Breadboard-friendly RGB Smart NeoPixel Pack of 4
PRODUCT ID: 1312
Description
This is the easiest way possible to add small, bright RGB pixels to your project. We took the same
technology from our Flora NeoPixels and made them breadboard friendly, with two rows of 3 x 0.1"
spaced header on each side for easy soldering, chaining and breadboarding. These ultra-bright
LEDs have a constant-current driver cooked right into the LED package! The pixels are chainable so you only need 1 pin/wire to control as many LEDs as you like.
These pixels have full 24-bit color ability with PWM taken care of by the controller chip. Since the
LED is so bright, you need less current/power to get the effects you want. The driver is constant
current so its OK if your battery power changes or fluctuates a little.
Each pixel draws as much as 60mA (all three RGB LEDs on for full brightness white). An Arduino
can drive up to 500 pixels at 30 FPS (it will run out of RAM after that). Using ribbon cable you can
string these up to 6" apart (after that, you might get power droops and data corruption)
Each order comes with 4 individually controllable pixels. In the photos above we show the pixels with
headers soldered on, but the pixels do not come with any headers. You can pick up some in the shop if you
need
Our detailed NeoPixel Uberguide has everything you need to use NeoPixels in any shape and size. Including
ready‐to‐go library & example code for the Arduino UNO/Duemilanove/Diecimila, Flora/Micro/Leonardo,
Trinket/Gemma, Arduino Due & Arduino Mega/ADK (all versions)
Technical Details
Dimensions: 0.4" x 0.5" x 0.1" / 10.2mm x 12.7mm x 2.5mm
0.5" (12.5mm) diameter circle PCB, 0.1" (2.5mm) total thickness
800 KHz speed protocol
Chainable design
5-9VDC power (can run at 3.5V but color will be dimmed), constant current 18.5mA per LED
(~55mA max total per pixel)
NeoPixel EagleCAD PCB files and Fritzing Library available in the NeoPixel tutorial
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“1312”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+69.579821+8.99764
