout as row major and progressive. Row major means the pixels are arranged in horizontal lines (the opposite, in vertical lines, is column major). Progressi ve means each row proceeds in the same direction. Some matrices will reverse direction on each row, as it can be easier to wire that way. We call that a zigzag layout. ©Adafruit Industries Page 65 of 88 However…for this example, we want to use the shield in the “tall” direction, so the Arduino is standing up on the desk with the USB cable at the top. When we turn the board this way, the matrix layout changes… Now the first pixel is at the top right. Pixels increment top-to-bottom — it’s now colum n major. The order of the columns is still progressive though. We declare the matrix thusly: Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(5, 8, 6, NEO_MATRIX_TOP + NEO_MATRIX_RIGHT + NEO_MATRIX_COLUMNS + NEO_MATRIX_PROGRESSIVE, NEO_GRB + NEO_KHZ800); The first two arguments — 5 and 8 — are the width and height of the matrix, in pixels. The third argument — 6 — is the pin number to which the NeoPixels are connected. On the shield this is hard-wired to digital pin 6, but standalone matrices are free to use other pins. ©Adafruit Industries Page 66 of 88 The next argument is the interesting one. This indicates where the first pixel in the matrix is positioned and the arrangement of rows or columns. The first pixel must be at one of the four corners; which corner is indicated by adding either NEO_MATRIX_T OP or NEO_MATRIX_BOTTOM to either NEO_MATRIX_LEFT or NEO_MATRIX_RIGHT. The row/column arrangement is indicated by further adding either NEO_MATRIX_COL UMNS or NEO_MATRIX_ROWS to either NEO_MATRIX_PROGRESSIVE or NEO_MATRI X_ZIGZAG. These values are all added to form a single value as in the above code. NEO_MATRIX_TOP + NEO_MATRIX_RIGHT + NEO_MATRIX_COLUMNS + NEO_MATRIX_PROGRESSIVE The last argument is exactly the same as with the NeoPixel library, indicating the type of LED pixels being used. In the majority of cases with the latest NeoPixel products, you can simply leave this argument off…the example code is just being extra descriptive. The point of this setup is that the rest of the sketch never needs to think about the layout of the matrix. Coordinate (0,0) for drawing graphics will always be at the topleft, regardless of the actual position of the first NeoPixel. Why not just use the rotation feature in Adafruit_GFX? Adafruit_GFX only handles rotation. Though it would handle our example above, it doesn’t cover every permutation of rotation that may occur with certain matrix layouts, not to mention the zig-zag capability, or this next bit… Tiled Matrices A tiled matrix is comprised of multiple smaller NeoPixel matrices. This is sometimes easier for assembly or for distributing power. All of the sub-matrices need to be the same size, and must be ordered in a predictable manner. The Adafruit_NeoMatrix() constructor then receives some additional arguments: Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix( matrixWidth, matrixHeight, tilesX, tilesY, pin, matrixType, ledType); The first two arguments are the width and height, in pixels, of each tiled sub-matrix, n ot the entire display. The next two arguments are the number of tiles, in the horizontal and vertical direction. The dimensions of the overall display then will always be a multiple of the sub-matrix dimensions. ©Adafruit Industries Page 67 of 88 The fifth argument is the pin number, same as before and as with the NeoPixel library. The last argument also follows prior behaviors, and in most cases can be left off. The second-to-last argument though…this gets complicated… With a single matrix, there was a starting corner, a major axis (rows or columns) and a line sequence (progressive or zigzag). This is now doubled — similar information is needed both for the pixel order within the individual tiles, and the overall arrangement of tiles in the display. As before, we add up a list of symbols to produce a single argument describing the display format. The NEO_MATRIX_* symbols work the same as in the prior single-matrix case, and now refer to the individual sub-matrices within the overall display. All tiles must follow the same format. An additional set of symbols work similarly to then describe the tile order. The first tile must be located at one of the four corners. Add either NEO_TILE_TOP or NEO_TILE_BOTTOM and NEO_TILE_LEFT or NEO_TILE_RIGHT to indicate the position of the first tile. This is independent of the position of the first pixel within the tiles; they can be different corners. Tiles can be arranged in horizontal rows or vertical columns. Again this is independent of the pixel order within the tiles. Add either NEO_TILE_ROWS or NEO_ TILE_COLUMNS. Finally, rows or columns of tiles may be arranged in progressive or zigzag order; that is, every row or column proceeds in the same order, or alternating rows/columns switch direction. Add either NEO_TILE_PROGRESSIVE or NEO_TILE_ZIGZAG to indicate the order. BUT…if NEO_TILE_ZIGZAG order is selected, alternate lines of tiles must be rotated 180 degrees. This is intentional and by design; it keeps the tile-to-tile wiring more consistent and simple. This rotation is not required for NEO_TILE_PROGR ESSIVE. ©Adafruit Industries Page 68 of 88 Tiles don’t need to be square! The above is just one possible layout. The display shown at the top of this page is three 10x8 tiles assembled from NeoPixel strip. Once the matrix is defined, the remainder of the project is similar to Adafruit_NeoPixel. Remember to use matrix.begin() in the setup() function and matrix.s how() to update the display after drawing. The setBrightness() function is also available. The library includes a couple of example sketches for reference. Other Layouts For any other cases that are not uniformly tiled, you can provide your own function to remap X/Y coordinates to NeoPixel strip indices. This function should accept two unsigned 16-bit arguments (pixel X, Y coordinates) and return an unsigned 16-bit value (corresponding strip index). The simplest row-major progressive function might resemble this: uint16_t myRemapFn(uint16_t x, uint16_t y) { return WIDTH * y + x; } That’s a crude example. Yours might be designed for pixels arranged in a spiral (easy wiring), or a Hilbert curve. The function is then enabled using setRemapFunction(): matrix.setRemapFunction(myRemapFn); RAM Again On a per-pixel basis, Adafruit_NeoMatrix is no more memory-hungry than Adafruit_NeoPixel, requiring 3 bytes of RAM per pixel. But the number of pixels in a two-dimensional display takes off exponentially…a 16x16 display requires four times the memory of an 8x8 display, or about 768 bytes of RAM (nearly half the available ©Adafruit Industries Page 69 of 88 space on an Arduino Uno). It can be anywhere from tricky to impossible to combine large displays with memory-hungry libraries such as SD or ffft. Gamma Correction Because the Adafruit_GFX library was originally designed for LCDs (having limited color fidelity), it handles colors as 16-bit values (rather than the full 24 bits that NeoPixels are capable of). This is not the big loss it might seem. A quirk of human vision makes bright colors less discernible than dim ones. The Adafruit_NeoMatrix library uses gamma correction to select brightness levels that are visually (though not numerically) equidistant. There are 32 levels for red and blue, 64 levels for green. The Color() function performs the necessary conversion; you don’t need to do any math. It accepts 8-bit red, green and blue values, and returns a gamma-corrected 16bit color that can then be passed to other drawing functions. Advanced Coding FastLED Library If looking to boost your NeoPixel prowess, you may find everything you need in the F astLED library (https://adafru.it/eip). It’s an alternative to the Adafruit_NeoPixel library, providing more advanced features like HSV color support, nondestructive brightness setting and high-speed mathematical operations. (It works with other LED types too, such as DotStars!) FastLED works altogether differently; it’s not a drop-in replacement for Adafruit_NeoPixel, and existing sketches will require some rewriting. Note: FastLED currently works only with RGB NeoPixels; RGBW pixels are not yet supported. At all. You will get incorrect and unpredictable colors. We don’t write or maintain FastLED, and can’t provide software troubleshooting advice. If requesting help with a FastLED NeoPixel project in the forums, we’ll usually ask that you try one of the known-working Adafruit_NeoPixel example sketches to narrow down whether it’s a hardware or software issue. Visit the FastLED web site to get started. (https://adafru.it/eip) ©Adafruit Industries Page 70 of 88 FAQ and Further Programming Insights Help! My Arduino servo code stops working when combined with NeoPixels! Unfortunately the NeoPixel and Servo libraries don’t play nice together; one is dependent on periodically disabling interrupts, the other absolutely requires interrupts. There are a couple of options here: • Use a dedicated servo control shield (http://adafru.it/1411) or breakout board (http://adafru.it/815), offloading that task from the processor so interrupts are a non-issue. • Use a hardware-PWM-based servo library (https://adafru.it/kDh) rather than the stock Arduino Servo library. This can provide rock-steady servo timing without interrupts, but can only control a very limited number of servos (2-3), and only on very specific pins. When driving NeoPixels I cannot receive infrared codes on my IR receiver! Just like servos, the infrared library uses software interrupts to poll the IR LED, while the standard NeoPixel library blocks interrupts while NeoPixel are being updated. If you don't constantly update the NeoPixel, IR will work in between updates, but if you update them all the time, you will need to use another library and a microcontroller more capable than an Uno or Mega. Ideally one with DMA so that NeoPixels don't take up any CPU cycles. Marc MERLIN explains how to this depending on what chip you have (Teensy, ESP8266 or ESP32): http://marc.merlins.org/perso/arduino/post_2017-04-03_Arduino-328P-UnoTeensy3_1-ESP8266-ESP32-IR-and-Neopixels.html (https://adafru.it/xA2) How fast can I refresh a string of (N) pixels? NeoPixels receive data from a fixed-frequency 800 KHz datastream (except for “V1” Flora pixels, which use 400 KHz). Each bit of data therefore requires 1/800,000 sec — 1.25 microseconds. One pixel requires 24 bits (8 bits each for red, green blue) — 30 microseconds. After the last pixel’s worth of data is issued, the stream must stop for at least 50 microseconds for the new colors to “latch.” ©Adafruit Industries Page 71 of 88 For a strip of 100 pixels, that’s (100 * 30) + 50, or 3,050 microseconds. 1,000,000 / 3,050 = 328 updates per second, approximately. However… That’s only the time needed to push the bits down the wire. The actual refresh rate will be something less than this, and can’t be estimated as a single number for all cases. It takes time to process each “frame” of animation. How much time depends on the complexity of the math and the efficiency of the code (for example, floatingpoint calculations can be relatively slow). The formula above gives a maximum theoretical rate, but that’s just a starting point. Reality in some cases could fall an order of magnitude (or more) below this. For exploratory benchmarking, you can always write code as if a large number of pixels were present, and time the result. The extra output bits will simply be ignored by the strip (or you can even test with no NeoPixels connected at all). That won’t do. Now what? Because NeoPixels use a fixed-frequency clock, options are limited. You can’t switch out for a faster microcontroller and expect substantially different results. One option is to use a different LED type, such as our DotStar or LPD8806 strips, or WS2801 pixels. These can be driven at higher data rates, though they do have some other tradeoffs with respect to NeoPixels (cost, color resolution and/or pixel density). Another is to develop your own code on a more capable microcontroller or an FPGA that drives multiple NeoPixel strips in parallel. One such project — OctoWS2811 for the Teensy 3 microcontroller — is shown later. This sort of thing is a complex undertaking and not recommended for beginners. And even among more experienced programmers, there’s often an unreasonable over-emphasis on data rates when the real bottlenecks lie elsewhere…don’t dwell on this too much unless you can confirm it’s the root of the problem. Can I control NeoPixels using (Board X)? We currently only offer an Arduino library. See the links later for other devices. For anything beyond this, if considering writing your own library, understand that some processors are better suited to the task than others. Read through the timing requirements shown below and determine if the chip in question can synthesize a signal meeting those specifications. An 8 MHz AVR can just barely keep up… ©Adafruit Industries Page 72 of 88 anything slower may have trouble, though some hardware-specific hacks (like clever use of SPI) might make it possible. In many cases, assembly language is required. What’s up with Raspberry Pi? This guide focuses mostly on Arduino and similar microcontroller boards where NeoPixel support is most robust. Raspberry Pi control of NeoPixels is possible, but requires special libraries and/or is limited to specific pins…it’s all a bit beyond the scope of this guide. The wiring and power guidance here is valid for any device though. We tend toward DotStar LEDs in Raspberry Pi projects, as in this Raspberry Pi light painter (https://adafru.it/KJB).  DMA NeoPixels for ARM Cortex-M0 Boards If you’re using a recent “M0” development board such as the Adafruit Feather M0, Circuit Playground Express or Arduino Zero, an alternate NeoPixel library (https:// adafru.it/xBb) exploits these devices’ direct memory access (DMA) feature to operate more smoothly. Advanced Arduino sketches can then use interrupts with impunity, and code that depends on the millis() or micros() functions will not lose time. There’s a corresponding DMA version of the NeoMatrix library (https://adafru.it/xAQ) as well. Plus a super potent 8-way concurrent NeoPixel DMA library (https://adafru.it/Blw). We offer a companion FeatherWing (https://adafru.it/Et6) and breakout board (https:// adafru.it/CJd) to make connections and level-shifting easier! Third-Party Libraries In addition to the previously-mentioned FastLED library, NeoPixel-compatible libraries have been developed for devices beyond Arduino. Please keep in mind that Adafruit did not develop any of this code and can’t fix bugs or offer technical help. This is Wild West stuff. • OctoWS2811 (https://adafru.it/cDM): specifically for the PJRC Teensy 3.0 microcontroller board. Uses DMA to drive up to 8 NeoPixel strips concurrently ©Adafruit Industries Page 73 of 88 with minimal processor load. Multiple boards can be cascaded for still larger displays. • FadeCandy (https://adafru.it/cDN): also for Teensy 3.0. Doesn’t support as many pixels as OctoWS2811, but adds dithering and smooth interpolation for color purists. • LEDscape (https://adafru.it/cDO): specifically for BeagleBone Black. Although the BeagleBone is a multitasking Linux system like the not-NeoPixel-compatible Raspberry Pi, this code exploits hardware features specific to the BeagleBone Black to drive hundreds of meters of NeoPixel strip with virtually no processor load. • WS2812 LED Driver (https://adafru.it/Etc) for Parallax Propeller. • xCORE NeoPixel test code (https://adafru.it/dcO) for the XMOS xCORE startKIT. • light_ws2812 (https://adafru.it/UBV): an alternate Arduino library for AVR and ARM microcontrollers. Some of these are 3.3V devices. See the “Powering NeoPixel” page for notes on controlling 5V NeoPixels from 3.3V microcontrollers. WS2811? WS2812? B? SK6812? Why do I see different names mentioned? NeoPixels have evolved through several generations: • WS2811 is a driver chip separate from the RGB LED • WS2812 integrated the driver and RGB LED in a single package • WS2812B is a newer generation WS2812 — the color balance is slightly different and the data signal “latch” time is longer • SK6812 is a “WS2812-compatible” part from other manufacturers — we’ve adopted these for most NeoPixel-branded products as they better tolerate different voltages. On the original WS2811, chip, the data stream runs at half the speed. When the WS2812 came along, a lot of code and projects had already built up around the WS2811 name — so, for instance, you’ll see projects like “OctoWS2811” and others but they’ll really work with all of these! Writing Your Own Library The WS2812 datasheet (https://adafru.it/cDB) explains the data transmission protocol. This is a self-clocking signal — there’s only one wire, not separate data and clock ©Adafruit Industries Page 74 of 88 lines. “1” and “0” bits are indicated by varying the duty cycle of a fixed-frequency square wave. There’s a math goof in the datasheet’s timing values. Use these figures instead: Note that there’s nearly 25% “wiggle room” in the timing. So if your code can’t match the recommended times exactly, it’s usually okay, as long as it’s close. There are three bytes of data for each pixel. These should be issued in green, red, blue order, with the most-significant bit first. The data for pixel #0 (nearest the microcontroller) is issued first, then pixel #1, and so forth to the furthest pixel. This does not operate like a traditional shift register! All the data for the whole run must be issued. You can’t address individual pixels in the middle of a run. After all the color data is sent, the data line must be held low for a minimum of 300 microseconds for the new colors to “latch.” You may want to dig through our Arduino library (https://adafru.it/aZU) for insights. The timing-critial parts are written in AVR assembly language, but it’s extensively commented with C-like pseudocode. ©Adafruit Industries Page 75 of 88 My Microcontroller Isn’t Fast Enough to Do That The WS2812 appears to be backwardly-compatible with the 400 KHz WS2811 signal. If you can precisely match the latter chip’s timing, either type will respond. The WS2811 protocol is not simply a half-speed WS2812. The duty cycle for the “0” and “1” bits is slightly different. From the WS2811 datasheet (https://adafru.it/cDS): Python & CircuitPython It's easy to use NeoPixel LEDs with Python or CircuitPython and the Adafruit CircuitPython NeoPIxel (https://adafru.it/yew) module.  This module allows you to easily write Python code that controls your LEDs. You can use these LEDs with any CircuitPython microcontroller board or with a computer that has GPIO and Python thanks to Adafruit_Blinka, our CircuitPython-forPython compatibility library (https://adafru.it/BSN). Of single boards computers, only Raspberry Pi computers have NeoPixel support at this time. CircuitPython Microcontroller Wiring First wire up some NeoPixels to your board exactly as shown on the previous pages. Verify your connection is on the DATA INPUT or DIN side. Plugging into the DATA OUT or DOUT side is a common mistake! The connections are labeled and some formats have arrows to indicate the direction the data must flow. Do not use the USB pin on your microcontroller for powering more than a few LEDs! For more than that, you'll want to use an external power source. For more information, check out the Powering NeoPixels page of this guide: https:// learn.adafruit.com/adafruit-neopixel-uberguide/powering-neopixels Here's an example of wiring a Feather M0 to a NeoPIxel strip: ©Adafruit Industries Page 76 of 88 Board USB to LED 5V Board GND to LED GND Board D5 to LED Din The choice of digital pin 5 here is arbitrary for the sake of example. With few exceptions, most any pin will do. On ItsyBitsy boards, this pin is special and has a 5V level shifter built in. A Feather board does not, and the NeoPixel FeatherWing normally uses pin 6 for control (or is solder-jumper selectable). Python Computer Wiring Since there's dozens of Linux computers/boards you can use we will show wiring for Raspberry Pi. For other platforms, please visit the guide for CircuitPython on Linux to see whether your platform is supported (https://adafru.it/BSN).  Here's the Raspberry Pi wired to a NeoPixel strip: Pi 5V to LED 5V Pi GND to LED GND Pi GPIO18 to LED Din On the Raspberry Pi, NeoPixels must be connected to GPIO10, GPIO12, GPIO18 or GPIO21 to work! CircuitPython Installation of NeoPixel Library You'll need to install the Adafruit CircuitPython NeoPixel (https://adafru.it/yew) library on your CircuitPython board. ©Adafruit Industries Page 77 of 88 First make sure you are running the latest version of Adafruit CircuitPython (https:// adafru.it/Amd) for your board. Next you'll need to install the necessary libraries to use the hardware--carefully follow the steps to find and install these libraries from Adafruit's CircuitPython library bundle  (https://adafru.it/uap).  Our CircuitPython starter guide has a great page on how to install the library bundle (https://adafru.it/ABU). For non-express boards like the Trinket M0 or Gemma M0, you'll need to manually install the necessary libraries from the bundle: • neopixel.mpy • adafruit_bus_device Before continuing make sure your board's lib folder or root filesystem has the neopixe l.mpy, and adafruit_bus_device files and folders copied over. Next connect to the board's serial REPL (https://adafru.it/Awz) so you are at the CircuitPython >>> prompt. Python Installation of NeoPixel Library You'll need to install the Adafruit_Blinka library that provides the CircuitPython support in Python. This may also require verifying you are running Python 3. Since each platform is a little different, and Linux changes often, please visit the CircuitPython on Linux guide to get your computer ready (https://adafru.it/BSN)! Once that's done, from your command line run the following command: • sudo pip3 install adafruit-circuitpython-neopixel If your default Python is version 3 you may need to run 'pip' instead. Just make sure you aren't trying to use CircuitPython on Python 2.x, it isn't supported! CircuitPython & Python Usage To demonstrate the usage of this library with NeoPixel LEDs, we'll use the board's Python REPL. ©Adafruit Industries Page 78 of 88 For NeoPixels to work on Raspberry Pi, you must run the code as root! Root access is required to access the RPi peripherals. Run the following code to import the necessary modules and initialise a NeoPixel strip with 30 LEDs. Don't forget to change the pin if your NeoPixels are connected to a different pin, and change the number of pixels if you have a different number. import board import neopixel pixels = neopixel.NeoPixel(board.D5, 30) # Feather wiring! # pixels = neopixel.NeoPixel(board.D18, 30) # Raspberry Pi wiring! Now you're ready to light up your NeoPixel LEDs using the following properties: • brightness - The overall brightness of the LED • fill - Color all pixels a given color. • show - Update the LED colors if auto_write is set to False . For example, to light up the first NeoPixel red: pixels[0] = (255, 0, 0) To light up all the NeoPixels green: pixels.fill((0, 255, 0)) ©Adafruit Industries Page 79 of 88 That's all there is to getting started with CircuitPython and NeoPixel LEDs! Full Example Code # SPDX-FileCopyrightText: 2021 ladyada for Adafruit Industries # SPDX-License-Identifier: MIT import time import board import neopixel # On CircuitPlayground Express, and boards with built in status NeoPixel -> board.NEOPIXEL # Otherwise choose an open pin connected to the Data In of the NeoPixel strip, i.e. board.D1 pixel_pin = board.NEOPIXEL # On a Raspberry pi, use this instead, not all pins are supported # pixel_pin = board.D18 # The number of NeoPixels num_pixels = 10 # The order of the pixel colors - RGB or GRB. Some NeoPixels have red and green reversed! # For RGBW NeoPixels, simply change the ORDER to RGBW or GRBW. ORDER = neopixel.GRB pixels = neopixel.NeoPixel( pixel_pin, num_pixels, brightness=0.2, auto_write=False, pixel_order=ORDER ) def wheel(pos): # Input a value 0 to 255 to get a color value. # The colours are a transition r - g - b - back to r. if pos < 0 or pos > 255: r = g = b = 0 elif pos < 85: r = int(pos * 3) g = int(255 - pos * 3) b = 0 elif pos < 170: pos -= 85 r = int(255 - pos * 3) g = 0 b = int(pos * 3) else: pos -= 170 r = 0 g = int(pos * 3) b = int(255 - pos * 3) return (r, g, b) if ORDER in (neopixel.RGB, neopixel.GRB) else (r, g, b, 0) def rainbow_cycle(wait): for j in range(255): for i in range(num_pixels): pixel_index = (i * 256 // num_pixels) + j pixels[i] = wheel(pixel_index & 255) pixels.show() time.sleep(wait) ©Adafruit Industries Page 80 of 88 while True: # Comment this line out if you have RGBW/GRBW NeoPixels pixels.fill((255, 0, 0)) # Uncomment this line if you have RGBW/GRBW NeoPixels # pixels.fill((255, 0, 0, 0)) pixels.show() time.sleep(1) # Comment this line out if you have RGBW/GRBW NeoPixels pixels.fill((0, 255, 0)) # Uncomment this line if you have RGBW/GRBW NeoPixels # pixels.fill((0, 255, 0, 0)) pixels.show() time.sleep(1) # Comment this line out if you have RGBW/GRBW NeoPixels pixels.fill((0, 0, 255)) # Uncomment this line if you have RGBW/GRBW NeoPixels # pixels.fill((0, 0, 255, 0)) pixels.show() time.sleep(1) rainbow_cycle(0.001) # rainbow cycle with 1ms delay per step Python Docs Python Docs (https://adafru.it/C5m) MakeCode We’ve got a whole separate guide explaining the use of NeoPixels in Microsoft MakeCode (https://adafru.it/wpC): Guide Link: NeoPixels with MakeCode (http s://adafru.it/D1L) Many of the examples work right in your browser with Circuit Playground Express (htt ps://adafru.it/wpF) and its 10 built-in NeoPixel LEDs. There’s even a page explaining how to use MakeCode with external strips (https://adafru.it/Etd) as well. Downloads • SK6812 RGBW Datasheet (https://adafru.it/UA1) (used in most of our RGBW products) • SK6812 RGB Datasheet (https://adafru.it/uaS) (used in most of our RGB products as of 2016) ©Adafruit Industries Page 81 of 88 • WS2812B Datasheet (https://adafru.it/uaR) (used in some older RGB products) • WS2812 Datasheet (https://adafru.it/qta) (used in some older RGB products) • Online NeoPixel Simulator (https://adafru.it/NfG) NeoPixel 12-LED Ring • EagleCAD PCB files on GitHub (https://adafru.it/qic) • Fritzing object in Adafruit Fritzing library (https://adafru.it/aP3) NeoPixel 16-LED Ring • EagleCAD PCB files on GitHub (https://adafru.it/qic) • Fritzing object in Adafruit Fritzing library (https://adafru.it/aP3) ©Adafruit Industries Page 82 of 88 NeoPixel 24-LED Ring • EagleCAD PCB files on GitHub (https://adafru.it/qic) • Fritzing object in Adafruit Fritzing library (https://adafru.it/aP3) ©Adafruit Industries Page 83 of 88 NeoPixel 1/4 60-LED Ring • EagleCAD PCB files on GitHub (https://adafru.it/qic) • Fritzing object in Adafruit Fritzing library (https://adafru.it/aP3) NeoPixel Jewel • EagleCAD PCB files on GitHub (https://adafru.it/ped) • Fritzing object in Adafruit Fritzing library (https://adafru.it/aP3) ©Adafruit Industries Page 84 of 88 Breadboard Friendly NeoPixel Breakout • EagleCAD PCB files on GitHub (https://adafru.it/rAt) • Fritzing object in Adafruit Fritzing library (https://adafru.it/aP3) ©Adafruit Industries Page 85 of 88 NeoPixel NeoMatrix 8x8 • EagleCAD PCB files on GitHub (https://adafru.it/rB8) • Fritzing object in Adafruit Fritzing library (https://adafru.it/aP3) ©Adafruit Industries Page 86 of 88 NeoPixel Arduino Shield • EagleCAD PCB files on GitHub (https://adafru.it/rCg) • Fritzing object in Adafruit Fritzing library (https://adafru.it/aP3) ©Adafruit Industries Page 87 of 88 NeoPixel 8 Stick • EagleCAD PCB files on GitHub (https://adafru.it/rCQ) • Fritzing object in Adafruit Fritzing library (https://adafru.it/aP3) ©Adafruit Industries Page 88 of 88
很抱歉,暂时无法提供与“1507”相匹配的价格&库存,您可以联系我们找货
  • 1+521.953301+67.46210
库存:52
