WS2812B
Intelligent control LED
integrated light source
Features and Benefits
l
Intelligent reverse connect protection, the power supply reverse connection does not damage the IC.
l
The control circuit and the LED share the only power source.
l
Control circuit and RGB chip are integrated in a package of 5050 components, form a complete control of pixel
point.
l
Built-in signal reshaping circuit, after wave reshaping to the next driver, ensure wave-form distortion not
accumulate.
l
Built-in electric reset circuit and power lost reset circuit.
l
Each pixel of the three primary color can achieve 256 brightness display, completed 16777216 color full color
display, and scan frequency not less than 400Hz/s.
l
Cascading port transmission signal by single line.
l
Any two point the distance more than 5m transmission signal without any increase circuit.
l
When the refresh rate is 30fps, cascade number are not less than1024 points.
l
Send data at speeds of 800Kbps.
l
The color of the light were highly consistent, cost-effective..
Applications
l
Full-color module, Full color soft lights a lamp strip.
l
LED decorative lighting, Indoor/outdoor LED video irregular screen.
General description
WS2812B is a intelligent control LED light source that the control circuit and RGB chip are integrated in
a package of 5050 components. It internal include intelligent digital port data latch and signal reshaping ampli
fication drive circuit. Also include a precision internal oscillator and a 12V voltage programmable constant curr
e-nt control part, effectively ensuring the pixel point light color height consistent.
The data transfer protocol use single NZR communication mode. After the pixel power-on reset, the DIN
port receive data from controller, the first pixel collect initial 24bit data then sent to the internal data latch,
the other data which reshaping by the internal signal reshaping amplification circuit sent to the next cascade
pixel through the DO port. After transmission for each pixel,the signal to reduce 24bit. pixel adopt auto resha
-ping transmit technology, making the pixel cascade number is not limited the signal transmission, only depend
on the speed of signal transmission.
LED with low driving voltage, environmental protection and energy saving, high brightness, scattering angl
e is large, good consistency, low power, long life and other advantages. The control chip integrated in LED
above becoming more simple circuit, small volume, convenient installation.
http://www.world-semi.com
WS2812B
Mechanical Dimensions
PIN configuration
PIN function
NO.
Symbol
Function description
1
VDD
2
DOUT
3
VSS
Ground
4
DIN
Control data signal input
Power supply LED
Control data signal output
Absolute Maximum Ratings
Prameter
Symbol
Ratings
Unit
Power supply voltage
VDD
+3.5~+5.3
V
Input voltage
VI
-0.5~VDD+0.5
V
Topt
-25~+80
Tstg
-55~+150
Operation junction
temperature
Storage temperature range
Electrical Characteristics(TA=-20~+70℃,VDD=4.5~5.5V,VSS=0V,unless otherwise specified)
WS2812B
Prameter
Smybol
conditions
Min
Tpy
Max
Unit
Input current
II
VI=VDD /VSS
±1
µA
VIH
DIN ,SET
0.7VDD
V
VIL
DIN ,SET
0.3 VDD
V
VH
DIN ,SET
0.35
V
Input voltage level
Hysteresis voltage
Switching characteristics(TA=-20~+70℃,VDD=4.5~5.5V,VSS=0V,unless otherwise specified)
Prameter
Symbol
Condition
Min
Tpy
Max
Unit
Operation frequency
Fosc2
800
KHz
300
ns
120
µs
Duty ratio50%
400
Kbps
15
pF
Transmission delay
time
Fall time
Data transmission
rate
Input capcity
tPLZ
tTHZ
FMAX
CI
CL=15pF,DIN→
DOUT,RL=10KΩ
CL=300pF,OUTR/OU
TG/OUTB
WS2812B
LED characteristic parameter
Emitting color
Model
Wavelength(nm)
Luminous intensity(mcd)
Voltage(V)
Red
13CBAUP
620-630
550-700
1.8-2.2
Green
13CGAUP
515-530
1100-1400
3.0-3.2
Blue
10R1MUX
465-475
200-400
3.0-3.4
Data transfer time( TH+TL=1.25µs±150ns)
T0H
0 code ,high voltage time
0.35us
±150ns
T1H
1 code ,high voltage time
0.9us
±150ns
T0L
0 code , low voltage time
0.9us
±150ns
T1L
1 code ,low voltage time
0.35us
±150ns
RES
low voltage time
Above 50µs
Sequence chart:
T0 L
0 cod e
T0H
T1L
1 code
T1 H
Treset
RET co de
Cascade method:
D1
D2
DIN DO
D IN DO
PIX1
PIX2
D3
D4
DIN DO
PIX3
WS2812B
Data transmission method:
reset code
>=50us
Data refresh cycle 1
first 2 4 b it
D1
Data refresh cycle 2
seco n d
2 4 b it th ird 2 4 b it
seco n d
2 4 b it
D2
reset
code
first 2 4 b it
th ird 2 4 b it
seco n d
2 4 b it
th ird 2 4 b it
seco n d
2 4 b it
th ird 2 4 b it
th ird 2 4 b it
D3
th ird 2 4 b it
D4
Note: The data of D1 is send by MCU,and D2, D3, D4 through pixel internal reshaping amplification to
transmit.
Composition of 24bit data:
G7
G6
G5
G4
G3
G2
G1
G0
R7
R6
R5
R4
R3
R2
R1
R0
Note: Follow the order of GRB to sent data and the high bit sent at first.
B7
B6
B5
B4
B3
B2
B1
B0
WS2812B
Typical application circuit:
U1
5V
1
C1
104
2
VDD
DIN
DOUT
VSS
4 DIN
3
WS2812B
U2
5V
1
C2
104
2
VDD
DIN
DOUT
VSS
4
3
WS2812B
U1
5V
1
C1
104
DOUT2
VDD
DIN
DOUT
VSS
WS2812B
4
3
很抱歉,暂时无法提供与“110990053”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 11+34.4061311+4.41851
