1612
1612
    ADAFRUIT
    LED BOARD NEOPIXEL MINI PCB 1=5
1612 数据手册
Page 1 of 2 NEOPIXELS / NEOPIXEL LEDS NeoPixel Mini PCB - Pack of 5 PRODUCT ID: 1612 Page 2 of 2 DESCRIPTION - These are the smallest NeoPixel breakouts around! Tiny, bright RGB pixels to your project. These little PCBs are only 8mm x 10mm and have two sets of three pads on the back for soldering wires. These ultra-bright LEDs have a constant-current driver cooked right into the LED package! The pixels are chainable - so you only need 1 pin/wire to control as many LEDs as you like. These pixels have full 24-bit color ability with PWM taken care of by the controller chip. Since the LED is so bright, you need less current/power to get the effects you want. The driver is constant current so its OK if your battery power changes or fluctuates a little. Each pixel draws as much as 60mA (all three RGB LEDs on for full brightness white). An Arduino can drive up to 500 pixels at 30 FPS (it will run out of RAM after that). Using ribbon cable you can string these up to 6" apart (after that, you might get power droops and data corruption) Each order comes with 5 individually controllable pixel buttons. Our detailed NeoPixel Uberguide has everything you need to use NeoPixels in any shape and size. Including ready-to-go library & example code for the Arduino UNO/Duemilanove/Diecimila, Flora/Micro/Leonardo, Trinket/Gemma, Arduino Due & Arduino Mega/ADK (all versions) http://www.adafruit.com/products/1612 7/21/2015
很抱歉,暂时无法提供与“1612”相匹配的价格&库存,您可以联系我们找货
库存:63
1612
    • 1+45.564301+5.71610
